Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
How to replace a steering gear box
Reply
Thread Tools
Old 12-22-2010, 07:13 PM   #1
davidhicks16
oreana il
94 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
This is my how to on a steering gear box replacement.
First: Position your truck on level ground with you wheels and steering wheel centered and lock your steering wheel
Second: Lift the drivers side of the vehicle and remove the wheel
Third: Flip the plastic cover off your steering shaft, this will give you access to the set screw that hold the steering shaft to the box.
Fourth: Remove the set screw ( It will fight you a little cause its covered in lock tight
Fifth: Remove the 2 fluid lines. I used a crows foot with a 2ft extension.
Sixth: Remove the pitman arm. (you will need to rent a puller for this)
Seventh: Remove the 3 bolts from the outside of the frame rail( I left the bolts hanging from the frame. It makes it easier to get restarted)
Eighth: Now you can pull the gear box free from the steering shaft.
Ninth: Pull the plastic caps out your new gear box. Wrap the steering shaft end with a rag and use pliers to turn the box to full lock. Now you turn the box all the way to full lock in the other direction, COUNT THE FULL TURNS! Now you know the full turns it can make take it halfway back and it will be centered.
Tenth: Push the gear box back on the steering shaft and put the set screw back in.
Eleventh: Put the three bolts from the frame back in the box.
Twelfth: Put the pitman arm back up on the box.
Thirteenth: Put the fluid lines back on snap the plastic shaft cover back on fill with fluid and you should be good to go.
__________________
82 full size bronco with sas underway
davidhicks16 is offline   Reply With Quote
( Join the Elite Explorers )
Old 12-22-2010, 07:32 PM   #2
FIND
Vermillion, SD
99 XLT V8 AWD
Vehicle Specs
Quoted: 10 Post(s)
I should have taken pictures when I did my dad's steering box.
__________________
I strongly abide by the motto, "Safety third."
Quote:
Originally Posted by NICE59FORDF100 View Post
Dont forget numbers. Teacher Ladies LOVE numbers
FIND is offline   Reply With Quote
Old 12-22-2010, 07:53 PM   #3
red.EDDIE.4x4
Tulsa, Oklahoma
'93 Eddie Bauer 4x4
Vehicle Specs
Quoted: 4 Post(s)
is there a need to "bleed" the steering box/pump?
__________________
1993 Eddie, 5.5 inch lift, 33's,
4.88s, cammed/bored 4.0, BW 1354M,
few more power adders...
For Sale: My rig - For sale
The Sploder
red.EDDIE.4x4 is offline   Reply With Quote
Old 12-22-2010, 08:08 PM   #4
davidhicks16
oreana il
94 xlt
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
When you center the box it spits all the machine oil out. Also after you fill the power steering fluid up leave the cap off slowly turn the wheel from lock to lock and that will work any air out.
__________________
Old 01-02-2013, 09:55 AM   #5
DR_APLET
Nor Cal Mendo
91
Vehicle Specs
Quoted: 0 Post(s)
How do i know if its bad? i have a little slop in mine. is there a definitive test? i am leaking fluid but i think its my pump.
__________________
Dr_aplet@hotmail.com
91 xploder Aussie rear, Lincoln front.
DR_APLET is offline   Reply With Quote
Old 01-20-2015, 02:37 PM   #6
smegun
florida
1994 ford explorer xlt
Vehicle Specs
Quoted: 11 Post(s)
replaced my power steering unit but i can still hear growling wondering if i got a clog in the steering box to cause excessive action against the power steer unit
there is a definate difference of noise made since the new PS pump but wondering if i should of changed the lines and blew out the PS box ?
smegun is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
