#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Check Engine light flashing!!!
Reply
Thread Tools
Old 11-22-2010, 01:18 PM   #1
Heeman12
Palm Harbor, FL
'04 xls
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US Check Engine light flashing!!!
I have an 04 Explorer and the check engine light has been going on and off for a few months. Had it checked a while ago and it was the egr valve, no big deal. Today the light started flashing and the car started shaking pretty good. Had the car towed to ford. Waiting to hear from them. Any ideas? Bad Coils?
Heeman12 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-22-2010, 03:51 PM   #2
Dan Whitaker
One fast putty tat
Raytown MO (Kansas City suburb)
Dan Whitaker's Avatar
No Mounty no more.
Vehicle Specs
Quoted: 21 Post(s)
Most likely a bad plug or bad plug wire.
__________________
P r i c k me, do I not bleed Ford Blue.
Dan Whitaker is offline   Reply With Quote
Old 11-22-2010, 06:57 PM   #3
Lebowski
Crestwood, KY
2005 Explorer 4x4
Vehicle Specs
Quoted: 0 Post(s)
You should post your problem here BEFORE taking it to the dealer. You could fix that problem for less than $10 and the dealer will probably charge you at least ten times that amount....
Lebowski is offline   Reply With Quote
Old 11-22-2010, 09:51 PM   #4
Heeman12
Palm Harbor, FL
'04 xls
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I asked about possible coil problems and he said definetly not the issue. He says that there is no compression in 2 cylinders. Now only option is for them to do a complete pressure check and just the test will cost $300. How much trouble am i in?
Old 11-23-2010, 08:01 AM   #5
matt0248
Chicago
02 XLT V8
Vehicle Specs
Quoted: 1 Post(s)
Get a second opinion. Have it towed somewhere else. However the 4.0 liters do have timing chain issues. so it is possible that the chain sliped and bent valves.
matt0248 is offline   Reply With Quote
Old 09-01-2012, 03:59 PM   #6
TK@96789
Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
I have a 2002 Ford Explorer XLT with 170,000 miles. Yesterday car lost power and began to shake and check engine light began to flash. Someone behind me said my vehicle had a strong gas smell. Picked up a diagnostci tool and told misfire detected on startup and cylinders 1,2,and 3 misfired (P0316,P0301,P0302 and P0302). Changed out my ignition coil and everything seems fine (power back, no check engine light and car not shaking). Hope this helps anyone who has this problem.
TK@96789 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
