#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Thumping noise from the front end.
Reply
Thread Tools
Old 12-13-2010, 04:14 PM   #1
unclejack
Camden, De
1997 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I was wondering if anyone out there may have experienced the problem I'm having. I have a 97 Explorer XLT 130,000 mile auto 4.0 liter automatic. This thing has done everything I asked it to do so I want want to keep it around as long as possible. Here's the problem:As I drive down the road under normal conditions a thumping noise starts at a low speed and gets more pronounced the faster I go. It is not a tire slap. When I put it in 4 x 4 low I'm OK until I try to turn. Just in Idle I go forward about 10 mph as soon as I turn the wheel I hear a loud groan and the truck comes to a stop without touching the brakes. If I give it gas to speed up it just groans and thumps louder. Since I tried that last week I think the thumping noise is getting louder now going down the road. Any Ideas or suggestion would be appreciated. Thanks. Jack
unclejack is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-13-2010, 07:47 PM   #2
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
Sams01XplrSprt's Avatar
2001 Sport (sold)
Vehicle Specs
Quoted: 4 Post(s)
welcome
__________________
2001 Ford Explorer Sport 4.0 sohc engine. Mods include: dual 40 series flowmasters & high flow k&n air filter & removed silencer & yellow fog lights (sold for $1,800) as of 2-26-12
Sams01XplrSprt is offline   Reply With Quote
Old 12-13-2010, 08:08 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've moved your thread into the stock 95-01 section. Check the caliper bolts, wheel bearings, CV axles, ball joints, and tie rods.
BrooklynBay is online now   Reply With Quote
Old 12-13-2010, 08:13 PM   #4
WaCumminstech
Bremerton, WA
92 Explorer Xlt
Vehicle Specs
Quoted: 0 Post(s)
Id shoot for Front axle shafts also, look for grease, or a torn boot. I would think it would be more obvious, sounds like you lost a u-joint in the front axle.
Easy way to inspect is turn the wheels Full left, get out with a flash light and look inside the arm area, same with the right.
WaCumminstech is offline   Reply With Quote
Old 12-13-2010, 11:16 PM   #5
iwannabamedic
Central Kentucky
iwannabamedic's Avatar
2000 explorer XLS
Vehicle Specs
Quoted: 0 Post(s)
mine a 2000 ex does a thump but not in 4x4, garage told me the bearing in the axle next to drive shaft is going bad. The wheel bearing have been replace and the half shafts, front drive shaft feels solid. IDK
__________________
2000 Explorer 4x4, 4.0L OHV, XLS, 5r55e
2000 Ranger 4x4, 4.0 l XLT, M5R1 was 5r55e
1986 F 150 4x4 5.8L, XLT, Auto, Ext cab, LWB- sold
HERS 1996 Jeep Grand Cherokee Limited, 4x4 - sold
Charles
iwannabamedic is offline   Reply With Quote
Old 12-14-2010, 07:20 AM   #6
unclejack
Camden, De
1997 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey guys, Thanks for the quick replies. I don't believe it is anything loose like tie rods or ball joints, but it sounds like it coming from the drive train up front. The noise is very loud in 2wd at 35 -65 mph. With the car in drive at idle in 4wd (high) going forward at 10mph all is good. As soon as I turn left or right the front end will bind up and the truck will come to a stop.
I did a lot of reading on this site & now I'm leaning towards a bad Viscous Coupling (VC) or something up front. So, can I remove the drive shaft from the transfer case to the front axle and still drive the truck.
Old 12-14-2010, 04:36 PM   #7
my98nnj
Boonton, New Jersey
1998 XLT
Vehicle Specs
Quoted: 71 Post(s)
Quote:
This is somewhat normal, you shouldn't be in 4WD High or especially 4WD low on dry ground. This information is also in your owners manual.
On dry ground you will bind up the drive line when turning in 4WD.
