So a 95 with or without portion valve?
Without a proportioning valve. The valve is located on the drivers side frame rail on these rigs. If you removed it you will need one with the proportioning valve, if you do need one that you will want to call Centric, ask for Bryan, he will be able to tell you what you need.
Here is my old post: (Follow it and you will be golden, you will need to plug the front ABS outlet on the MC if you dont have front ABS, I didn't, use brass plug)
Yesterday I spoke with a technician at Centric Parts (large brake component manuf.) and I told him what I had done, rear-end swap to 4.10 LSD and disc brakes, from 1999 Explorer, and that I was having rear bias issues, essentially brakes were dragging/binding up in the rear. He told me that this is due to preloaded hydraulic pressure that is present in disc/drum master cylinders. This allows the drum brake to do what it is supposed to once the brake pedal is engaged, without it, the timing of the rears in relation to the fronts would be out of sync.
He advised me to swap out the stock master (1991) for a 1995 Explorer master cylinder (part # 130.65044 w/cruise control or # 130.65043 w/o cruise control). Since I have cruise I went with the 130.65044.
