#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Any other power issues besides the alternator ?
Reply
Thread Tools
Old 01-12-2011, 10:24 PM   #1
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I'm working on the 2000. Everything points to a bad alternator but I want to rule out other options before I get one. The car dies as soon as I disconnect the battery cable and its basically running off battery. It loses a .01V every few seconds when running and drops quite a bit when the lights turn on.
I wonder if a lose belt could be it ? My belt is squeaking and seems loose.
__________________
'96 XLT 4DR <<< RETIRED
'00 Sport 2DR
Signature modified by Moderator
G-96XLT is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-12-2011, 11:01 PM   #2
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 115 Post(s)
Unlikely for a serpentine belt to slip, unless the tensioner is broken, in which case the belt would likely have fell off the water pump pulley, if not all the other pulleys.
A properly operating alternator supplies ALL the electrical power used in the vehicle AFTER the battery starts the engine. imp
imp is offline   Reply With Quote
Old 01-12-2011, 11:06 PM   #3
2TimingTom
Highlands Ranch, Colorado
2TimingTom's Avatar
'97 XLT
Vehicle Specs
Quoted: 232 Post(s)
With the alternator hooked up and the engine idling, what voltage do you have across the battery terminals? It should be around 13.6ish to 14.4.
__________________
1997 XLT SOHC: SAS/SOA
Explorer registry
Also in the garage: 2012 Escape Limited 4wd V6 AND 2000 Expedition Eddie Bauer 5.4L AWD- registry
Modified RBVs
2TimingTom is online now   Reply With Quote
Old 01-13-2011, 12:58 AM   #4
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
The voltage is around 11 and dropping. I know its running off the battery. I'm just wondering if it could be anything else besides the alt. I switched around some relays and took another reading and still 11v and going down. Turning the lights on brings it down to about 10.5v.
The belt was actually loose. I raised the alternator by a couple of washers and it got a little tighter and the squealing is gone, however alternator still seems busted.
__________________
'00 Sport 2DR
Old 01-13-2011, 03:26 AM   #5
Spdrcer34
Bremerton, WA
1992 Explorer XL
Vehicle Specs
Quoted: 10 Post(s)
Can it be something else.....sure......
But the only that it can be is INSIDE the alternator....such as the voltage regulator....
Just change the alternator. And your problem will be solved.
BUT BEFORE YOU DO THAT, CHARGE YOUR BATTERY BACK UP TO 100% using a battery charger.
Failure to do so will result in another bad alternator, AND battery.
Ryan
__________________
1992 Ford Explorer XL - with a few bolt ons...
Spdrcer34 is offline   Reply With Quote
Old 01-13-2011, 07:39 AM   #6
ranger7ltr
Great State of Texas
1999 Sport
Vehicle Specs
Quoted: 31 Post(s)
Before changing the alternator...
I would check for any voltage at the wire that supplies battery voltage to the alternator...If there is no voltage there, the 175 amp mega fuse is blown...
And I would recommend not removing the battery cables while running to test the alternator output...While it does work, it will remove the battery from the system and the if the alternator is working, the system voltage could spike and kill any number of electronic components...
When you remove the alternator and have it tested, if it shows to be shorted internally, still check the mega fuse for continuity...Alternators have been known to kill that fuse as well as themselves...
__________________
When in doubt, use a bigger hammer!
2014 Jeep Compass Limited [Company Vehicle]
2003 Ford F-150 XLT Supercab
1999 Ford Explorer Sport [new playtoy]
1983 Ford Ranger V8 [soon to be gone]
ranger7ltr is offline   Reply With Quote
Old 01-13-2011, 10:19 AM   #7
rego
Mn
98xlt,2000xlt both ohv 6
Vehicle Specs
Quoted: 6 Post(s)
Does the battery icon light up with the key in the on position and motor not running? The icon is just above the speedometer needle.
rego is offline   Reply With Quote
Old 01-13-2011, 12:19 PM   #8
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I don't know where this 175 amp mega fuse is located. Can anyone help me. is it in the box under the hood ?
I'll check for the battery light as well. There is enough juice to start the car so the battery can't be that bad.
__________________
'00 Sport 2DR
Old 01-13-2011, 12:27 PM   #9
rego
Mn
Vehicle Specs
Quoted: 6 Post(s)
Checking the battery light is not to check battery condition. The light will help verify a circuit. The mega fuse is next to the fuse/relay box.
Old 01-13-2011, 12:50 PM   #10
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
Quoted: 1 Post(s)
Quote:
Originally Posted by ranger7ltr View Post
And I would recommend not removing the battery cables while running to test the alternator output...the system voltage [will] spike and kill any number of electronic components...
