Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Odd noise in 1-2-early 3rd on 4.6 AWD Monty
Reply
Thread Tools
Old 01-20-2011, 04:22 PM   #1
2002GreyHD150
DFW, Texas
2004 Mountaineer 4.6L AWD
Vehicle Specs
(Original Poster)
hello all.
I have been getting a random ABS Light, which I know is the driver's bearing/hub going south. I replaced the Passenger front this time last year. New code is "driver's ABS sensor" the bearing is failing, giving a faulty ABS tracking to the ABS computer. No biggie.. an hour, 2 beers.. done deal.
However, just yesterday a new noise started. Comes from the engine "area" not centralized or localized Left or Right. Best description is classic Pushrod V8 Lifter noise. Clicking... BUT its ONLY when the truck is fully warmed up, and 1st -2nd & easing into the 3rd gear shift. It is "rotational" & porportional to RPM.
If the truck is in nuetral, rev all you want, no clicking. So either it is a load dependent internal engine issue (chain slap?) or is movement dependent, I am wondering if the bearing is so far gone that the bearings inside the casing are slapping each other once warmed up?
Any thoughts?
Rob
2002GreyHD150 is offline   Reply With Quote
Old 01-26-2011, 10:27 PM   #2
2002GreyHD150
DFW, Texas
Vehicle Specs
(Original Poster)
bump for Resident Ford Tech or anyone ?
thanks!
Rob
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
