#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2000 Explorer OHV Fuel Pressure Regulator
Reply
Thread Tools
Old 11-29-2010, 02:55 PM   #1
ronomac25
Raleigh/Durham, NC
2000 Ford Explorer XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello!
This is my first post to this wonderful website looking for assistance.
2000 Ford Explorer V6 OHV
I am looking to replace my fuel pressure regulator after having several problems with the check engine light. I have diagnosed it to be the fuel pressure regulator and have a question about what kind of part I need.
I understand it to need a PSI of 30-35, but I am having trouble finding the right part. Advance Auto currently has this:
Part No# 4309
http://shop.advanceautoparts.com/web...7CGRP2030P____
It states it's not an OE piece of equipment and at a 9-12 PSI.
Can anyone assist me in locating an applicable replacement?
Thank you!
ronomac25 is offline   Reply With Quote
( Join the Elite Explorers )
Old 11-29-2010, 03:10 PM   #2
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
In the tank
Starting with 1999 (I believe) the fuel pressure regulator is part of the fuel pump assembly located in the fuel tank. The thing on the fuel rail that looks like a regulator is only a damper. Your fuel pressure should be constant at about 60 to 65 psi. There is no return fuel line. Fuel pressure test procedure
2000StreetRod is online now   Reply With Quote
Old 12-02-2010, 09:37 PM   #3
ronomac25
Raleigh/Durham, NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
It's really in the tank huh? I don't think that's something I will be able on replace on my own...
Thanks for the info and the quick response!!
Old 12-03-2010, 08:53 AM   #4
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Quoted: 31 Post(s)
What is the system fuel pressure?
For the model truck you have it should be 65-72 psi...Minimum pressure would be 55-60 psi...If your pressure is lower than that you probably need a pump instead of a fuel pressure regulator..
In the returnless fuel system, the FPR is in the tank on the sending unit/fuel pump assembly...And the regulator is there to relieve too high pressure not to modulate system pressure as the vacuum operated units on a return type fuel system...
Check the picture...The FPR is indicated by the black arrow and the fuel pump is indicated by the purple arrow...
__________________
When in doubt, use a bigger hammer!
2014 Jeep Compass Limited [Company Vehicle]
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is offline   Reply With Quote
Old 02-20-2011, 12:12 PM   #5
ronomac25
Raleigh/Durham, NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I am getting a reading on the diagnosis tool of 'lean mix in banks 1 & 2'. I have not checked the pressure in the lines yet, but I appreciate the help and pics!!
Old 02-20-2011, 12:26 PM   #6
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
You probably have intake gasket problem which will give you lean codes P0171 and P0174.
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 02-21-2011, 07:35 PM   #7
ronomac25
Raleigh/Durham, NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I am questioning the above information now because my Hayne's manual says its on top of the motor on a bracket with a vacuum line coming out of the top.
I uploaded a pic from the passenger side. Note the light gray vacuum line. Is this it? If so, any recommendations where I can order one from? Advance, Auto Zone and JCWhitney don't have any.
http://i10.photobucket.com/albums/a1...220_160014.jpg
Old 02-21-2011, 08:00 PM   #8
snoranger
Jackson, NJ
snoranger's Avatar
94 limited on 35's
Vehicle Specs
Quoted: 67 Post(s)
Dont ever believe what Haynes says!!!! The above info is correct.
The item in your pic is the heater control valve. It allows coolant to flow into the heater core.
__________________
94 limited: 4.0l, 5spd swap, 6" skyjacker lift, 35x14.5 thornturds, 4.56s. 5.0 swap started (94 cobra 5.0, zf 5spd, np205)
95 xlt: stockish (SOHC swap, 30,000miles and I blew up the 3rd 4r55e...now collecting parts for a Cummins swap.)
Cummins 4BT swap thread
Ranger bed trailer build
snoranger is offline   Reply With Quote
Old 02-21-2011, 08:44 PM   #9
budwich
Ottawa, Ont
96 XL
Vehicle Specs
Quoted: 0 Post(s)
X2... why would you think that's your fuel regulator... there doesn't appear to be any fuel lines going near it... but yes the vacuum does operate your heat flow... :-).
budwich is offline   Reply With Quote
Old 02-22-2011, 01:08 PM   #10
ronomac25
Raleigh/Durham, NC
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks guys...The picture of the 4.0L pushrod motor in the Haynes looks similar to this. Perhaps I was hoping it would be, cuz I don't plan on dropping my gas tank to do this...I am still learning a lot!
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
