Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Help - 94 Explorer EEC Fuses keep blowing - Tried most options
Reply
Thread Tools
Old 01-12-2011, 02:02 PM   #1
xSnoWx
BC
91 XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
CAN Help - 94 Explorer EEC Fuses keep blowing - Tried most options
94 Explorer was picked up, died on the way home, got it towed home and found that the EEC Fuse was blown-replaced it, ran good for about 4 months, blew the EEC fuse again after the 4 months-replaced fuse-blew it instantly, kept blowing fuses, searched the threads-tried unplugging the trans harness (3wire) no change, removed all relays from the fuse box-kept blowing.
So unplugged the wiring in the frame rail (For the pump?) stopped blowing fuses when cranking over, so replaced the fuel pump last weekend, started right up, ran good for 4days, then was driving back, stopped running-checked it-blown EEC fuse again, got it home, searched the thread some more, replaced Fuel pump relay and EEC Relay, replaced fuse again-still blowing fuses, anyone have any idea where to look to next ... is driving me crazy. The only next thing I was going to move onto would be fuel pump harness in frame rail?? ANY Help would be appreciated
xSnoWx is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-12-2011, 09:25 PM   #2
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
Vehicle Specs
Quoted: 10 Post(s)
The EEC relay doesn't really protect the fuel pump circuit -- the fuel pump circuit has its own fuse.
If you've removed the EEC relay and it still blew the fuse, that suggests to me that the short to ground is in between the fuse and the relay. I'd get a wiring diagram and see just how much there is between the fuse and the relay (if memory serves, there isn't much, and it might all be inside/underneath the power distribution box) -- then focus on that part of the circuit.
__________________
Mr. Shorty
92 XLT 4x4
87 Bronco II XLT 4x4
'98 Chev K1500 Suburban SLT 4x4
MrShorty is offline   Reply With Quote
Old 01-13-2011, 10:17 AM   #3
xSnoWx
BC
91 XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
EEC Relay was the only one left in the system, fuel pump relay was removed still popped the fuse ... will try pulling the fuse box I guess
Old 01-17-2011, 03:46 PM   #4
xSnoWx
BC
91 XL
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Update: Harness rubbed through on EGR Tube, repaired one damaged wire and resecured out of the way-starts up fine
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
