| Modified 1995-2001 Explorers Questions related to modified 1995-2001 Explorer, Mountaineer, Ranger and 2002+ Sports (2dr). Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, torsion twist, lift kits, engine swap, transmission swap. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Kansas City
'00 XLT 5.0 V8
Ok so later on this year, I'm planning to tear down and put back together my 5.0 with only 156,000 miles. Reason to do so is for several reasons, learning experience, replace valve seals that are slowly starting to go bad, and to add a cam into it as well. The engine as of now runs great so hopefully I'll be able to re-use alot of parts. At this point I want to stay with 302 ci displacement. I don't have the budget nor is neccessary to build a stroker engine since I also own a Mustang as well that could rather benefit from that money. But I do want to know what I can do outside of new gaskets, rings, oil pump and bearings I can do to rejuvenate it. A cam is a top priority for this project, preferrably a custom cam. Redo everything on the top end like springs, rollers, push rods, ignition, etc.Can anyone help point me in the direction of rebuild kits on here, Where I can locate someone that can build a cam and give me an idea of how much a simple rebuild plus cams, and valve train must cost?
__________________ 2000 Explorer XLT. 5.0 V8. Dual In/Out Flowmaster Super 40 Series, Royale Purple Motor Oil, MAC Cold Air Intake with K&N Cone, Torque Monster Headers , X-Cal 3 SCT Tuner tuned by Henson Performance, Rear Cats Delete, Drilled and Slotted Rotors with Ceramic Pads Gold Powdercoated Valve Covers and Upper Intake manifold by Turdle Engine overhaul Completed! Still tinkering. Shaved/Ported GT-40P's w/ matching lowe r intake, Flowtech Street Beast Custom cam 111 lsa, Scorpion Adjustable Rockers. Painted Block, Taylor 8mm wires |
#2 |
Topeka, KS
00 V8 Mountaineer
if you get a custom cam don't buy any of that stuff first, the cam designer should recommend/sell you the proper parts for your new cam. As far as ignition goes you can leave it alone it's a good system as it is.
#3 |
Kansas City
'00 XLT 5.0 V8
Really as far the ignition? I've heard alot about MSD. But honestly , you're right that's something I can do later anyways with the engine in the truck. I'm really focused about doing the internals. I'm gonna check with COMP cams , other than that any other reccommendations?
#4 |
Topeka, KS
00 V8 Mountaineer
The ignition is good, you could run msd coil packs if you really wanted, but those are easy to add anytime. Jay Allen used to be the go to cam designer, but he has been ill for quite some time and fallen off the map. I would check over on sbftech and see who they are recommending now.
#5 |
Kansas City
'00 XLT 5.0 V8
This is the the recommended cam I got in response from COMP Cams technical support. http://www.compperformancegroupstore...Category_Code=
http://www.compcams.com/Company/CC/c...csid=1446&sb=2 __________________ 2000 Explorer XLT. 5.0 V8. Dual In/Out Flowmaster Super 40 Series, Royale Purple Motor Oil, MAC Cold Air Intake with K&N Cone, Torque Monster Headers , X-Cal 3 SCT Tuner tuned by Henson Performance, Rear Cats Delete, Drilled and Slotted Rotors with Ceramic Pads Gold Powdercoated Valve Covers and Upper Intake manifold by Turdle Engine overhaul Completed! Still tinkering. Shaved/Ported GT-40P's w/ matching lowe r intake, Flowtech Street Beast Custom cam 111 lsa, Scorpion Adjustable Rockers. Painted Block, Taylor 8mm wires |
#6 |
Topeka, KS
00 V8 Mountaineer
For what that cam costs I think your better off getting a true custom cam, and not from comp or another major manufacturer. Woody who owns ford strokers is recommending these guys right now since Jay Allen is out of commission.
Mark at Bullet (662)893-8022 Bob at Cam Motion 225 926 6110 |
#7 |
Kansas City
'00 XLT 5.0 V8
Cool I'll give those numbers a call later this work week. I also figured those prices were pretty dang high!
