Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood
Notices
Under the Hood Ford Explorer and Ranger, Engine, troubleshooting, modifications, performance and accessories.
Depressurize the fuel system?
Reply
Thread Tools
Old 06-06-2001, 01:18 PM   #1
redhat
burke, va
96 eb
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Question Depressurize the fuel system?
What is the quickest and easiest way to depressurize the fuel system - in preps for fuel filter replacement?
Thanks.
redhat is offline   Reply With Quote
( Join the Elite Explorers )
Old 06-06-2001, 01:28 PM   #2
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
With the ignition off, either pump the gas pedal a couple of times (you'll have to wait a while before you starta it again to let the gas clear afterwards) or depress the schrader valve on the fuel rails (it's the same type of valve as you have on your tires). The second is the recommended way.
__________________
Moderator..Home Improvement/Explorer 911/2011 Explorer Forum
You took my breath away....and now I want it back....
'66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT
"Ex"plorer's: '92 Sport, '94 Sport, '01 XLS
Our Crappy Website
JDraper is offline   Reply With Quote
Old 06-06-2001, 01:36 PM   #3
redhat
burke, va
96 eb
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
JDraper - thanks for the help.
Old 06-06-2001, 01:47 PM   #4
JoeC5
n/a
93 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Do you have to depressurize the fuel system before you change fuel filters?? I usually just get underneath the truck and change it right out with no problems at all.
JoeC5 is offline   Reply With Quote
Old 06-06-2001, 01:47 PM   #5
CHH777
Once...
Houston, TX
CHH777's Avatar
1994 Mazda Navajo LX 4x4
Vehicle Specs
Quoted: 0 Post(s)
I just trip the rollover safety shutoff switch and run the engine till it dies...
CHH777 is offline   Reply With Quote
Old 06-06-2001, 01:55 PM   #6
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Quoted: 0 Post(s)
Quote:
On a fuel injected engine, pumping the gas pedal shouldn't work. As long as the ignition is off, the fuel injectors aren't injecting any fuel. The only thing the pedal does is open up the throttle body butterfly to allow more air in. The computer then injects the fuel in response to the opening of the throttle body.
I don't know about the second suggestion either. It wasn't in the Service Manual. What was in the service manual was installing a vacuum pump to the valve and using it to bleed off the pressure. An alternate method was to start the vehicle, and pull the connector off the top of the fuel shut-off switch and run it until it dies (a few minutes). That is the method I used when replacing my fuel filter on my '97 and it worked very easily.
__________________
4.56 Powertrax No-Slip, SOHC V6, SuperChip, K&N FIPK (#57-2513-1), Borla cat-back (#14748), 2" torsion lift, 3" PA body lift (#853), Monroe Reflex shocks, 285 75R16 BF Goodrich T/A ko, 2WD mod
Earnhardt Ford, Berge Ford, U-Haul
My Explorer
Robert is offline   Reply With Quote
Old 06-06-2001, 01:57 PM   #7
Robert
Mesa, AZ
'97 4x4 Sport
Vehicle Specs
Quoted: 0 Post(s)
Re: Depressurize the fuel system?
Quote:
Thanks.
Another quick suggestion is to make sure you have the quick disconnect tool before starting the replacement. It sucks to fight and pull on the lines, get one off and find out about the quick disconnects. You will then be looking for another vehicle to drive up to the auto parts store for the $5 tool.
__________________
My Explorer
Old 06-06-2001, 01:59 PM   #8
JoeC5
n/a
93 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
Yeah, but do you have to depressurize the system?
Old 06-06-2001, 02:00 PM   #9
JDraper
Somewhat Functional
McVeytown, PA
JDraper's Avatar
'11 XLT
Vehicle Specs
Quoted: 30 Post(s)
Brain Fart on suggestion #1. To much time with Quadrajets and 4150's!!! As for the second, that's what my Haynes manual suggested for pressure relief. Tripping the cutoff switch and running it till it dies (suggested above) does the trick too.
You should depressurize the system first so you don't spray fuel all over the place. The system pressure runs 35-45 psi (from memory, I don't have the manual handy). If you pop the filter connectors loose at pressure, you'll have fuel everywhere.
__________________
Our Crappy Website
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
