| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2013 Ford Explorer problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Elite Garage Builder
McVeytown, PA
'11 XLT
2011 Ford Explorer Specifications
I wanted to start a thread with all the specifications I could find for the '11 Explorer. I'll be adding to it as I find them. If anyone finds any other specs or sees a mistake, please let me know and I'll edit this post.
Link to Model Comparison 2011 Explorer Specifications: Exterior Dimensions Wheelbase [in] 112.6 Length [in] 197.1 Height [in] 70.4 Width - Excluding Mirrors [in] 78.9 Width - Including Mirrors [in] 90.2 Width - Mirrors Folded [in] 82.5 Front Track [in] 67 Rear Track [in] 67 Front Overhang [in] 38 Rear Overhang [in] 46.5 Approach Angle [deg] 21.7 Departure Angle [deg] 21.4 Ramp Breakover Angle [deg] 16.5 Minimum Running Ground Clearance [in] 7.6 Interior Dimensions Head Room - First Row [in] 41.4 Head Room - Second Row [in] 40.5 Head Room - Third Row [in] 37.8 Leg Room - First Row [in] 40.6 Maximum Leg Room - First Row [in] 43.9 Leg Room - Second Row [in] 39.8 Leg Room - Third Row [in] 33.2 Hip Room - First Row [in] 57.3 Hip Room - Second Row [in] 56.7 Hip Room - Third Row [in] 40.7 Shoulder Room - First Row [in] 61.3 Shoulder Room - Second Row [in] 61 Shoulder Room - Third Row [in] 50.8 Interior Color Combinations: Base-Interior Center stack accents — Dark Slate Metallic Door trim — Dark Galvano HVAC trim surrounds — Charcoal Black Instrument panel appliqué — Dark Galvano XLT- Interior Center stack accents — Dark Slate Metallic Door trim — Bright Galvano with LA grain HVAC trim surrounds — Polished Pewter Instrument panel appliqué — Bright Galvano with LA grain Limited- Interior Center stack accents — Meteorite Black upper and Gloss Black lower Door trim — Olive Ash Dark Brown Instrument panel appliqué — Olive Ash Dark Brown woodgrain Capacities: Passengers, Luggage, Fuel Passenger Volume [cu. ft.] 151.7 Cargo Volume Behind First Row [cu. ft.] 80.7 Cargo Volume Behind Second Row [cu. ft.] 43.8 Cargo Volume Behind Third Row [cu. ft.] 21 Fuel capacity (gal.) 18.6 Engine Specifications 3.5L V6 Drive type Front-Wheel Drive (std.) / Intelligent 4WD (opt.) Engine type 3.5L Twin independent Variable Camshaft Timing (TiVCT) V6 Horsepower (net @ rpm) (Ford projected) 290 @ 6500 Torque (lb.-ft @ rpm) (Ford projected) 255 @ 4100 Compression ratio 10.8: 1 Valve lifters Direct acting mechanical bucket Induction System Naturally aspirated Fuel delivery Sequential multi-port electronic fuel injection Exhaust Quasi dual exhaust with chrome tips Engine block type Cast aluminum Cylinder head material Cast aluminum FWD V6 MPG 17 city / 25 hwy / 20 combined Transmission 6-speed automatic (std.) / 6-speed SelectShift Automatic (opt.) Final drive ratio 3.16 (FWD) / 3.39 (4WD) Four Wheel Drive V6 MPG 17 city / 23 hwy / 19 combined Chassis Specifications Front suspension MacPherson strut front suspension with 32mm front stabilizer bar Front shocks Gas-pressurized twin tube Rear suspension Multi-link independent rear suspension with 22mm rear stabilizer bar Rear shocks Gas-pressurized twin tube Brakes Power 4-wheel disc with Anti-lock Braking System (ABS) Steering Electronic Power-Assisted Steering (EPAS) Towing Specifications Optional Class III Trailer Tow Package Configuration .................................Axle Ratio....... GCWR...... Max Loaded Trailer Weight 3.5L TiVCT V6 FWD........... 3.16..........9920........5000 3.5L TiVCT V6 4WD ...........3.39........10096........5000 Performance 0-60 MPH 6.9 Seconds Warranty: 3yr/36,000mi. Bumper to Bumper 5yr/60,000mi. Powertrain 5yr/60,000mi. Roadside Assistance __________________ Moderator..Home Improvement/Explorer 911/2011 Explorer Forum You took my breath away....and now I want it back.... '66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT "Ex"plorer's: '92 Sport, '94 Sport, '01 XLS Our Crappy Website Last edited by JDraper; 03-08-2011 at 03:41 PM. |
#2 |
Wannabe Elite Explorer
Victoria, BC
2011
On thing I just found out, it is not even on the Canadian Website but it is on the US one. They actually went out of their way to make different becnh seats for the Leather XLT and the Ltd. Same base leather seats but the XLT does not get the pull down arm rest/cup holder. Not sure why they would have went thorugh the trouble of actually having to make two different kinds of seats.
#3 |
Does anyone know what the roof rack load capacity is?
#4 |
McVeytown, PA
'11 XLT
According to my manual the Maximum Recommended Load is 100 lbs (45kg).
__________________ Moderator..Home Improvement/Explorer 911/2011 Explorer Forum You took my breath away....and now I want it back.... '66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT "Ex"plorer's: '92 Sport, '94 Sport, '01 XLS Our Crappy Website |
#5 |
Des Moines, IA
Is that with or without the crossbars? 100 lbs seems low.
__________________ 2011 Explorer XLT 4WD 2004 GTO (garage queen) Several crotch rockets |
#6 |
McVeytown, PA
'11 XLT
With crossbars. The manual explicitly states that no cargo is to be placed directly on the roof, it should be placed so the cross bars carry the load.
