Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Fuel Gauge fluctuate
Reply
Thread Tools
Old 01-03-2011, 10:31 PM   #1
MickHoolie
seattle, wa
2000 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Dk Exp Fuel Gauge fluctuate
Greetings All,
I have a 2000 XLS 2WD 4.0L 5-speed with a funky fuel gauge. On 3 occasions over the past year, I have been driving down the interstate with about 3/4 tank of gas and the gauge visibly begins to drop by more than a quarter tank. When I accelerate, the gauge returns to the correct level. This will continue this way for about 30 minutes before resuming normal operations.
The occurances have been months apart. I know how far I can drive on a tank so running out of fuel is not an issue...much. This is just an annoyance.
Has anyone else seen this and/or know what the cause/fix is?
Mick
MickHoolie is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-03-2011, 10:55 PM   #2
BrianDye
I'll have another...
Monroe, MI
BrianDye's Avatar
2006 XLT
Vehicle Specs
Quoted: 77 Post(s)
Sounds like you could have a bad anti-slosh unit. (Dont know much about them, but if I had to guess, I would say thats a good place to start)
Its what basically makes your fuel gauge NOT bounce around while going up/down hills, accellerating/braking etc.
__________________
06 Charcoal Beige XLT
Debadged in back, removed pin stripe, tinted fogs, LED conversion, black headlights w/Morimoto Mini retro, xB LED Halos, black bentley style grille, Tan cloth interior swapped w/black carpet, black leather/power/heated seats from a Limited
BrianDye is offline   Reply With Quote
Old 01-03-2011, 11:09 PM   #3
MickHoolie
seattle, wa
2000 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
I wouldn't say that it bounces, it just slowly drops until I get on the accelerator. When I back off, it begins to slowly drop again. Really, quite odd.
Old 01-03-2011, 11:27 PM   #4
Kevlar7R
Phoenix, AZ
1997 Mountaineer 5.0 4x4
Vehicle Specs
Quoted: 3 Post(s)
Perhaps an electrical issue? Most fuel gauges are a variable resistor, connected to a float. It sends a level signal by varying the voltage coming out. If the voltage going in is fluctuating, the voltage going out will be too. The fact that it picks up when you up the revs (and thereby uping the voltage output of the alternator) lends to this theory as well.
Kevlar7R is offline   Reply With Quote
Old 01-04-2011, 08:41 AM   #5
jmoracco
amarillo
98 explorer4x4
Vehicle Specs
Quoted: 0 Post(s)
Your not alone with this issue, but im sure mine is due to movement of the gasoline on accel and braking. whether it is due to electrical malfunction and or mechanical failure, most likely a new sending/fuel pump unit would be in order. For me I will most likely wait till I need to replace fuel pump, but thats coming from someone who has already spent countless hours and bloody knuckles getting the whole timing components replaced....There is also some really good threads on fuel pump removal and replacement. Good luck
jmoracco is offline   Reply With Quote
Old 01-04-2011, 02:37 PM   #6
AE86PandaDude
Kent, WA
'97 XLT
Vehicle Specs
Quoted: 0 Post(s)
maybe the explorer is saying that its not having fun right now and wants you to step on the gas and haul butt to wherever you are going.....
__________________
My Project Car:
1979 BMW 320-6
to do list: rebuild engine
interior
body damage
AE86PandaDude is offline   Reply With Quote
Old 01-24-2011, 09:31 PM   #7
MickHoolie
seattle, wa
2000 XLS
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
My XLS has this happen only on rare occasions but my sister-in-law has the issue constantly. I will start checking out the anti slosh unit. I'm guessing that is the least expensive piece. Also, I will check the connections.
Thanks for all the input from everyone. I'll let you know what I find.
Old 01-25-2011, 03:08 PM   #8
firepop5
floral park ny
96 EB
Vehicle Specs
Quoted: 4 Post(s)
I have a 96 5.0 V8. I started having this problem several years ago. Since a new fuel pump/sender unit was installed a few months before, (and I didn't want to drop the tank) I assumed the problem was electrical, the gauge or the anti-slosh unit. I went to a junk yard and inquired about an anti-slosh module. They would only sell me an entire cluster. I next went to the dealer and found you cannot buy the module alone, only a kit with a new fuel gauge, the a/s module, a new temp. gauge and a new temp. gauge sender. I was told a/s module and fuel gauge are calibrated to each other and must be changed together. The same for the temp gauge and sender. The kit cost $160. The 2 gauges came attached to a portion for the cluster. Alll went well until I tried to change the temp gauge sender. I cracked the lower intake manifold by cross threading the new sender. I can't post what came out of my mouth then. $800 later for a used manifold installed plus the $160 for the kit, the fuel gauge still acted like it was possessed!
Sorry for the long story, but looking back, I would leave it alone.
About a year later, the gauge started acting normally again!!!
Since then I've read that high sulphur content in certain brands of gasoline can cause a coating to form on the sender and cause the erratic behavior. They recommend several doses of Tech-ron fuel cleaner. I would try this and start buying another brand of gasoline.
firepop5 is offline   Reply With Quote
Reply
Tags
Check fuel gauge operation, fuel gauge
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