I suspect that if you've been doing this something in the drive line has failed.
my98nnj is offline   Reply With Quote
Old 12-14-2010, 07:35 PM   #8
unclejack
Camden, De
1997 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My X is equipped with 4WD auto, 4WD high, & 4WD low. My Four Wheeling owner's supplement says do not use 4WD on dry, hard surfaced roads (except models equipped with Auto 4WD or AWD). Must be something magic with the Auto 4WD or AWD. I use 4WD (either high or low) when I pull my boat out of water. It's easier on my transmission, the owners manual says I should use 4WD occasionally during the year and recommends using 4WD low to pull a boat out of the water, and after I'm off the ramp I might go another 100 to 200 feet on dry (damp) hard road surface in 4WD. I never though of that as a problem mostly because I've been doing that for 13 years with this X and 10 years before that with my Bronco. Maybe 10 to 15 times per year.
The owners manual also says I should not drive faster than 45 mph when towing my boat. Tell that to the 18 wheeler on I-95 while he's blowing his horn and giving you that one finger salute.
As far as the wheels binding up and stopping the truck when I turn in 4WD I either didn't notice it before coming off the ramp or I really believe its something that started since I noticed this thumping noise.
So far I checked the rubber boots, they are OK, no cracks, no grease on the outside. Almost too clean for a truck with 130,000 miles. I tried to wiggle the outer cv joints while it was in Neutral and everything felt tight both sides. This weekend I'll pull the front wheels hubs and check (re-pack) the inner and outer bearings. Thanks for the suggestions so far & keep 'em coming.
Old 12-14-2010, 08:21 PM   #9
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
Vehicle Specs
Quoted: 454 Post(s)
It's the front differential (in the axel). You might have broken teeth.
PS: You don't have a VC - only the AWD has one. That is part of a true central differential, unlike yours that have a rigid coupling in the transfer case.
SoNic67 is offline   Reply With Quote
Old 12-15-2010, 07:34 AM   #10
unclejack
Camden, De
1997 Explorer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey, Sonic67, thanks for the heads up on the AWD. you're right & I didn't think of that. I guess I should check the front diff for metal chips.
Old 12-16-2010, 08:48 PM   #11
WaCumminstech
Bremerton, WA
92 Explorer Xlt
Vehicle Specs
Quoted: 0 Post(s)
Did you check he ujoints in the front shafts? typically, when in 4x4 on dry ground youll hear tire chirping, unless you broke something. if it was your diff you would only hear noise when you were in 4x4. But you are hearing it all the time, i would start simple, and work from there. As far as i know you dont have a fully locked front end, you may have a posi in the rear, but the front will be open, meaning if you jack up your front end you can grab the passenger side wheel and turn it, and the driver side will turn in the opposite direction. if your diff was junk it would be junk all the time, not just when you turn the wheel, which points back to the U-joints (or CV) joints in the front end. A rigid coupling would imply a "spool" or fully locked front end, ive never seen one from the factory, because an inexperienced off roader would have an incredible amount of trouble on any kind of slippery surface.
Old 12-16-2010, 09:26 PM   #12
tweety
just leaving your sister's
'97 sport
Vehicle Specs
Quoted: 0 Post(s)
same problem here
just passed 170k on my 97 sport 5spd.
last few days noticed a thumping noise and vibration (feels like someone is hitting something under the car with a 3lb. sledge) coming from front end when vehicle is moving above 15mph or so...thumps are continuous and increase with speed...whether accelerating or decelerating or coasting noise is there.
Today it was so loud almost pulled over on way home from work. Engine runs fine, car idles perfect...must be driveline related. Looked underneath when I got home...wiggled anything I could find...everything felt firm. Did notice some grease on passenger side around the axle.
Not sure if it is relevant but, last few days have been very cold...today was a bit warmer and noise seems to be getting worse.