#7 |
Victoria, BC
2011
That may be with the Ford cross bars but with the Thule ones I am pretty sure it is rated higher.
#8 |
Twin Cities, MN
'11 XLT
How about the bolt pattern for the wheels? Looks like it's still 5x4.5.
#9 |
Zachary, LA
Weight
Does anyone know the total weight?
#10 |
The cross-bar loading has to do with raising the vehicle center of gravity and increasing the risk of roll-over (besides the load capability of the components transferring the weight down to the vehicle frame). I'd think the Ford statement would take priority over the Thule load capacity.
#11 |
Zachary, LA
Good information. I'm new to the site, and was actually inquiring about the total weight of the 2011 Explorer. I've had Fords all my life..still have an 88 Bronco II that I purchased in 1991, and it's still in great shape. Looking to purchase the 2011 Explorer Limited soon, and wanted to know the weight for tax purposes.
#12 |
McVeytown, PA
'11 XLT
I've seen a curb weight listed at right around 4500 lbs. At this point I can't verify that though.
#13 |
Des Moines, IA
I've read that a fully loaded Limited is sitting just south of 4700 lbs curb weight. So all other models should go down from here, pending options. Also, it's frequently quoted that the 2011 is 100 lbs less than the 2010 model however trim level isn't given.
#14 |
Tampa, FL
2013 Explorer
Overall Height including antenna
I’m guessing that the height spec of 70.4 inches does not include the roof mounted antenna. Does any know the overall height of the 2011 Explorer Limited including the roof mounted antenna? My garage door clearance is only 77 inches.
#15 |
2012 XLT AWD
17" wheels specs
7.5" width, +40mm offset, 5.82" back spacing, 5x114 lug pattern, 2.5" center hole. Nice thing is these are the same specs for the 2011 Edge 17" wheel, which is an alloy. Also, the 2011 Edge and 2011 Explorer use the same tire pressure monitoring sensors.
#16 |
NJ
'97 XLT
Thules standard disclaimer is that you must not exceed the factory rack maximum weight limitation. Probably the same for all rack manufacutrers to avoid liablility problems. 100lbs is very good, equal to my '97.
#17 |
McVeytown, PA
'11 XLT
MyFordTouch Specs
Here are specs on the MFT system, including the sound system:
8-inch touchscreen Resistive glass-on-glass touch panel Automotive-grade; employs resistive-touch technology Requires a force from 0.2~2 N to actuate the panel and can only perform single actuation and drag and drop type HMI (Human Machine Interface) capabilities Phone Hands-free phone Phonebook transfer Audible text messaging Phonebook photo transfer Phonebook address transfer Bluetooth® Profiles1 Generic Object Exchange Profile Object Push Profile Serial Port Profile Phonebook Access Profile Advanced Audio Distribution Profile Audio/Video Remote Control Profile Hands-Free Profile Dial-Up Networking Profile Message Access Profile Entertainment Audio Playback and Browsing: MP3 Players, iPod/iPhone,9 USB Mass Storage Device (MSD), USB Media Transport Device (MTP), SD Card Video Playback and Browsing: USB Mass Storage Device (via special USB / RCA video cable) Bluetooth® Stereo Audio Streaming Audio/Video In Playback (via RCA input) Codecs: .WMA, .MP3, .AAC, .M4A, .WAV Playlist support: (.WPL, .ASX, .M3U, MP3 Players, MTP) Audible Audiobook support: iPod/iPhone, USB MSD, SD Card Album Cover Artwork transfer: MP3 Players, USB Mass Storage Device (MSD), USB Media Transport Device (MTP), SD Card HD Radio8 Song Tagging: iPod/iPhone AM/FM/HD Radio Sirius Satellite Radio2 WiFi 802.11 b/g Bluetooth® Internet data connection via Bluetooth® Personal Area Network (PAN) Internet data connection via USB Mobile Broadband Sony Audio System (Ford) 12 speakers 390 watts Dolby Pro Logic II Surround Sound THX Certified Audio System (Lincoln)11 14 speakers 600 watts DTS Neural Surround 8” Subwoofer Navigation GPS Processor, Memory, and Storage Freescale i.MX51 SOC Core CPU: ARM Cortex A8 @ 600 mHz 2D/3D graphics controller 512MB RAM 2GB NAND flash memory __________________ Moderator..Home Improvement/Explorer 911/2011 Explorer Forum You took my breath away....and now I want it back.... '66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT "Ex"plorer's: '92 Sport, '94 Sport, '01 XLS Our Crappy Website |
#18 | |
Twin Cities, MN
'11 XLT
Quote:
![]() Might need to do some homework... |
#19 |
McVeytown, PA
'11 XLT
IIHS Evaluation of the '11 Explorer can be found in this link:
http://www.iihs.org/ratings/rating.aspx?id=1433 __________________ Moderator..Home Improvement/Explorer 911/2011 Explorer Forum You took my breath away....and now I want it back.... '66 Mustang Coupe, '04 Mustang Mach 1, '08 Focus, '11 Explorer XLT "Ex"plorer's: '92 Sport, '94 Sport, '01 XLS Our Crappy Website |
#20 | |||
OH
2011 XLT
Does anyone know the weights for the different models?
So far I've seen 4,695 (that ford claims it is... but who knows which model that is for). And then I've seen 4765 for the XLT 4WD. What does the XLT FWD weigh? What does the Base FWD and 4WD weigh What does the Limited FWD and 4WD weigh How much weight does the moon roof add or subtract. Does the trailer package add any weight, if so how much? Ford talks about weight being a reason for better fuel economy... But something tells me that some of these vehicles weigh more than others..
| Thread Tools | |
