Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Hard shift into reverse
Reply
Thread Tools
Old 10-28-2010, 09:41 PM   #1
tmac1180
Immokalee, FL
2006 Ford Explorer 2WD
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
New to this site....My wife has a 2006 Ford Explorer 2WD base model. When we shift into reverse there is a few second delay followed by a hard shift into reverse. The vehicle makes a loud noise when shifting into reverse and the vehicle feels like it rocks. The vehicle shifts fine in normal driving conditions (automatic). We have found that if we depress the brake pedal hard almost to he floor, the shifting into reverse is fine with no sound and no problem. Any idea what this is?
tmac1180 is offline   Reply With Quote
( Join the Elite Explorers )
Old 10-28-2010, 10:31 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 411 Post(s)
Welcome to this forum! How many miles does it have? The solenoid block & servo bores tend to act up around 60K miles. Did you check the fluid level? It might be low on fluid. Did you ever replace the fluid & filter?
BrooklynBay is offline   Reply With Quote
Old 10-28-2010, 10:35 PM   #3
Perfect5miles
Stoughton,MA
1997 Explorer Sport 4wd
Vehicle Specs
Quoted: 0 Post(s)
Hey Bud when I first Bought My 1997 Sport it Had the same problem so Before the probmlem Got worse i Changed the Tranny Fluid and filter and added a product Called (sea foam ) TRANS TUNE ) I;m Proud to Say it Completly Fixed The Problem You can't even tell it shifted now
Perfect5miles is offline   Reply With Quote
Old 10-28-2010, 10:39 PM   #4
tabezic
Shelby twp. Michigan
02 mountaineer v8
Vehicle Specs
Quoted: 0 Post(s)
my mounty does that sometimes.
__________________
I would if I could. But I cant, so i wont.
2002 mercury mountaineer 4.6 v8. no cats. flowmaster muffler. air box mod w/ k&n drop in. 17% tints. interior LEDs. Leds in the headlights. 12000k (spring and summer) and 8000k(fall and winter) hi/lo HIDs in the headlight and fogs.
http://www.cardomain.com/ride/337743...township-mi-us
tabezic is offline   Reply With Quote
Old 10-28-2010, 10:39 PM   #5
tmac1180
Immokalee, FL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks for both replies! Sorry I forgot to mention the miles. I think she has just over 85k on it.
It is a weird problem. If the brake is pressed as normal, it acts up. We have to push it almost to the floor to engage it into reverse without the noise and feel.
Old 10-28-2010, 10:41 PM   #6
tabezic
02 mountaineer v8
Vehicle Specs
Quoted: 0 Post(s)
i got 130k miles and a new trans at 126k. some times of i shift into reverse when im very slowly rolling foward, it wont slam into reverse.
__________________
Old 10-28-2010, 10:47 PM   #7
Perfect5miles
Stoughton,MA
Vehicle Specs
Quoted: 0 Post(s)
Yea Mine Has 77xxx on it, I swear Its The Same Thing I Used To do the brake thingto but its called a hard shift and that trans tune will solve it
Old 10-28-2010, 10:55 PM   #8
tmac1180
Immokalee, FL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Trans Tune...I will try that and see...thank you.
Old 10-28-2010, 10:58 PM   #9
tmac1180
Immokalee, FL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Oh, one more thing. Not to sound dumb, but where might I add the Sea Foam/Trans Tune considering that only a shop (or someone along those lines) can check the fluid?
Old 10-28-2010, 10:59 PM   #10
Perfect5miles
Stoughton,MA
Vehicle Specs
Quoted: 0 Post(s)
Sea Foam-Trans Tune its like $9 replace the filter and fliud though,No Problem Brother I rather hear its fixed for $40 than have a headache of having to replace your tranny
add it when your putting in the tranny fluid at the dipstick hole
i dont know how mechinically inclined you are but buy a haynes repair manual .its really simple you go under neath you vehicle loosen up one side more than the other let it drain then take the pan off clean it out along with the magnet in there it will filthy wipe it all down layout the new gasket on the pan preset the bolts through the pan into the gasket wipe around the pan case than start one corner of the pan then go to the otherside of the pan tighten the pan bolts equally job done
Old 10-28-2010, 11:07 PM   #11
tmac1180
Immokalee, FL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'd like to but the 2006 model doesn't have an under the hood dipstick....
Old 10-28-2010, 11:11 PM   #12
Perfect5miles
Stoughton,MA
Vehicle Specs
Quoted: 0 Post(s)
you have to crawl under your vehicle theres a rubber plug around your tranny thats your dip stick
Old 10-28-2010, 11:14 PM   #13
tmac1180
Immokalee, FL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Ahhh and simply inject it up into the transmission then I take it?
Old 10-28-2010, 11:17 PM   #14
Perfect5miles
Stoughton,MA
Vehicle Specs
Quoted: 0 Post(s)
it will be on the upper side of your tranny so you shouldnt have a problem
look under there pop it out youll see its just a regular dipstick except it underneath
Old 10-28-2010, 11:26 PM   #15
Perfect5miles
Stoughton,MA
Vehicle Specs
Quoted: 0 Post(s)
it show a diagram if you search this post on this site :2006 6R transmission fluid inspection procedure
Old 10-28-2010, 11:38 PM   #16
tmac1180
Immokalee, FL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I will...thanks again I really appreciate it!
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
