Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer/Ranger Solid Axle Swap Registry
Notices
Explorer/Ranger Solid Axle Swap Registry If you have completed a solid axle swap on your Explorer and would like to share the results with others this is the place to do it:D This isn't the place to talk about a work in progress, rather a place for the FINAL results, specs, instructions etc
Wicked Windsor's D44 Swap
Reply
Thread Tools
Old 02-17-2011, 01:01 PM   #21
bronco2guy
Built not bought.
Columbia, MO
bronco2guy's Avatar
91 Ford Explorer
Vehicle Specs
Very nice setup
bronco2guy is offline   Reply With Quote
Old 02-22-2011, 01:46 AM   #22
mrbird09
San Mateo Calli
1995 Eddie Bauer 4x4
Vehicle Specs
sweep ex bro
mrbird09 is offline   Reply With Quote
Old 02-23-2011, 11:14 AM   #23
chad551
St.Louis, MO
chad551's Avatar
2002 Explorer Sport Trac
Vehicle Specs
Did you have any issues welding your 2" DOM to the Ballistic bushings? From the dimensions I found says the weldable area is 1.85" wide.
__________________
2002 Explorer Sport Trac, SOLD....My SAS Thread
Photobucket Site
My rock slider build
chad551 is offline   Reply With Quote
Old 02-27-2011, 10:07 PM   #24
GoneXplorin
Central Cali
94 sport
Vehicle Specs
Quote:
Originally Posted by WickedWindsor View Post
I've got 4" to the inner C weld and 4 1/4" to the inner C (weld is 1/4" thick.
My Ballistic fab brackets are 3" from outside edge to outside edge wide.
Also to consider, I angled my brackets so the control arms would angle in as they get closer to the frame. I think this is the propper way to mount the brackets. I've seen people mount axle brackets perpendicular to the axle but to me that puts too much side load stress on them.
You can kind of see the angle and where I mounted them here.
As far as rubbing goes, I have slight rubbing at full lock on the lower arms but I am going to install steering stops soon to prevent that.
Lower control arms - 30" bolt eye to bolt eye
Upper control arms - 15.5" bolt eye to bolt eye
Is it 4 1/4" to the inner C on the passenger side and driver side? And what year Waggy shafts did you use? Thanks in advance
GoneXplorin is offline   Reply With Quote
Old 03-26-2011, 11:33 PM   #25
rstangboi
Davis, California
2001 Ranger SAS'ed
Vehicle Specs
any more details on your dodge master cylinder?
like what year and all it was off of?
and the lines really just screwed right in?
__________________
2001 Ford Ranger SAS'ed, 35" Xterrains, d44/d60, detroit/arb.
rstangboi is offline   Reply With Quote
Old 03-28-2012, 07:48 PM   #26
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
Would like to know more about this as well, but seeing has he hasn't replied for a long time, we might not find out more
I cant tell if the line connector sizes are the same or dif than each other on those masters. I was wondering if it would apply to a 2nd gen brake lines or not.
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