(Had an old BMW did close to same thing few years back..turned out to be center support bearing on the drive shaft. When I got underneath and shook the drive shaft..the rubber surround on the bearing was ripped and allowed the drive shaft to bang against the tunnel. Didn't see anything quite so obvious under the explorer)
Together we will get through this!
tweety is offline   Reply With Quote
Old 12-16-2010, 10:02 PM   #13
ragajungle
Chicago, IL
89 BroncoII & 05 Taurus
Vehicle Specs
Quoted: 1 Post(s)
on the v8 awd models the front driveshaft makes the thunking noise at any speed. - It can be verified by removing the front ds.
Not sure about the v6 4wd - but I would think it could be the same scenario - a bad u-joint - again the best way is to drop it - if it stops then you have narrowed it to either the front axle or the ds
ragajungle is offline   Reply With Quote
Old 12-16-2010, 10:12 PM   #14
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Originally Posted by tweety View Post
(feels like someone is hitting something under the car with a 3lb. sledge)...must be driveline related. Looked underneath when I got home...wiggled anything I could find...everything felt firm
Crawl under the truck enough that you can see the boot of the CV-joint of the front driveshaft where it connects to the transfer case. If you have a CV-joint that is, and see if it is torn. If so search the forum for "front driveshaft" and you'll get a lot of information about it.
__________________
There is wisdom to be found in the counsel of many.
OneLever is offline   Reply With Quote
Old 12-16-2010, 11:37 PM   #15
WaCumminstech
Bremerton, WA
92 Explorer Xlt
Vehicle Specs
Quoted: 0 Post(s)
CV joints will be between the tire, and Diff, u joints will be between the t case and the front diff, the differenct between the two is because of the working angles, remember AWD, and 4x4 ARE different, ALL wheel drive is all the time, 4x4 is only when selected, he only has noise when in 4x4
Old 12-17-2010, 08:20 AM   #16
tweety
'97 sport
Vehicle Specs
Quoted: 0 Post(s)
little more info
my truck is the awd 4.0..and I did the brown wire mod on it about a year or so ago...I usually have the awd switched off 98% of the time. Primarily only engage it from standstill when trying to drive out of or through heavy snow.
Old 12-17-2010, 05:08 PM   #17
tweety
'97 sport
Vehicle Specs
Quoted: 0 Post(s)
latest...
Hey guys, the saga continues. The noise now seems to have subsided a bit...also no longer feels as much like something is heavily impacting the vehicle. Now seems like something is lightly impacting and then rubbing or grinding under the front end..but very loud and noticeable even from inside with the radio on. The noise is still continuous above 15mph and increases with speed
Ideas?
(Sorry uncle for hijacking..but thought any info would be beneficial for both of us.)
Old 01-02-2011, 01:00 PM   #18
tweety
'97 sport
Vehicle Specs
Quoted: 0 Post(s)
anyone still following this...
guys I replaced the front passenger side cv axle shaft...still rhythmic clunking noise above 20mph that increases with wheel speed (not rpm's)
Started thinking maybe u-joint in driveshaft..pulled front driveshaft, u-joint seemed fine. Drove around the block with front driveshaft out..still clunking noise from front passenger side. Could this just be a wheel out of balance? I'm running out of ideas and parts to replace.
Thanks for all your help.
Old 01-02-2011, 01:21 PM   #19
foxfire556
atlanta ga
2001 ranger 4x4
Vehicle Specs
Quoted: 0 Post(s)
I have the same problem.. its been going on for about 4 yrs.... I have replaced hub assemblys, cv axles,tires,Ect...
Im all out of ideas..
foxfire556 is offline   Reply With Quote
Old 01-02-2011, 06:19 PM   #20
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
Quoted: 1 Post(s)
Vibrations can travel up and down the driveline in deceptive ways. Don't rule out the rear driveshaft u-joints. Best advice I can give is to crawl under it and look at the entire underside for leaking fluid or grease. Then test each wheel manually for play and noise, and each shaft for play.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
