Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
can i change a automatic to a 5 speed?
Reply
Thread Tools
Old 12-22-2010, 05:30 PM   #1
winterfresh24
newberg OR
91 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i have a 1991 explorer 4x4 105k
my tranny is giving me some shifting problems and i have thought about what it would take to convert it to a 5 speed. i looked by the pedals and i have the mounts for the new pedal already in it and i know i can use a 5 speed from a ranger. i am just wondering if it could be done
winterfresh24 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-22-2010, 06:02 PM   #2
Midjurion
Boise, ID
'91 XLT 5speed stock
Vehicle Specs
Quoted: 0 Post(s)
Found this thread that would probably help you get going in the right direction on swapping
http://www.explorerforum.com/forums/...d.php?t=221708
__________________
Thanks, David
Proud owner of a 1991 Ford Explorer XLT 5speed 4x4
Midjurion is offline   Reply With Quote
Old 12-22-2010, 06:57 PM   #3
FIND
Vermillion, SD
99 XLT V8 AWD
Vehicle Specs
Quoted: 10 Post(s)
Yeah... Just buy a whole parts vehicle and swap everything over.
It isn't THAT expensive though to have a tranny rebuilt.... There is one seller on ebay that doesn't do a bad job of it and is reasonably priced... they are in arizona or something... so after shipping and then shipping your core back, it is usually around $1100. If you have a decent tranny place in your area, that is about how much a rebuild costs anyways half the time.
__________________
I strongly abide by the motto, "Safety third."
Quote:
Originally Posted by NICE59FORDF100 View Post
Dont forget numbers. Teacher Ladies LOVE numbers
FIND is offline   Reply With Quote
Old 12-23-2010, 06:04 AM   #4
Baddecision93
Orrville, OH
92 XLT
Vehicle Specs
Quoted: 0 Post(s)
This guy shows how he did it. I would personally describe his skill as "above average" but he makes it look very doable, lol.
http://www.explorerforum.com/forums/...d.php?t=253888
Remember though, once you get your old tranny out you are really past the point of no return. Your vehicle is disabled until you complete the swap. If you have access to another vehicle until you are finished it might be a good security blanket.
__________________
It's nothing time and money can't fix...
Trying to reverse rust, time, and the work of a crazy Amishman
My Explorer
Quote:
Originally Posted by DeRocha View Post
I can tell you Jesus is very popular when working on 10+yrd vehicles in the rust belt.
Baddecision93 is offline   Reply With Quote
Old 12-23-2010, 04:51 PM   #5
Joes4x4Ranger
The center of Hell, Parker, Arizona!
'91 XLT
Vehicle Specs
Quoted: 0 Post(s)
I had a donor rig ready in my garage with the 5 speed. I did the entire swap in a little over two days. It is a plug and play swap, no cutting welding or other custom modification needed. When you change the pedal cluster, un-bolt the wiring bulk head connector and you will have room to remove and replace the pedal shaft. Be sure to take the under hood wire harness to the tranny, neutral safety switch, and starter from the donor rig as well. The starters are different
If you tow anything heavier that a jet ski, stick with your automatic and have it rebuilt. Be ready to replace clutches every 3-4 years. Beware of weak reverse shaft and input shaft bearings on the manual tranny. Buy a new slave cylinder and master cylinder, and clutch for the manual, these fail regularly.
I also did the electric to manual transfer case swap. When I'm off road I DO NOT want to depend on cheap shit electric parts to get me in 4 wheel drive.
__________________
1991 Explorer XL 4X4, Reman-Motorcraft engine, 2.5 inch lift, Duff extended radius arms, Pro Comp Extended Steel Brake lines, Powertrax No-Slip Front and Rear, Warn Manual hubs, 31 X 10.50 BF Goodrich on Panther 15 X 8's, Overhead console.
Joes4x4Ranger is offline   Reply With Quote
Old 12-23-2010, 06:28 PM   #6
winterfresh24
newberg OR
91 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
thanks a lot everyone. i think i want to be starting on this project soon. the one thing i was wondering about to was if i should get a floor mounted 4x4 shifter. i think it would be better but im not sure if that would be to hard to do. i feel confident in my ability to do this because i just replaced my intake manifold gasket. and that sucked but its working great now.
Old 12-23-2010, 06:44 PM   #7
FIND
Vermillion, SD
99 XLT V8 AWD
Vehicle Specs
Quoted: 10 Post(s)
Every 3-4 years what? I have 3.27 gearing on mine and I tow cars with it sometimes. Just take care of the dang thing and you can get 200,000 miles out of it.
__________________
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
