Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
94 ranger rough idle
Reply
Thread Tools
Old 01-24-2011, 06:15 AM   #1
Junkyarddog
909
94 ranger
Vehicle Specs
(Original Poster)
Hi guys I have a 94 ranger with a 4.0 it was running perfect until a month ago all of a sudden I get a intermitten rough idle problem. It seems like it dose it after I turn it on and run it for a while and it cools for a few and then I go turn it on and it starts to shake I've gotten the acasuanl mis fire it sounds kind of like a knock but that dosent happen all the time I'll let t sit there for a few and then it clears itself up and runs fine, I've done a few things that have helped slightly but haven't taken care of the problem.
1. Changed the fuel filter
2. Changed plug wires had a few that were burnt
3. Cleaned aicv
4. Checked spark plugs were all good
5. Checked pcv valve and it was good
I've done some research and i starting to think it's the upper intake rubber gaskets I bought some carb cleaner and sprayed it on the intake and it seemed to clear up I'm going to try it again to make sure. If it is the problem would you guys just recommend replacing the uper gasket or should I do the bottom I currently don't have any oil leaks at all any help is appreciated thanks !
Junkyarddog is offline   Reply With Quote
Old 01-24-2011, 05:04 PM   #2
swetrid
Reading Pa
2001 Eddie Bauer
Vehicle Specs
Intake gaskets
__________________
Resident Ford Tech for the last 17 years, 2001 Eddie Bauer 5.0L, Cherry Bomb Cat back, 2010 Ecoboost Flex
swetrid is offline   Reply With Quote
Old 01-24-2011, 07:40 PM   #3
Junkyarddog
909
94 ranger
Vehicle Specs
(Original Poster)
Quote:
Originally Posted by swetrid View Post
Intake gaskets
Right but should I do the upper only or lower and upper . I just don't want to do the lower if it isn't needed I found a write up on here already but I just want to make sure I do what needs to be done.
Old 01-28-2011, 04:36 AM   #4
Junkyarddog
909
94 ranger
Vehicle Specs
(Original Poster)
Any suggestions guys??? I want to try to takle this job this weekend but I don't want to replace the lower gaskets if they are not needed.
Old 01-29-2011, 09:09 PM   #5
Junkyarddog
909
94 ranger
Vehicle Specs
(Original Poster)
To the top........any ideas anyone?????
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
