#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
My door doesn't close. The latch is stuck in the closed position.
Reply
Thread Tools
Old 01-07-2011, 06:14 PM   #1
jmac0017
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
hey guys need your help.
i have a 2004 explorer 4x4
passenger door will not close
the pin the door is locked in the up postion not allowing the door to close.
happen once before was able to push it back into place with a screw driver.
(beginning of winter)
washed the vehicle yesterday when we finally had reached +1 C.
today blizzard like conditions.
screwdriver not working today.
Anyone know any tricks to get the pin back into the correct postion.
your help would be greatly appreciated.
jmac0017 is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-07-2011, 07:55 PM   #2
A Wise Guy
McHenry, IL.
'06 Limited Dark Cherry
Vehicle Specs
Quoted: 0 Post(s)
Just checking the obvious here. When you are trying to reset the latch in the door open position you are lifting the door handle in order to allow the latch to open right?
__________________
'06 Limited V8 Style
K&N 77 Series Metal Intake, Magnaflow Cat Back, X-Cal 2, Tint up front...
Searching and Posting starts here: http://www.albinoblacksheep.com/flash/posting
A Wise Guy is offline   Reply With Quote
Old 01-09-2011, 01:25 PM   #3
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've renamed your thread, and moved it into the stock 2002-2005 section. Unlock the door, and either lift the handle as previously suggested or pull on the inside handle while manually moving the latch to the open position.
BrooklynBay is offline   Reply With Quote
Old 01-09-2011, 07:34 PM   #4
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
If it is frozen, you might be able to thaw it out with a hair dryer or a heat gun.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 01-10-2011, 01:04 AM   #5
alexk
New Jersey
15 Sport
Vehicle Specs
Quoted: 27 Post(s)
This happened to my hatch when I had my explorer. It was frozen in the open position and wouldnt close. I took the steam cleaner to it and a few minutes later the came free. If something is causing it to stick the steamer might free up something too.
__________________
Current Explorer: 2015 Sport White platinum 401a with dual panel roof.
Former Explorer's
2002 XLT 4x4 V8
2013 XLT 4x4
alexk is online now   Reply With Quote
Old 01-12-2011, 10:49 PM   #6
jk7294
Indiana
2002 Limited V8
Vehicle Specs
Quoted: 0 Post(s)
Same happened to me, I just had to cycle the manual lock a few times and the handle and it worked.
jk7294 is offline   Reply With Quote
Old 02-24-2011, 12:27 AM   #7
jmac0017
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Thank you
where are my manners...
Thanks guys for your help.
Old 02-24-2011, 10:29 AM   #8
Jorgen
Bloomfield Hills, MI
'05 S4, '04 Explorer
Vehicle Specs
Quoted: 1 Post(s)
Quote:
This is exactly what I have done before, get a screw drive on the latch portion put a little pressure and pull the handle should open right up and be able to close properly.
__________________
1969 Triumph Spitfire [Toy/Project]
2005 Audi S4 4.2l V8 6-speed quattro[Daily Driver]
2004 Explorer XLT, 4.0 OHC, Auto, Fully Loaded [Wife's Daily Driver]
1998 Explorer Sport, 4.0 SOHC, Auto 190k [RIP Old Girl]
Jorgen is offline   Reply With Quote
Old 02-24-2011, 06:42 PM   #9
stuartr
Richlands, VA
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 1 Post(s)
Mine is really bad to do this in the cold. I try to keep de-icer for this. Works great for me.
STU
__________________
Mountianeer family I have a 2002 and she has a 2008. Both AWD V6.
stuartr is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
