#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger, A/C & Heater systems HVAC
Notices
Explorer, Ranger, A/C & Heater systems HVAC Ford Explorer, Ranger, Mountaineer, Bronco II, Air Conditioning and Heating Systems.
96 Explorer Limited EATC problem
Reply
Thread Tools
Old 12-11-2010, 08:10 PM   #1
Mooney123
highlands ranch, colorado
1992 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi I have a 96 limited ex with v8, and the heater is stuck on full hot. No matter what temp i select it never gets cooler so i ran the eatc DTC self test and came up with code 115. Anybody know how to fix this or how to troubleshoot it? lots of searching but nothing yet. Thanks
Mooney123 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-11-2010, 09:50 PM   #2
ragajungle
Chicago, IL
89 BroncoII & 05 Taurus
Vehicle Specs
Quoted: 1 Post(s)
Welcome! It is not uncommon for the Explorer to need a "Blend Door"....Use the search function to find "blend door" fixes for Gen 1-2 fixes.
ragajungle is offline   Reply With Quote
Old 12-12-2010, 09:39 AM   #3
Mooney123
1992 Explorer Sport
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks for the reply. Is that what code 115 indicates? Im searching it now
Old 12-12-2010, 10:50 AM   #4
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
115 is not a code in service manual. Here is the test procedure and loist of codes.
Section 12-03C: Air Conditioning System, Electronic Automatic Temperature Control 1996 Aerostar/Ranger/Explorer Workshop Manual
DIAGNOSIS AND TESTING Procedure revision date: 05/18/2000
Self Test
Perform EATC on-board diagnostic test. Record all diagnostic trouble codes (DTCs) displayed during test.
The control assembly will detect electrical malfunctions occurring during the on-board diagnostic.
Ensure that the engine is warm (at least 49C [ 120F]) coolant temperature). To display the DTCs for the malfunction detected, initiate the on-board diagnostic by pushing OFF and FLOOR simultaneously and then AUTOMATIC within two seconds. The test may run as long as 20 seconds, during which time the display will be blank. If the display is blank for more 20 seconds, go to Symptom Charts when On-Board Diagnostic Test and Functional Test Indicate NO ERROR.
The on-board diagnostic test can be initiated at any time, with the resulting DTCs being displayed. Normal operation of the system stops when on-board diagnostic is activated. To exit the on-board diagnostic and restart the system, push the blue button. Pushing the DEF button instead of the blue button will clear all DTCs. The on-board diagnostic should be deactivated before turning the EATC system OFF. Refer to the following chart for an explanation of DTCs.
If a malfunction exists but no DTC appears during the test in Step 1, refer to the appropriate pinpoint test(s) contained in this section.
INSPECTION AND VERIFICATION FOR DIAGNOSTIC TROUBLE CODES Condition Possible Source Action
DTC 024
Blend door calibration during self-test.
REFER to Pinpoint Test A.
DTC 030
Self-test indicates automatic temperature control sensor shorted.
REFER to Pinpoint Test K.
DTC 031
Self-test indicates automatic temperature control sensor open.
DTC 040
Self-test indicates A/C ambient air temperature sensor short.
REFER to Pinpoint Test G.
DTC 041
Self-test indicates A/C ambient air temperature sensor open.
DTC 050
Self-test indicates A/C sunload sensor short.
REFER to Pinpoint Test H.
DTC 025
Intermittent fault in blend door calibration.
DTC 042
A/C ambient air temperature sensor intermittent short.
DTC 043
A/C ambient air temperature sensor intermittent open.
DTC 052
A/C sunload sensor intermittent short.
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
