#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Offroad Tech Forums > Offroad Explorer - Ranger Projects > Explorer - Ranger Shocks, Suspensions, Lift Kits
Notices
Explorer - Ranger Shocks, Suspensions, Lift Kits Ford Explorer and Ranger chassis related posts. Get help choosing the right shock absorber and aftermarket suspension for your Explorer or Ranger based vehicle.
Long-Travel Suspension
Reply
Thread Tools
Old 06-04-2001, 11:19 PM   #1
BislamJoe
Texarkana Texas
1993 Explorer 4x4 XLT
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
[EDIT: I'm bumping this thread back up - it's got a lot of good information in it.]
I need longer legs on my truck. I don't want to lift it, at least not much. I'm thinking about the Duff 2.5" but if I can get the travel I want without lifting, that's how I'll do it. I'm keeping the TTB, and none of you solid-axle guys can change my mind on that. I'm going for travel, not articulation. I've thought about having coils and leaf packs made by National Spring, finding some drop brackets giving a 2" lift, beefing those up in an unabashed display of pure redneckedness, then fabbing dual shocks for the front, and topping it off with dual rear shocks. For the dual rear shocks, is there any way to mount them both behind the axle? I'm thinking of a dual fuel tank conversion, moving my muffler to the spare tire hole, mounting the spare on the roof or rear bumper. I'm also planning a V8 conversion. Any thoughts?
__________________
David Nash
"Can ya hear me now?"
BislamJoe is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-05-2001, 04:47 AM   #2
Clint
Mesa ,AZ
91 sport
Vehicle Specs
Quoted: 0 Post(s)
u mind tellin me the diff between articulation and wheel travel............u really can't have one without the other
duff makes a good kit and if u don't want to go to high u can't beat 2 1/2 inches but u should probably go with the duff kit minus the coils and get some made by national for lift of about 3 1/2 inches of lift with a 300-350 pound spring rate(don't worry with this spring rate you will settle at 2.5-3") and then to allow the tires to travel without tasteing your wheel well look into a set of perrys fenders at www.perrysfabnfiber.com. for the rear i would go for the zimm spring mod and some warrior shackles to allow the spring to flatten out more.....then u should have a great flexible rig.....while your at it buy the dual shock kit from duff
__________________
7" of total susp. lift .... 33's blah blah blah
Clint is offline   Reply With Quote
Old 06-05-2001, 11:09 AM   #3
Randall
Demon4x4 Member
Mo. City, TX
Randall's Avatar
1991 Demon Edition
Vehicle Specs
Quoted: 12 Post(s)
One question about the Zimm mod. I assume that you leave all of the explorer's original leaves with the stock clamps attached, is the extra ranger leaf left loose? Or do you clamp them together somehow while on the street and unbind them for offroad? Or is it just clamped in with the rest of the Explorer leaves permanently?
__________________
KF5ZXT
Demon4x4.com
1991 1-ton Exploder
2000 Ford F-250 PSD
Blue Ribbon Coalition Lifetime Member
Randall is offline   Reply With Quote
Old 06-05-2001, 05:25 PM   #4
BislamJoe
Texarkana Texas
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
articulation is like rock-crawling wheel movement. with a solid axle, for example, one wheel reaches down as the other remains still, but the body/frame lowers itself relative to the stationary wheel. By travel i mean simple vertical travel of individual wheels.
__________________
David Nash
Old 06-05-2001, 06:03 PM   #5
Clint
Mesa ,AZ
91 sport
Vehicle Specs
Quoted: 0 Post(s)
whore my springs aren't clamped(that's what gives it so much flex the spring seperation) but i do have a ubolt welded to the load spring so the springs won't misalign.........Joe i understand the definition but u still can't have one without the other ...if u have good functional wheel travel if u have good articulation but anyway what are u planning on doing suspension whise
__________________
Old 06-05-2001, 06:47 PM   #6
Randall
Demon4x4 Member
Mo. City, TX
Randall's Avatar
1991 Demon Edition
Vehicle Specs
Quoted: 12 Post(s)
Do you have a pic of the welded area? since you ride with the leaves loose at all times, how does it handle on the road? Is it bouncy as hell or what?
__________________
KF5ZXT
Demon4x4.com
1991 1-ton Exploder
2000 Ford F-250 PSD
Old 06-06-2001, 02:43 PM   #7
CHH777
Once...
Houston, TX
CHH777's Avatar
1994 Mazda Navajo LX 4x4
Vehicle Specs
Quoted: 0 Post(s)
I'd like to see a pic too. When I do some hard wheeling my overload springs twist inward and the driver side hits the gas tank skid plate.
CHH777 is offline   Reply With Quote
Old 06-06-2001, 07:25 PM   #8
FROADER
Moderator
Huntington Beach, CA
FROADER's Avatar
2010
Vehicle Specs
Quoted: 61 Post(s)
You should take out the overload springs in the first place. Those are limiting some of your travel right there. It will also ride a little better on the road too with them out.
