Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
How do I adjust the engine idle speed?
Reply
Thread Tools
Old 01-15-2011, 02:53 PM   #1
arterbery
2002 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
have 2002 Mercury Mountaineer have cleaned MAF and replaced air filter engine fault lights have cleared but engine has high idle speed how do I adjust?
arterbery is offline   Reply With Quote
( Join the Elite Explorers )
Old 01-15-2011, 10:17 PM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 415 Post(s)
Welcome to this forum! I've moved your thread into the stock 2002-2005 section. Don't play with the set screw adjustment. You might have a vacuum leak or a bad IAC. What were the previous code numbers?
BrooklynBay is offline   Reply With Quote
Old 01-17-2011, 07:29 AM   #3
matt0248
Chicago
02 XLT V8
Vehicle Specs
Quoted: 1 Post(s)
Check for a binding or sticking throttle body. Also, my X had a high idle when it got hot. The hotter the engine got the higher the idle speed. I ended up replacing the IAC with one from Autozone (needed one fast, otherwise I woudl have gotten a motorcraft one). Problem went away.
matt0248 is offline   Reply With Quote
Old 01-17-2011, 11:26 AM   #4
SuRrEaLNJ
hail to the king, baby!
out of my mind...
SuRrEaLNJ's Avatar
MUNK 07 Focus 97 XL1200C
Vehicle Specs
Quoted: 2 Post(s)
you don't, its all computer controlled
I notice u said cleared fault lights, what were the codes?
__________________
Quote:
Originally Posted by Spas View Post
You are all lunatics, and Jay is your king!
BEN REALLY REALLY LOVES PINK
SuRrEaLNJ loves Hannah Montana
SuRrEaLNJ is offline   Reply With Quote
Old 01-17-2011, 06:40 PM   #5
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
Double ck the throttle cable, sometimes they wear and stick, closely inspect it down at the gas pedal.
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 01-17-2011, 08:16 PM   #6
EasyRhino
Kailua, Hawai'i
'02 Limited 4.6L 4x4
Vehicle Specs
Quoted: 0 Post(s)
What is the idle speed as indicated by your tachometer?
It is true that there is no idle screw adjustment, as it is computer controlled.
__________________
Wife's: '02 Limited 4.6L/4x4
Mine: '04 Mustang GT Vert, 2006 C6 Corvette Coupe
EasyRhino is offline   Reply With Quote
Old 01-17-2011, 08:58 PM   #7
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quoted: 122 Post(s)
Quote:
Curious when did they go to drive by wire? Thanks. imp
imp is offline   Reply With Quote
Old 01-17-2011, 10:03 PM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 415 Post(s)
Quote:
Originally Posted by imp View Post
curious when did they go to drive by wire? Thanks. Imp
2004.
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
