Ford has tsb for this concern.
Printable View (48 KB)
TSB
09-1-6 IMPROVED BRAKE PEDAL FEEL AND FIRMNESS - BUILT BEFORE 5/31/2008
Publication Date: January 13, 2009
FORD: 2006-2008 Explorer
2007-2008 Explorer Sport Trac
MERCURY: 2006-2008 Mountaineer
This article supersedes TSB 08-2-8 to update the part list and add a production fix date.
ISSUE:
Some 2006-2008 Explorer, Mountaineer, and 2007-2008 Sport Trac vehicles built before 5/31/2008 may experience customer concerns with brake pedal feel or firmness.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Bleed the brake system using the anti-lock brake system (ABS) hydraulic control unit (HCU) bleeding procedure found in Workshop Manual (WSM), Section 206-00.
If the brake bleeding procedure resolves the concern, do not continue with this TSB and return the vehicle to the customer.
If the brake bleeding procedure does not resolve the customer concern, replace the brake pedal assembly.
Remove brake pedal assembly, Refer to WSM Section 206-06.
Install updated brake pedal assembly.
PART NUMBER PART NAME
8L2Z-2455-B Fixed Brake Pedal
8L2Z-2C434-E Adjust Pedal (Non-Memory)
8L2Z-2C434-F Adjust Pedal (Memory)
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
090106A 2006-2008 Explorer/Mountaineer, 2007-2008 Explorer Sport Trac: Bleed The Brake System (Do Not Use With 2000A) 0.7 Hr.
090106B 2006-2008 Explorer/Mountaineer, 2007-2008 Explorer Sport Trac: Bleed The Brake System, Replace The Brake Pedal Assembly (Do Not Use With 2000A, 13480A, 9818A8) 1.8 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
2455 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2009 Ford Motor Company