#8 |
Old and in the way
Humboldt, Kansas
2000 Mounty
How high do you plan on revving the engine to achieve the desired output? This will determine quite a few needed upgrades--
The first time the engine sees 5800 RPM's you should upgrade valve springs-for example. Valve train stability will need to be addressed, as the contact arc of the rocker tip will be increased. Roller rockers will "pull" the valve stem less. The rocker arm pulling on the valve is responsible for valve stem seal wear. If you have excessive wear with a stock cam, well, I think you can see where this is going. $$$ |
#9 |
Kansas City
'00 XLT 5.0 V8
I'd say 6,000-6,200 would be a fair number for me
#10 |
Kansas City
'00 XLT 5.0 V8
Ok i Emailed Cam motion and they sent me back a cam reccomendation sheet to fill out. Is there somewhere I can get the specifications on all the internals of the Explorer 5.0 such as cam type, engine design, rod length, bore/stroke, cylinder heads, cylinder head flow lift of intake/exhaust, compression, rocker ratio, valve size, current cam design profile ?
#11 |
Kansas City
'00 XLT 5.0 V8
Cam Type? Engine Design/Size?
Bore/Stroke? Rod Length? Cylinder Heads? Compression? Cyclinder Head Modifications? Rocker Ratio? Valve Sizes? Induction System? Fuel? Exhaust System? Chassiss Design/Weight? Transmission? Axle Ratio/Tire Size? Current Camshaft Design/Profile? Application Notes Cylinder Head Flow Data Lift Intake Exhaust 0.200 0.300 0.400 0.500 0.600 0.700 0.800 __________________ 2000 Explorer XLT. 5.0 V8. Dual In/Out Flowmaster Super 40 Series, Royale Purple Motor Oil, MAC Cold Air Intake with K&N Cone, Torque Monster Headers , X-Cal 3 SCT Tuner tuned by Henson Performance, Rear Cats Delete, Drilled and Slotted Rotors with Ceramic Pads Gold Powdercoated Valve Covers and Upper Intake manifold by Turdle Engine overhaul Completed! Still tinkering. Shaved/Ported GT-40P's w/ matching lowe r intake, Flowtech Street Beast Custom cam 111 lsa, Scorpion Adjustable Rockers. Painted Block, Taylor 8mm wires |
#12 |
DISABLED AIRBORNE VET
SW Florida
1999 Expedition XLT 4x4
All these question are to be told when you describe the type of vehicle, engine package with said vehicle. The company you are inquiring with about a cam has all that info at a touch of their fingers. The questions they are asking from you are aftermarket internals that you may have installed and if you did any bore and stroke modification. But if it is a basic 2000 5.0, that is all you have to tell them,Majority of it is simple,
The 5-liter engine in the Ford Explorer is technically a 4.9-liter 4,949 cc of displacement cam type- is a single overhead cam 98, 99, 00 came out with 215 horsepower and 288 foot-pounds of torque compression ratio of 9.0-to-1. Cylinder bore was 4 inches and crankshaft stroke was 3 inches. The overhead valve configuration has 16 valves, and the transmission is a four-speed automatic. The company you are inquiring to wold have all the stock internals required to come up with a suitable cam based on what you are looking for. You explain to them that you are rebuilding the engine with stock internals and or whatever you are installing in the rebuild. Hope this helps as there is not much to give ya oother than advice. __________________ 99 Expedition XLT 4x4- Edge HT/EVO tuned, full Spectre CAI kit, lifted, Rancho RS5000's, 33 Nitto's on 16x10 Pro-Comps, Hooker Aero Chamber exhaust, Black Brush Guard, more to come. Last edited by SkyJumper; 05-06-2011 at 08:43 PM. |
#13 |
Kansas City
'00 XLT 5.0 V8
Hey guys, been a while since I posted in this thread. Been busy with other things plus still searching my options. I got refered to flowtechinduction by the 5.0 guys on the mustang forums.
