Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > General Explorations!!
Notices
General Explorations!! Closed to new posts. Place new posts in our new model year appropriate forum
Rear Drum Brake Adjustment
Thread Tools
Old 05-30-2001, 09:58 AM   #1
David S.
Ogden, Utah
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I was getting a neverending squealing from my rear brakes for the last week. The drums have never been replaced so I decided just to replace them. When I took off the old drums, I backed off the star screw a few turns to get the new drums on. Instead of removing the rubber plug and readjusting the star screw, I believe I read somewhere that you can just drive in reverse and keep applying the brake to turn and star screw and the pads will be properly adjusted. Is this right?
__________________
Monroe Reflex
Bosch Platinum
Modified Airbox
20 mpg Hwy.
Big O Dual Groove Tires
David S. is offline
( Join the Elite Explorers )
Old 05-30-2001, 10:44 AM   #2
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
Yup. That'll work. The system is set up so that when the pads expand outwards, a lever moves the star adjuster automatically. You should have it somewhere near the proper adjustment point before you do it.
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline
Old 05-30-2001, 03:40 PM   #3
Nick K
Albuquerque, New Mexico
94 Explorer Sport 4X4
Vehicle Specs
Quoted: 0 Post(s)
Post
The book says reverse back 8 feet and then apply the brake firmly. Do this 2-3 times.
Nick K is offline
Old 05-30-2001, 11:45 PM   #4
mrboyle
I Drive By Brail
Montrose, CO
mrboyle's Avatar
'95 Bronco '80 Toy
Vehicle Specs
Quoted: 12 Post(s)
According to the fine print, this works. In reality it rarely works as designed. The "self adjusters" were designed to keep the shoes properly adjusted as they wear, not to adjust the brakes initally. To do this properly you need to manually adjust them.
__________________
Mike Boyle
'92 XLT(RIP) 1980 Toyota PU
Quote:
Originally Posted by DiffWackDaddy
Some people go looking for God, others get broadsided by them
mrboyle is offline
Old 05-31-2001, 04:52 PM   #5
Dre
Chicago
Dre's Avatar
94 Limited
Vehicle Specs
Quoted: 4 Post(s)
and that from my own experience is pretty tough.......... I'm a perfectionist.....and it took me good hour to adjust my brakes...... take the wheel off, take the drum off, adjust the screw...put everything back on and test....... then take the wheel off again, take the drum off and on and on... It must feel just right...... otherwise I'm using just the front brakes and wasting front pads and rotors......
I don't know, just me...
__________________
Yankee Kustoms
My Gallery
Dre is offline
Old 05-31-2001, 05:57 PM   #6
Maniak
Moderator-Stock 91-94
Vail, Arizona
Maniak's Avatar
1992 XLT 4x4
Vehicle Specs
Quoted: 213 Post(s)
Post
You don't "need" to take the wheel/drum off to adjust it..
There is an access hole (should have a rubber plug in it).. You can use a Flat Blade screwdriver.. or the acutal tool.. (kinda like a flat blade screw driver.. but with a flat end on each side.. and the metal is bent to make it easer to get it in there).. You need to rotate the adjustment wheel "up" to tighten it. If I don't have the time, I'll just lift the truck (put on jack stands).. and then rotate the tire as I'm adjusting it.. Once I hear the shoes start to scrape the drum.. I know that side is done.. I then do the other side..
When I want to get it perfect.. I lift the truck (jack stands).. remove 1 wheel and 1 drum.. then I adjust the other side.. (this way you are only feeling/hearing the 1 side).. Once this side is done I pull the tire/drum of the finished tire and repeat the adjust ment on the other side.. This will get it as close to exact as possible..
I have found that by removing the 1 tire/drum makes it easier to get right.. but I've done it enough times now that I can get it right with the tires still on.
Don't forget.. If you drums are worn down (with the shoes adjust correctly).. or you adjust it too tight you will have one heck of a time getting the drum off.
~Mark
__________________
Click HERE to see our Explorer Specs
Maniak is offline
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
