Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Help needed please
Reply
Thread Tools
Old 12-12-2010, 08:39 AM   #1
cruzzen
Gold Coast
cruzzen's Avatar
Vehicle Specs
(Original Poster)
Help needed please
We have another problem now with the car its a 2003 explorer XLT.
The stock alarm keeps going off all the time and when we are all driving the car keeps beeping say door ajar but all the doors are shut and have been checked.Has this happened to anyone on here what should i do?
cruzzen is offline   Reply With Quote
Old 12-12-2010, 11:24 AM   #2
waskly
Crooklyn NY!
Vehicle Specs
boot wire.. search this forum...
waskly is offline   Reply With Quote
Old 12-12-2010, 03:27 PM   #3
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
I had similar electrical issues with my 02 xlt. The dome lights would stay on until the battery saver feature turned them off, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, etc.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the driver's door. I found a broken wire and repaired it and all is back to normal!
Could also be related to the door ajar switch.
Here is a great thread for removing the door panel and checking/replacing the door ajar switch, thanks to borland for the awesome write-up: http://www.explorerforum.com/forums/...d.php?t=249253
Quote:
Originally Posted by thepotroast View Post
That is a great write up.
On a side note, before going through a complete replacement of the switch, you can spray WD40 into the door latch opening on each door, as these become stuck sometimes....and this can alleviate the issue.
This worked for me, after going for more than a year of the "door ajar" light coming on occasionally...mainly after a car wash, high humidity, or rain....making me unable to lock/arm the vehicle from the door keypad and keeping the dome lights on. Worth a try....it worked for me
Here is a great thread for checking for broken/damaged wires, thanks to synyster for this awesome write-up: http://www.explorerforum.com/forums/...d.php?t=270081
Hope this helps out. Be sure to keep us posted.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 12-12-2010, 05:54 PM   #4
cruzzen
Gold Coast
cruzzen's Avatar
Vehicle Specs
(Original Poster)
Thank you so much i will check it out
Old 12-12-2010, 05:58 PM   #5
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
You're welcome. Be sure to keep us posted.
__________________
Old 12-12-2010, 06:24 PM   #6
cruzzen
Gold Coast
cruzzen's Avatar
Vehicle Specs
(Original Poster)
I will
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
