#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
1994 Ford Explorer XLT with an automatic transmission problem.
Reply
Thread Tools
Old 11-14-2010, 10:52 AM   #1
Fordexplorerguy1
NC
Fordexplorerguy1's Avatar
94 XLT 4.0 tow package?
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I just bought a 500$ 94' explorer xlt with a tranny problem. When its cold it doesnt want to shift past first gear but after it warms up it shifts no problem.
Any idea on what it could be or on how to fix it? Some help would be much appreciated! thanks
Fordexplorerguy1 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-14-2010, 01:22 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the transmissions section. It sounds like you have a sticking governor.
BrooklynBay is offline   Reply With Quote
Old 11-14-2010, 07:21 PM   #3
Fordexplorerguy1
NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
How do i fix that?
Old 11-14-2010, 08:36 PM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Check # 45 in my list of useful threads: http://www.explorerforum.com/forums/...d.php?t=155582
Old 11-14-2010, 10:13 PM   #5
Fordexplorerguy1
NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
yeah,i have been looking at that thread actually, mine is a 4x4 too so would that change anything?
Old 11-14-2010, 10:14 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Everything should match your set up.
Old 11-14-2010, 10:17 PM   #7
Fordexplorerguy1
NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
mkay so to fix it just take it apart clean and lubricate?
Old 11-14-2010, 10:20 PM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
Sometimes it might be necessary to replace if it's worn down. WWW.Wittrans.Com sells them. Sonnax makes a 35 MM weight as an upgrade for the old weight.
Old 11-14-2010, 10:25 PM   #9
Fordexplorerguy1
NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
So that would solve it from not shifting out of first when cold, and from 2nd to third?
Old 11-14-2010, 10:29 PM   #10
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 380 Post(s)
The weight on the governor is probably binding when it's cold, then it loosens up as the fluid warms up.
Old 11-14-2010, 10:41 PM   #11
Fordexplorerguy1
NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
ok, this weekend ima tear it appart and see if i can fix it thanks!
Old 12-21-2010, 01:44 PM   #12
Fordexplorerguy1
NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
:bump: no luck and on top of it all the transmission is not engaging till like 10-30 secconds after i select drive. This is so frustrating.
Reply
Tags
1994 explorer 4x4, explorer, transmission problem
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