I second that. Now that alternators have solid state voltage regulators that is a bad practice. It sounds like one of the diode sets has failed inside the alternator. Get a replacement with a lifetime warranty if you can, and make sure the battery is charged before installing it. Here is a site with some decent troubleshooting information although it seems you have already narrowed it down: Link
__________________
There is wisdom to be found in the counsel of many.
OneLever is offline   Reply With Quote
Old 01-13-2011, 12:53 PM   #11
1AJeremyD
Mass
95 XLT 4.0
Vehicle Specs
Quoted: 0 Post(s)
Sounds like the diodes are cooked and the brushes inside are damaged. Changing the alternator is definitely the issue. The belt being loose probably made the bearings inside ride differently than intended and broke the brushes
__________________
Jeremy
1A Auto
888-844-3393
Shop for Ford Explorer Parts
1AJeremyD is offline   Reply With Quote
Old 01-13-2011, 02:07 PM   #12
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I'm 90% sure its the ALT but I still want to check a few things.
I want to find this mega fuse and check the # 15 fuse and check the air bag and battery light bulbs in the dash. I just read that the 2000 explorer could suffer a no charge problem from these.
I'll let you guys know in 2 hrs.
__________________
'00 Sport 2DR
Old 01-13-2011, 03:02 PM   #13
ranger7ltr
1999 Sport
Vehicle Specs
Quoted: 31 Post(s)
Pic of mega fuse...
Look at the picture...The underhood relay/fuse panel is in the upper right and on the passenger side of the relay/fuse box under a little cover[COVER IS OPEN HERE] is the mega fuse...
The mega fuse is attached to the posts with the battery cables under them...
__________________
Old 01-13-2011, 03:07 PM   #14
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
Hey rego I have an interesting problem. The battery light on the dash doesn't come on. I even hooked up a booster pack so there is good power.
I tried turning the key about 20 times, once it came on faintly, so I took it apart and put in a bulb from the fuel reset light and still nothing, so good bulb but no light when I turn the key to ON.
__________________
'00 Sport 2DR
Old 01-13-2011, 03:08 PM   #15
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I hate mega fuses, one blew on my booster pack and they can't be found anywhere. I'm currently using a door key as a mega fuse.
__________________
'00 Sport 2DR
Old 01-13-2011, 03:29 PM   #16
ranger7ltr
1999 Sport
Vehicle Specs
Quoted: 31 Post(s)
Here is where I get my megafuses from...
https://www.vtewarehouse.com/content...a/megafuse.php
And their prices are really good... Plus there is also ebay....
__________________
Old 01-13-2011, 03:50 PM   #17
windsors03cobra
Racine WI
99 5.0 AWD EB
Vehicle Specs
Quoted: 0 Post(s)
I lost an alternator on my 03 Cobra a couple years back and the battery light never came on.
Just replaced Dads alt on his 90 F150, 3 month old Napa alt, tested and dead, no battery light there either and I'm sure it has a light in addition to the voltmeter. What I'm saying is dont loook for or use the battery light as a troubleshooting item, seemed like GM was able to make them work but I dunno about Ford. Exploder voltmeter/gauges are worthless as tits on a bull.
Only other bad thing in some cases could be the alt pigtail, easy to check with a VOM for a trigger wire turning on.
windsors03cobra is offline   Reply With Quote
Old 01-13-2011, 04:38 PM   #18
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
Quoted: 1 Post(s)
(Original Poster)
I found the mega fuse. thanks. It seems to be ok, It was a little rusty but I cleaned it up and it had continuity.
It looks like it will be the ALT. I checked and changed around the bulbs, tightened the #15 fuse by bending it and checked all other fuses.
__________________
'00 Sport 2DR
Old 01-13-2011, 04:59 PM   #19
1AJeremyD
Mass
95 XLT 4.0
Vehicle Specs
Quoted: 0 Post(s)
Change the tensioner while you are at it if you haven't done so recently. Having a bad belt and tensioner will just screw up the alternator again.
__________________
Jeremy
1A Auto
888-844-3393
Old 01-14-2011, 11:56 AM   #20
rego
Mn
Vehicle Specs
Quoted: 6 Post(s)
Reread post#6. You must have battery voltage to the alternator or it will not charge. I got my readings at the alternator. You can poke the probe through the rubber boot. I can't remember if the motor has to be running but I believe the key must be at least in the on position. I don't think you will find battery voltage because you have no icon.The seatbelt icon may be involved in this circuit. It is just under the speedometer needle. As a last resort before I found my loose fitting #15 fuse problem, I was ready to run battery voltage directly to the correct lead on the alternator to see if it would then put 14+ volts out. I'm not saying that is a good idea, but but I was about at my wits end.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
