Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
help!
Reply
Thread Tools
Old 01-03-2011, 01:32 PM   #1
chris12491
corbin city new jersey
94' xlt
Vehicle Specs
(Original Poster)
help!
i need some tips on swapping my explorer motors. i have 2 1994 exp. one is wrecked with a good motor. the other motor is shot. i would like to swap the motors but dont really know where to start. can anyone help?
chris12491 is offline   Reply With Quote
Old 01-03-2011, 01:35 PM   #2
chris12491
94' xlt
Vehicle Specs
(Original Poster)
i have all of the lift stuff, the wheels, the 35" tires, i just have to get the motors swapped in order to get this project moving along. ive never done a motor swap before.
Old 01-03-2011, 01:53 PM   #3
wood1
North of Ottawa
wood1's Avatar
'93 XLT, Cayman Green RIP
Vehicle Specs
Hey Chris, do some searches and a lot of reading, getting yourself a Chilton's manual is a good idea... I started out back in the day by getting a few friends together to help out. You must have at least one pal that is capable and willing to work for beer and pizza?
__________________
Ribs. I had ribs for lunch, that's why I'm doing this.
List of useful TTB Threads
wood1 is offline   Reply With Quote
Old 01-03-2011, 02:32 PM   #4
chris12491
94' xlt
Vehicle Specs
(Original Poster)
okay. i have a haynes manual. ive got someone thats willing to help out for free but our schedules never work out. ive done some searches but didnt come up with too much. i could probably remove the motor my self, its just the part of hooking everything back up thats the problem.
Old 01-03-2011, 05:25 PM   #5
wood1
North of Ottawa
wood1's Avatar
Vehicle Specs
digital camera and lots of pictures as you remove and disconnect stuff.
__________________
Old 01-03-2011, 05:54 PM   #6
Pollarican
Wall Township, New Jersey
Pollarican's Avatar
1991 EB 4dr
Vehicle Specs
Chris - It sounds like a crazy in depth endeavor but its really pretty simple. Since both motors are 1994, they are running the same electronics, including sensors, harnesses, and computers (provided they both run auto or both manual transmissions), everything will be plug and play. The connectors that Ford uses are keyed in such a way that only the proper wires coming from each sensor to the harness will fit together, you physically can't mess up connecting most of the sensor wires. As wood1 said above, grab a digital camera and take some pictures of the wiring - you can always fall back on these if you find yourself scratching your head. Personally, I always like to get a roll of painters tape or different colored cable ties, and mark each connector as I take them apart so I know, when its time for re-assembly, what belongs where in terms of wiring.
Following the chiltons or haynes should make the job a lot less complicated than it seems. Off the top of my head, pulling the engine consists of:
1) Unbolt Starter/Transmission bellhousing Bolts
-If Auto, you have to unbolt the Torque converter. You can do this by running a crazy length extension from the front of the vehicle into the starter hole and removing each of the 4 nuts 1 by one, turning the engine crank as you go.
2) Drain All Fluids
3) Disconnect air intake tubes
4) Pull the serp belt
5) Disconnect the AC from the engine bracket
6) Pull the Alternator
7) Remove Power Steering pump/ Connections
8) Unbolt the engine mounts
9) Disconnect all wiring connections that are made to the body harness
10) Remove any vaccum lines, taking a picture of them before you do so will be a huge help
11) Secure a chain or strap to the intake
12) Lift motor and pull towards front of vehicle
You can leave the main engine harness, ignition coil, waterpump/fan, idler pully, intake, and even throttle body attached and still pull the motor.
Hope this helped,
Jeff
__________________
1991 EB - Rolled at 55 MPH...Still drove perfect
1993 EB - The Phase II version of the Rolled 1991
Build in Progress: Cammed 4.0, M5OD-R1HD Swap, 5.5" Skyjacker lift Stage II, F250 Towers, FA600, 3 inch body lift, 35 Inch BFG TA KM2, LimitedSlip Disc 8.8 w/ 4.56's, 4.56 Front w/ E-clip Elim, Circlip Spicer 760s, K&N In, Flowmaster Out, Moog Everything, etc.
Pollarican is offline   Reply With Quote
Old 01-03-2011, 10:17 PM   #7
chris12491
94' xlt
Vehicle Specs
(Original Poster)
thank you guys sooo much. this is a big help. ill be workin on it tomorrow and the next. thanks alot guys.
Old 01-03-2011, 10:29 PM   #8
keithisg
Elizabeth City, North Carolina
1994 Ranger reg cab 4.0
Vehicle Specs
Really interested to see how this goes, keep updated!
keithisg is offline   Reply With Quote
Old 01-04-2011, 03:51 PM   #9
chris12491
94' xlt
Vehicle Specs
(Original Poster)
would it be easier for me to do the body lift first so i have some more room to work with?
Old 01-08-2011, 02:42 PM   #10
92exp4x4
Covington, Kentucky
92exp4x4's Avatar
92 XL 2-door and others
Vehicle Specs
Might as well, I don't like body lifts personally, but they do give you lots of room to work!
You could even jack the body up and roll the chassis out from under it. You are going to have to disconnect nearly everything to do the body lift anyway, so why not if you got the room?
This would make an engine swap cake.
__________________
My stable:
2 doors - '91 Eddie Bauer; '92 XL 5 speed; '92 Sport 2WD 5 speed
4 doors - '91 XLT; '93 XLT; '94 XLT, 6" lift, 33's; '94 Eddie Bauer 5 speed; '94 Limited
Others - '22 Model T, '48 8N tractor, '62 Fairlane 500, '93 F-Superduty 460, '97 F250 Powerstroke, '04 F550 service truck (company owned)
92exp4x4 is online now   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
