Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Anti Hijack door locking
Reply
Thread Tools
Old 01-27-2011, 07:35 PM   #1
Snowcone
Newcastle, Australia
02 XLT
Vehicle Specs
(Original Poster)
I know you guys in the States need this feature, but is there any way to stop the damn thing from locking all the doors after you move off.
It is driving me batty every time I need to get something out of the back and I forget to unlock them and then have to go back to the front door and press the unlock button.
Seriously, hijacking is not very common in Australia and it is not an option or feature on most cars delivered here.
Snowcone is offline   Reply With Quote
Old 01-27-2011, 07:40 PM   #2
waskly
Crooklyn NY!
Vehicle Specs
yes it can be turned off. and its just auto locks :P
if you have a message center its in there.
1. Select this function from the
SETUP control for the current
display mode.
2. Press the RESET control to turn
the autolocks ON or OFF.
if you do not have the reset/setup/info buttons or the message center instrument cluster do this
Deactivating/activating autolock
There are 3 methods to enable/disable this feature. One through your
dealer, the second with a power door unlock/lock sequence and the third
with the keypad.
Before following the activation or deactivation procedures, make sure
that the anti-theft system is not armed, ignition is off, and all vehicle
doors, liftgate and liftgate window are closed.
You must complete steps 1-5 within
30 seconds or the procedure will
have to be repeated. If the
procedure needs to be repeated,
you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will
chirp once if autolock was deactivated or twice (one short and one long
chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the
procedure is complete.
waskly is offline   Reply With Quote
Old 01-27-2011, 07:54 PM   #3
Snowcone
02 XLT
Vehicle Specs
(Original Poster)
Thank you for the fast response.
I have a message centre so will do this tonight.
cheers
Old 10-20-2012, 07:43 AM   #4
vipersinu2
The Big City of Orange City, Florida
vipersinu2's Avatar
97,03 explorer 07 mounty
Vehicle Specs
is there a way to have all the doors unlock when key shuts off like the 06-10 models?
vipersinu2 is online now   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
