#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
No Horn or Cruise Control
Reply
Thread Tools
Old 11-23-2010, 12:08 AM   #1
llabourdeth
Houghton, MI
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I'm trying to figure out whats wrong with the cruise control and horn on my '98 explorer. Neither work, but the airbag light doesn't indicate any problems, so it's not likely that the problem is the clock spring. Additionally, when I use the remote to lock the car, the horn chirps. I already checked all the fuses, and they all checked out ok. Any ideas on what the problem could be?
llabourdeth is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-29-2010, 10:34 PM   #2
larivera1989
Florida
99 Eddie Bauer 5.0
Vehicle Specs
Quoted: 2 Post(s)
sounds like it might just be the wiring harness probably got damaged. the horn and cruise control work thru that same harness it might have to be replaced or fix if possible. i had a similar problem with my 97 explorer which at one point nether the horn or cruise control worked. i was lucky enough to come across a complete harness with the buttons in mint condition as the old ones were in really bad shape .i carefully installed it in my truck wen i tested it everything worked again.. hope this helps
larivera1989 is offline   Reply With Quote
Old 11-29-2010, 11:04 PM   #3
waskly
Crooklyn NY!
Vehicle Specs
Quoted: 4 Post(s)
clock spring....
waskly is offline   Reply With Quote
Old 11-29-2010, 11:23 PM   #4
01EXP5.0
Corbin, KY
01 Limited
Vehicle Specs
Quoted: 0 Post(s)
Quote:
Originally Posted by waskly View Post
clock spring....
The clock spring is the cool little mechanism that allows the horn and airbag to send/receive a signal without twisting and breaking wires from all the turning of the steering wheel. Here is a link to give you an idea of what one looks like. http://www.dormanproducts.com/p-10034-525-213.aspx
__________________
If it ain't broke, then I ain't gotta hold of it yet.
01EXP5.0 is offline   Reply With Quote
Old 11-30-2010, 02:07 AM   #5
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
Check the fuse under the hood. When it blows, you lose the horn and the cruise.
__________________
If we confess our sins, He is faithful and just and will forgive us our sins and purify us from all unrighteousness. 1 John 1:9
Joe Dirt is offline   Reply With Quote
Old 12-01-2010, 03:36 PM   #6
llabourdeth
Houghton, MI
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Do you have a part number for that harness? And I already checked the fuse.
Old 12-02-2010, 11:51 AM   #7
larivera1989
Florida
99 Eddie Bauer 5.0
Vehicle Specs
Quoted: 2 Post(s)
dont know what the part# is but i have a pic of what it looks like (old one from my x)
__________________
1997 Explorer XLT 4.0L OHV
1999 Explorer Eddie Bauer 5.0L V8
2001 Explorer Eddie Bauer 4.0L SOHC
http://www.explorerforum.com/forums/...d.php?t=299316
Old 12-05-2010, 01:49 PM   #8
llabourdeth
Houghton, MI
'98 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I figured out what the problem was. It did have to do with the harness, but the harness itself wasn't bad. It was the left side cruise control button. It had somehow been disconnected from the harness at some point and wasn't properly plugged back in. After putting everything together properly, everything started working. Thanks for the help.
Old 12-05-2010, 02:00 PM   #9
2TimingTom
Highlands Ranch, Colorado
2TimingTom's Avatar
'97 XLT
Vehicle Specs
Quoted: 232 Post(s)
I have a question regarding this (sorta). My cruise and horn both work, BUT should the cruise buttons on the LEFT side of the steering wheel illuminate when the headlights are on? The right side buttons do but my left don't.
__________________
1997 XLT SOHC: SAS/SOA
Explorer registry
Also in the garage: 2012 Escape Limited 4wd V6 AND 2000 Expedition Eddie Bauer 5.4L AWD- registry
Modified RBVs
2TimingTom is offline   Reply With Quote
Old 12-05-2010, 02:51 PM   #10
Joe Dirt
Joe Dirt's Avatar
07 Camry
Vehicle Specs
Quoted: 6 Post(s)
They should. Well, when new they do, those lights don't last very long. I you have any still lit, consider yourself lucky!
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
