Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Removing the plastic bezel around the radio
Reply
Thread Tools
Old 10-28-2010, 08:14 AM   #1
Joe DeVola
AtL
2004 XLT
Vehicle Specs
(Original Poster)
How dos the bezel around the radio get removed? Just pop it off or does other trim around need to be removed first?
Joe DeVola is offline   Reply With Quote
Old 10-28-2010, 08:25 AM   #2
F15E_WSO
Washington DC area
2002 XLT; 2001 Exp Sport
Vehicle Specs
On one of mine there are two screws sort of hidden, just above the climate controls, that is where I would start. We will remove it soon and repaint a different color. Good luck.
F15E_WSO is offline   Reply With Quote
Old 10-28-2010, 09:10 AM   #3
iBrent
Northborough, MA
2005 Eddie Bauer 4x4
Vehicle Specs
If you're referring to this piece:
http://cgi.ebay.com/ebaymotors/2003-...#ht_500wt_1164
Then it just pops off. No screws involved. No other trim removal required. Work a PLASTIC pry bar around the outside. There are a total of 4 clips, 2 on top, 2 on the side near the bottom. Also expect wires going to the climate controls.
__________________
2005 Explorer Eddie Bauer
iBrent is offline   Reply With Quote
Old 10-28-2010, 09:14 AM   #4
Joe DeVola
AtL
2004 XLT
Vehicle Specs
(Original Poster)
That's it exactly.
No screws then?
Old 10-28-2010, 09:15 AM   #5
Joe DeVola
AtL
2004 XLT
Vehicle Specs
(Original Poster)
Quote:
Another responder showed me a picture of an identical bezel. My doesn't have any screws above the climate controls.
Old 10-28-2010, 09:38 AM   #6
iBrent
Northborough, MA
Vehicle Specs
Quote:
Originally Posted by Joe DeVola View Post
That's it exactly.
No screws then?
Correct, to remove that bezel there are no screws. There are 2 screws to remove the radio once that bezel is removed, but that will become obvious when the bezel is gone.
__________________
Old 10-28-2010, 09:59 AM   #7
Joe DeVola
AtL
2004 XLT
Vehicle Specs
(Original Poster)
Very good. Thank you.
Old 10-28-2010, 10:30 AM   #8
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Crazy Joe Devola (I hope that is a Seinfeld reference and I didn't just insult you), Check out this thread for removing the radio bezel: http://www.explorerforum.com/forums/...d.php?t=271666
I recommend using a flat, wide object so you don't leave any marks. I use a butter knife and haven't left any marks.
Good luck.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is online now   Reply With Quote
Old 10-28-2010, 02:10 PM   #9
MoonRocky
Lake Ozark, Missouri
2002 Explorer XLT V6 4.0
Vehicle Specs
I popped mine off with a 3" wide paint scrapper. Worked just fine.
MoonRocky is offline   Reply With Quote
Old 08-10-2011, 06:30 PM   #10
rosiedoll
portland or
1996 Ford Explorer V8 awd
Vehicle Specs
I took the 4 screws off the bezel just under topp of dash, and have some play with now with bezel, but it doesnt seem to want to get loose all around....its a 1988 ford ranger some bozo stuck a radio BEHIND the bezel and not secure it...so need to replace it, but can't get old radio out thru bezel I am scred I am going to vreak it,,, tried to find a utube viseo on how to..no luck
rosiedoll is offline   Reply With Quote
Old 08-10-2011, 06:59 PM   #11
LONO100
Bay Area CA
LONO100's Avatar
03 sport trac XLT
Vehicle Specs
remove the two small screws under the bottom of the bezel, then carefully snap the rest of the brackets off. the radio should come out with it.
LONO100 is online now   Reply With Quote
Old 08-10-2011, 11:03 PM   #12
jayton
Jefferson, GA
02 XLT V8
Vehicle Specs
This thread is from last year. I think the original poster may have already figured it out by now. On the 4 door Explorers from 2002-2005, I know for a fact that there are no screws holding this bezel in place. Also, +1 on someone else's suggestion of using a butter knife. No marks!
__________________
jayton
2002 Explorer XLT, 2WD, 4.6L SOHC
1996 Mustang GT, Convertible, 4.6L SOHC (I have two of these)
1993 Grand Marquis
2002 BMW 325i Sedan
jayton is offline   Reply With Quote
Old 01-12-2013, 10:51 AM   #13
danny3221
ocala fl
1996 \explrer xlt 2wd
Vehicle Specs
On the 1996 xlt there are 2 small screws on the front on the facing. these are practically hidden near the botton. once you get those out, and pull the radio out (which is still attached) there are two screws on the right side that hold the radio in.
danny3221 is offline   Reply With Quote
Old 01-14-2013, 03:42 PM   #14
sfhess
Palmdale CA
2002 Explorer XLT 2WD
Vehicle Specs
Quote:
All fine and good, but this section of the bulletin board is for 2002-2005 Explorers, which are a different animal than a 1996 model.
sfhess is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
