Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Ranger - Mazda B-Series Forum > Ford Ranger - Mazda B-Series Forum
Notices
Ford Ranger - Mazda B-Series Forum Ford Ranger and Mazda B Series forums. The Mazda B2300 B3000 and B4000 are clones of the Ford Ranger, with all systems the same. The only differences are trim and a few body parts. This forum discusses Ford Ranger and Mazda B series specific issues. Owners of the older Mazda B2000 B2200 and B2600 are welcome as well.
My 1995 Ranger with a 4.0L starts & stalls with a rough idle when it's cold.
Reply
Thread Tools
Old 12-07-2010, 03:11 PM   #1
Ryan11383
Rockford Illinois
1995 Ford Ranger 4.0
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
US My 1995 Ranger with a 4.0L starts & stalls with a rough idle when it's cold.
I have a 1995 Ford Ranger. Since it has gotten cold when I go to start it after a long cold soak it will run great untill the idle comes down then it will idle rough and stall out. But once its warm it will run fine. The other thing I have noticed is when it dies my clock on my radio and the station will reset as if the battery was pulled.
Here is a list of what has been done.
Fuel Filter
IAC
New plugs/wires
MAF was cleaned
EGR replaced
I ran injector cleaner threw it
Ryan11383 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-07-2010, 06:49 PM   #2
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
You probably need the upper intake/fuel rail gaskets.
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 12-09-2010, 09:51 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 414 Post(s)
Welcome to this forum! I've moved your thread into the Ranger section. Do you have a check engine light with codes?
BrooklynBay is online now   Reply With Quote
Old 12-10-2010, 11:14 PM   #4
Ryan11383
Rockford Illinois
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
rough Idle/Stall.
I have two codes, one is for the EGR and the other code is a left side Lean code. I no its kinda hill billy but I have capped off the EGR. I put a plate between the EGR flange and tube to the intake. I have just done this because I didnt no if a EGR would fix the issue. I was right it didnt it still acts the same way. Truck will idle fine when rpms are up when its a cold start. Then when the rpms start to drop it will start to run rough and die. After its warm it will sit and idle fine for a min or so then it will start to idle rough and my idle rpm will rise and fall, then it will run rough and die.
I think im going to replace the upper intake. Its only 20 dollars and its not a bad job. So wish me luck and hope it goes well...
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
