Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Heated seat switch.
Reply
Thread Tools
Old 11-08-2010, 07:31 AM   #1
cjah2oskier
Chester, NJ
2004 EB
Vehicle Specs
(Original Poster)
Heated seat switch.
Has anyone replaced the seat heater switch in 03 EB. Can't turn the heater off
cjah2oskier is offline   Reply With Quote
Old 11-08-2010, 08:52 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the stock 2002-2005 section. You could test the switch with a continuity tester.
BrooklynBay is offline   Reply With Quote
Old 11-08-2010, 01:11 PM   #3
jrford
Birmingham, MI
'10 Sport Trac
Vehicle Specs
bummer on the '03 as there is a mid model change for the heated seats, no idea when the switch over was made.
They started with a Heated Seats Module (black box under seat) to control the heated seats, if you have one that would be my first guess.
Half-way through they dropped the module all together, and only use a switch, and heaters no module, switch here seems common.
__________________
Jim
2010 Mercury Mountaineer Premier, V8 AWD, 15k
2010 Sport Trac Limited, V8 4WD, 55k
2004 EB Quad Buckets V8 AWD, 105k
jrford is offline   Reply With Quote
Old 11-17-2010, 01:40 PM   #4
kmb6013
West Seneca, NY
2004 Eddie Bauer
Vehicle Specs
I have an '04 Eddie Bauer with the same problem. If I push the button in the light on the display goes off but as soon as I release the button the heated seats indicator lights stays on. How do I test the switches and module mentioned above?
kmb6013 is offline   Reply With Quote
Old 11-17-2010, 03:48 PM   #5
rocco123
Endicott, NY
rocco123's Avatar
1994 XLT & 2002 Limited
Vehicle Specs
Remove the seat to get closer to the switch, disconnect switch & perform a simple continuity test. Push in & you should have cont. Let go & it should show open.
I'm in the process of wiring mine so it will start to heat when I remote start the truck. What I never liked about my heated seats is that they only heat to a point, then switch off without coming back on. Guess this is normal for explorers, but not other heated seat systems.
rocco123 is offline   Reply With Quote
Old 11-22-2010, 08:31 PM   #6
nasty_north
canada
03 Eddie Bauer v6
Vehicle Specs
my 03 EB heated seat wont turn off despite pushing the button, no indication lights either on gauge cluster or switch. going to have to trouble shoot this problem also before my rear end develops warts. lol
this looks useful guide for no power: http://www.ehow.com/how_6225806_trou...-explorer.html
another 03 explorer with always on problem : http://groups.google.com/group/rec.a...2c55fcee35084a
nasty_north is offline   Reply With Quote
Old 01-29-2012, 06:23 PM   #7
sk_mountaineer
2005 Mountaineer
Vehicle Specs
Heated switch part number
Anyone know the part number for this heated seat switch for the 2002-2006 Mercury Mountaineers? Thanks.
sk_mountaineer is offline   Reply With Quote
Old 01-30-2012, 04:25 PM   #8
Paul Cerisano
Guelph
2004 Ford Eddie Bauer
Vehicle Specs
heated seat switch
Part # 3L2Z 14D694-AA
Paul Cerisano is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
