EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
My first "Service engine soon" light :-(
Reply
Thread Tools
Old 01-25-2011, 05:52 AM   #1
zecolleman
Skagströnd ICELAND
zecolleman's Avatar
2004 limited
Vehicle Specs
(Original Poster)
Ok got my first error code to day. I read the error code as P0307 and P03016 and that meens misfire ,right. So what is best to do first to find the problem? Plugs are new only 3000 milage. And is ok to drive the car like this? I don´t feel any difference driving it.
__________________
Ford dose not spend gas, it simply use It....
zecolleman is offline   Reply With Quote
Old 01-25-2011, 07:27 AM   #2
miker104
N KY
miker104's Avatar
'04 XLT
Vehicle Specs
P0307 Cylinder 7 Misfire Detected. Could be loose spark plug (apparently they have been know to blow out on some engines), or sparkplug wire or Coil Over Plug (COP) if it has them. Could also be a bad spark plug.
P0316 Engine Misfire Detected on Startup (First 1000 Revolutions)
miker104 is offline   Reply With Quote
Old 01-25-2011, 07:43 AM   #3
shadowless127
Long Island, NY
'01 EB AWD 5.0
Vehicle Specs
replace wire, COP, and plug for cylinder 7.
The 2v's are known to spit plugs.
__________________
2001 Explorer Eddie Bauer 5.0 AWD - Custom Cat-Back, CAI, Ceramic Pads, LED Puddle Lamps, Sony MEX-BT3000P, Infinity 1060W sub, Boston Acoustics GT275 amp
Quote:
Originally Posted by Joe Dirt View Post
Here is the selling point of the Bosch Jesus plugs. That optimum cleaning temperature. I can hear the angels singing already.
shadowless127 is offline   Reply With Quote
Old 01-25-2011, 09:31 AM   #4
rocco123
Endicott, NY
rocco123's Avatar
1994 XLT & 2002 Limited
Vehicle Specs
Swap coild around to see if problem follows to different cyl
rocco123 is offline   Reply With Quote
Old 01-25-2011, 10:51 AM   #5
zecolleman
Skagströnd ICELAND
zecolleman's Avatar
2004 limited
Vehicle Specs
(Original Poster)
Ok did swap coil 7 with coil 6 and the light have not come back yet. The coil were pretty messy "sand and water" maby that was the problem? I cleand them and sprayed it with WD40. But before I noticed that it idel roughly and then the light was flashing.What is the diffrence between flashing light and not?..
__________________
Old 01-25-2011, 11:55 AM   #6
miker104
N KY
miker104's Avatar
'04 XLT
Vehicle Specs
What is the difference between flashing light and not?
Q: Is it safe to drive if my "Check Engine" light is on?
A: It really depends what code is stored and what caused it. In worst cases driving with "Check engine" light may cause more damage to the vehicle. A car may even stall while driving. If your check engine light came on, I'd certainly recommend to visit your dealer or a mechanic as soon as possible, just to be on a safe side. If the Check Engine light is flashing, this means that the engine computer (ECM) has detected that your engine is misfiring, which could damage your catalytic converter. Have the your vehicle inspected as soon as possible.
Old 01-26-2011, 06:27 AM   #7
zecolleman
Skagströnd ICELAND
zecolleman's Avatar
2004 limited
Vehicle Specs
(Original Poster)
Ok the light seems to be gone so it was probably the water. So I went out this morning and took all the coils out and blow compressed air down to the plug hole to get the water out and sprayed the coils with WD40. And now we just wait and se if it was realy that easy. Has anyone experienced this? The weather here have been very bad and the hood was at least 3 times completely packed with snow like concrete and now it has been 45°F for about week so all the snow is mostly cone.
__________________
Old 01-26-2011, 09:46 AM   #8
rocco123
Endicott, NY
rocco123's Avatar
Vehicle Specs
No, never experienced this... but then again I'm not living in Iceland
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