FROADER is offline   Reply With Quote
Old 06-06-2001, 09:31 PM   #9
Clint
Mesa ,AZ
91 sport
Vehicle Specs
Quoted: 0 Post(s)
i can't remove mine i still tow a boat and other stuff
__________________
Old 06-07-2001, 12:05 PM   #10
BislamJoe
Texarkana Texas
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
i don't rockcrawl, i'm looking for the kind of performance you see in desert racers and prerunners. i don't exactly desert run, but i tend to approach off-road trails with tactics best described as "stupid-crazy-redneck-fast" and enjoy high-speed off-road races over large open fields. i'm avoiding lift to keep my c.o.g. as low as i can. i'm willing to trim as much as i need to, including moving things around in the fenderwell, so tire clearance is only a concern at full-lock. i want to run at least 33's, maybe 35's if that won't be too much trouble. i figured wheel spacers would help solve the full-lock rub problem, but i read in another thread that they put a lot of stress on your drivetrain. are there any other ways to increase my front track width without a solid axle? i can swap in a full-width or slightly narrowed axle in the rear; i'll probably go ahead and step up to a 9-inch if that becomes necessary.
__________________
David Nash
Old 06-07-2001, 12:52 PM   #11
CHH777
Once...
Houston, TX
CHH777's Avatar
Vehicle Specs
Quoted: 0 Post(s)
Fender,
I had them removed at one point but the rear began to sag. I have a Navajo which only has two rear leafs plus the overload. Do 91-94 Explorer Sports have a 4-leaf spring pack?
Old 06-07-2001, 01:10 PM   #12
sirhk100
las vegas
'91
Vehicle Specs
Quoted: 67 Post(s)
There are a couple of Fab shops around SoCal that can make widened TTB for up front. Some are widened by as much as 4" per side. Running those along with fiberglass flared fenders and extended radius arms and you'll have a lot of travel with no clearance issues.
sirhk100 is online now   Reply With Quote
Old 06-07-2001, 03:14 PM   #13
FROADER
Moderator
FROADER's Avatar
2010
Vehicle Specs
Quoted: 61 Post(s)
BislamJoe-
I think I have the lowest X on this site with 35s. I too drive as fast as my X will let me whenever I get the chance. It actually doesn't go fast enough for me. I chased for Bob Gordon for a couple years. Anyway, I don't think you're going to get 35s on your truck without lifting it, unless you are ready to cut your inner wells completely away and if you're going to tub the back. You can't really cut too much in the back unless you tub it back there. Eventually, mine will have 4 link int he rear with a 9" and widend about 3 or 4 inches per side in the front. I'm looking to be done with everything in about 2 years.
CHH77-
I'm not sure about the leaf pack in the Sport
CMartin91-
I hear ya
Old 06-07-2001, 04:44 PM   #14
CHH777
Once...
Houston, TX
CHH777's Avatar
Vehicle Specs
Quoted: 0 Post(s)
Fender,
Did you put any flares on the back to match your front fenders?
Old 06-07-2001, 06:34 PM   #15
BislamJoe
Texarkana Texas
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
that's what i was thinking - a widened TTB with long radius arms. you have a website for any of those shops? or better yet, a way to get plans or something to do it myself or have it done locally. i know the Zimmermans built radius arms, so i'm planning to build mine as well. i also thought about swapping in a Dana 44, Dana 44HD or Dana 50 TTB from a full-size f-truck. I'm not sure how tough that would be though. as for the rear, is a full-width 9-inch a tough swap? would a full-width 8.8 be easier?
__________________
David Nash
Old 06-07-2001, 06:44 PM   #16
Pendarus
Fullerton Ca.
94 4X4 XLT 4 Door
Vehicle Specs
Quoted: 0 Post(s)
Exclamation
Try Baja Concepts in San Diego.
www.bajaconcepts.com
They carry a full line of Explorer 4X4 mods for prerunning.
__________________
I'd rather be lucky than good....Luck covers stuff good just won't handle!
Pendarus is offline   Reply With Quote
Old 06-07-2001, 06:50 PM   #17
Clint
Mesa ,AZ
91 sport
Vehicle Specs
Quoted: 0 Post(s)
ok i get what your saying u want wheel travel but a stiff wheel travel "no sway"have u checked out camburg www.camburg.com go under what's new and look under xtreme explorer .....the full width 8.8 isn't going to be any easier than a 9 so go with a 9 or leave it alone ....sorry guys i don't have a pic
__________________
Old 06-07-2001, 07:08 PM   #18
sirhk100
las vegas
'91
Vehicle Specs
Quoted: 67 Post(s)
Also check
McNeil Racing
Perry can also do it!
AutoFab
Old 06-07-2001, 07:17 PM   #19
tdavis
Linux Guru
Jack of All Trades
Pinole, CA
tdavis's Avatar
2001 F250/XLT Superduty
Vehicle Specs
Quoted: 35 Post(s)
Quote:
Originally posted by CHH777
Fender,
yes. and 4door leaf packs fit on a 2dr.
I know. I've got EMU on mine now. And they was made for a 4door.
__________________
Thomas Davis
Chased vehicle -> Honda VFR800
Tow vehicle -> Ford F250 Superduty
Frankenstein Rock Crawler - > Suzuki Samurai (sold, onto the next project..)
tdavis is offline   Reply With Quote
Old 06-07-2001, 08:39 PM   #20
BislamJoe
Texarkana Texas
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thanks guys! I've e-mailed Camburg to see if I can get widened TTB parts. Probably 4" per side should do it, right? to clear 33's at full lock at least? I'm still listening to any suggestions you guys can throw at me, just try to remember, I'm going kinda for the low-rider with big-honking tires! lol
__________________
David Nash
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