http://www.flowtechinduction.com/ This is the email responsed I got from them after sending a cam buil form to them. AT this point I just want to do a basic overhaul with a cam swap and any other valvetrain changes the builder specifies. No stroker engine, no head swap, intake swap. I'd like to keep this as simple as possible. Good morning Thomas, Thank you for your interest in one of our custom designed camshafts and valvetrain kits. I will review what you have listed on your Cam Tech Form and go through all your pertinent details. Your particular camshaft profile will be designed and ready for scheduling in about two to three working days. Please note, because I receive dozens and dozens of Emails per day, there are times when a response may be delayed. If this timeframe is acceptable, this type of camshaft will normally take about a week to ten days to get completed after receipt of payment. Lead-times may vary depending on the time of the year order is placed and availability of camshaft cores. Special base circle cores or grinds require additional time. Once payment is received, I can Email you an advanced copy of the cam spec card that is included with every profile. As a policy, I do not release any of the camshaft particulars until payment is received. Any one of our custom hydraulic roller camshafts for the small block Ford is $325 USD with FREE SHIPPING to the continental 48 states. The race series billet steel core camshafts are available for $375 and the “Ever-Wear” steel cores are $395 USD also with free shipping. Payments are strictly by cash, certified bank check or postal money order and must be paid in full before any work can proceed. PayPal is also accepted with 3% added to the entire order to cover processing and documentation fees. The PayPal total for a hydraulic roller camshaft would be $335 ($387 for billet cores) shipped to the continental 48 states. Additional shipping and insurance costs will need to be calculated. Be aware that your cylinder heads will require a change of valve springs and other peripheral equipment when using our camshafts. If this is required, the customer must be able to provide the proper information on such items as valve spring installed height and pocket diameters in order for us to provide the correct matching spring package. The GT40P heads require machining the spring pockets for a quality valve spring kit so have your machine shop be aware of this. Push rod lengths will vary so they must be verified for proper rocker arm geometry and lifter preload before ordering. We can provide all the proper components for a trouble free installation as long as we are provided accurate information. If you are interested in these peripherals, they can be quoted for you. We look forward to working with you on this project. Ed FLOWTECH INDUCTION PO Box 1205 Coventry, RI 02816 www.FlowTechInduction.com Can anyone provide me with the needed 5.0l engine spec so I can give the builder the correct information needed to get me the right parts? __________________ 2000 Explorer XLT. 5.0 V8. Dual In/Out Flowmaster Super 40 Series, Royale Purple Motor Oil, MAC Cold Air Intake with K&N Cone, Torque Monster Headers , X-Cal 3 SCT Tuner tuned by Henson Performance, Rear Cats Delete, Drilled and Slotted Rotors with Ceramic Pads Gold Powdercoated Valve Covers and Upper Intake manifold by Turdle Engine overhaul Completed! Still tinkering. Shaved/Ported GT-40P's w/ matching lowe r intake, Flowtech Street Beast Custom cam 111 lsa, Scorpion Adjustable Rockers. Painted Block, Taylor 8mm wires |
#14 | |
Speed
Bremerton, WA
1992 Explorer XL
Quote:
Ryan __________________ 1992 Ford Explorer XL - with a few bolt ons... |
#15 |
Kansas City
'00 XLT 5.0 V8
Yes, ~Bump! Anyone on here know where I can find the internal specs of the late Gt-40p head 5.0 engines. Things like lift, duration, stock cam lobe separation, valve spring installed height and pocket diameters. The cam builder needs to know all this before I can move forward with this project.
#16 |
Northern VA
2002 Explorer XLT
The stock cam Ford puts in the 5.0L engines is pretty darn good. Putting in another cam without improving breathing for the heads really limits the potential horsepower gain from a cam swap. I would take the money for the cam and buy under drive pulleys, headers and a free flowing exhaust and you will see about as much horsepower as a cam. Also, you could mill the heads down a bit to increase the compression ratio. Just don't go too far. Then again, if you want a dependable decent performance boost then install higher (numerical) gears as this is one of the best bang-for-the-bucket modifications one can do.
BTW, Flowtech Induction is a great outfit. If you are going the cam route then you chose a great place to have the cam cut. |
#17 |
Kansas City
'00 XLT 5.0 V8
I'm not trying to go over the top with this project. I can't fit all that into the budget otherwise I'd just go the 347 route and that leads to a snowballing effect of other needed mods. Just a basic overhaul to keep her on the road another 10+ years, fix the annoying main seal and valve seal leaks on her while beefing up the cam and valve-train. I've read on here on several threads that after the exhaust, the cam is the 2nd weakest link on this engine. Well, I've already got about as high flow exhaust as you can get. Torque Monster Headers into 2.5'' High flow cats, no rear cats and dual in/out 40 series.
#18 |
Northern VA
2002 Explorer XLT
One thing you can do yourself while it is apart is to port match the upper/lower intake and the heads. It won't give you a big HP gain but every little bit helps and it won't cost you hardly anything to do it.
#19 |
Kansas City
'00 XLT 5.0 V8
Have you heard anything about raised pistons as far as raising compression on a budget?
#20 | |
Northern VA
2002 Explorer XLT
Quote:
Milling the heads down reduces the compression ration too and costs less. Once again, just watch for piston to valve interference. |
| Thread Tools | |
