EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Diagram of the front differential.
Reply
Thread Tools
Old 01-07-2011, 05:29 PM   #1
acwdrw
CT
'99 XLT
Vehicle Specs
(Original Poster)
Hi, I have a 1999 Ford Explorer XLT 5.0L 4WD with a whining noise in the front end, I have changed the front driver's side hub assembly and the fluids in the front differentail and transfer case. I will be changing the passenger side hub next, but would like to look at a diagram of the front differential if anyone has access to one.
acwdrw is offline   Reply With Quote
Old 01-07-2011, 08:10 PM   #2
ncranchero
Sport Trac Moderator
Denver,NC
ncranchero's Avatar
Truckin' on Pat & Charlie
Vehicle Specs
Item Description
1 Differential Housing
2 Vent tube
3 Differential drive pinion bearing cup (2 req'd)
4 Differential pinion bearing (2 req'd)
5 Front axle drive pinion shaft oil slinger
6 Pinion seal
7 Drive pinion oil seal deflector
8 Pinion flange
9 Pinion nut
10 Bushing (2 req'd)
11 Axle to frame bracket
12 Bushing
13 Axle bracket to housing bolt (3 req'd)
14 Fill plug
15 Axle shaft oil seal (LH)
16 Axle shaft bearing
17 Oil restrictor plate (baffle)
18 Collapsible spacer
19 Pinion position shim
20 Differential case
21 Differential ring gear and pinion
22 Differential pinion shaft roll pin
23 Differential ring gear bolt (8 req'd)
24 Differential housing cover
25 Differential cover bolts (10 req'd)
26 Differential bearing cap (part of 3010)
27 Differential preload/backlash shim
28 Differential bearing cap bolt (4 req'd)
29 Differential bearing
30 Differential bearing race
31 Differential pinion shaft
32 Differential pinion thrust washer (2 req'd)
33 Differential side gear thrust washer (2 req'd)
34 Differential side gear (2 req'd)
35 Differential pinion gear (2 req'd)
__________________
Steve,
2010 Transit CONNECT 145K miles, 2002 Sport Trac 4x4 SOLD
2000 Taurus SES 3.0L 24 Valve DOHC Duratec 87K miles
1994 F150 4x4 4.9L/5-speed 160K miles,
1995 Ranger 2.3L/5-sp/3.73 75K miles "Plain Jane"
How to post photos
ncranchero is offline   Reply With Quote
Old 01-07-2011, 08:14 PM   #3
acwdrw
CT
'99 XLT
Vehicle Specs
(Original Poster)
Yes, I am considering rebuilding
Old 01-07-2011, 08:22 PM   #4
ncranchero
Denver,NC
ncranchero's Avatar
Vehicle Specs
Check out the Ranger Station Tech section.
__________________
Steve,
How to post photos
Old 01-08-2011, 07:23 PM   #5
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the transmissions, transfer cases, and differentials section.
BrooklynBay is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
