Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
2nd Gen rear wheel bearings
Reply
Thread Tools
Old 02-03-2011, 05:05 PM   #1
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
No results found for rears.. Every other issue has 10 posts talking about the same thing. I just want to know what I need to take em out.
I picked up the seals and bearings and fluids but I don't have any special bearing tools.. are they needed or can I hammer them out ?
__________________
'96 XLT 4DR <<< RETIRED
'00 Sport 2DR
Signature modified by Moderator
G-96XLT is offline   Reply With Quote
Old 02-03-2011, 05:10 PM   #2
waskly
Crooklyn NY!
Vehicle Specs
i use a slap hammer with a bearing puller attacher, you can defiantly hammer them in, out, might be tricky.
looks like this
waskly is offline   Reply With Quote
Old 02-03-2011, 05:48 PM   #3
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
I can't see anything in that little pic. What about a typical 3 arm gear puller. Is there enough room to put those in with the claws reversed.
__________________
'00 Sport 2DR
Old 02-03-2011, 05:51 PM   #4
waskly
Crooklyn NY!
Vehicle Specs
Quote:
using a jaw puller will not allow you to have any place to use the forcing screw to pull it out of.
i'll post a better picture, its a slap hammer with a bearing attachment.
where you use one of the black attachments to hold the bearing from inside while you slap it out.
Old 02-03-2011, 06:09 PM   #5
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
The tool waskly is referring to is also known as a slide hammer. Once you remove the axle shaft you should be able to manually rotate the inner race of the bearing with it still in place in the bore. To ensure that it is indeed bad.
If it is you can adjust the diameter of your slide hammer attachments so that they contact only the inner race of the bearing. This will destroy the bearing, but will make it less likely for you to nick the bore while you're slamming away.
When driving the new bearing in it may help to let it sit in the freezer for a few hours first to slightly shrink it. And possibly warm up the axle shaft bore with a butane or other similar torch. If you do warm up the axle shaft it doesn't have to be much, and watch out for old gear oil as you don't want it to ignite.
Use either a genuine, or create a, bearing driver to contact only the outer race of the new bearing. Drive it in with smooth even motions along the axis of the axle shaft. Striking the inner race will destroy the bearing if the outer race is being held in place by the bore. PVC pipe pieces can sometimes be used for this, or you can find better makeshift bearing driver's.
EDIT:
Be aware that if you are using brake parts cleaner to clean the axle tubes and rear differential. That heating brake parts cleaner produces toxic fumes which are highly poisonous! DO NOT HEAT BRAKE PARTS CLEANER! Allow it to evaporate completely before working. I'm not a professional, I just saw this thread and thought I should warn you.
__________________
There is wisdom to be found in the counsel of many.
OneLever is offline   Reply With Quote
Old 02-03-2011, 06:24 PM   #6
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
I know the precautions for putting it back in. I read the whole chapter in the haynes manual. I just wanted to know if there was anything special needed for the removal. I can get a slide hammer on loan, not sure about a bearing puller but maybe parts source has a loaner.
__________________
'00 Sport 2DR
Old 02-03-2011, 06:27 PM   #7
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
Looks like parts source has a harmonic puller and installer. is this good enough ?
http://www.partsource.ca/doityoursel...7_03_large.jpg
__________________
'00 Sport 2DR
Old 02-03-2011, 06:34 PM   #8
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
I see nothing in that kit to contact the bearing race, only to hold the tool in place. You could possibly use that tool along with a large (fender) washer from a hardware store. Also, even though you might not need it here is a write up on the rear axle removal for anyone else who might stumble across this thread: Link
__________________
Old 02-03-2011, 06:46 PM   #9
waskly
Crooklyn NY!
Vehicle Specs
actually a drill and a dent slap hammer might work, drill a hole in the bearing, screw in the slap hammer and hammer away.
Old 02-03-2011, 07:42 PM   #10
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
How much force is really required to knock the bearings out. I might just take it apart and examine it and build a tool for it.
I got the idea now from watching this video. I think I will just make something similar
http://www.youtube.com/watch?v=QhBADmrMufs
__________________
'00 Sport 2DR
Old 02-03-2011, 07:54 PM   #11
OneLever
97 Mt. 5.0L AWD
Vehicle Specs
build a tool for it... I think I will just make something similar
Definitely an option. They have threaded rod you can buy at a hardware store. Using several fender washers, a couple nuts, and some steel plating or angle bracket. All cut to size with an angle grinder. There are probably loaner tools available at your local auto parts stores though.
__________________
Old 02-03-2011, 08:07 PM   #12
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
That picture I showed you was the loaner.
The good thing is I already have the new bearings so I can try to make a tool for it first.
__________________
'00 Sport 2DR
Old 02-04-2011, 07:22 PM   #13
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
Hey Waskly is this the same thing ? I can get it on loan from Canadian tire
http://www.canadiantire.ca/AST/brows....jsp?locale=en
__________________
'00 Sport 2DR
Old 02-04-2011, 07:27 PM   #14
waskly
Crooklyn NY!
Vehicle Specs
Quote:
Originally Posted by g-96xlt View Post
hey waskly is this the same thing ? I can get it on loan from canadian tire
http://www.canadiantire.ca/ast/brows....jsp?locale=en
yes! you are going to use one of the 3 black attachments, they fold in to get into the axle shaft behind the bearing. then just slap or hammer it out.
Old 02-04-2011, 07:42 PM   #15
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
Great thanks. I took the bearing to the store and it fits perfect with the smallest black piece. I think I have everything now and I might just tackle this weekend.
__________________
'00 Sport 2DR
Old 02-04-2011, 07:43 PM   #16
waskly
Crooklyn NY!
Vehicle Specs
good luck
use the old bearing to put the new one in btw. makes life easy
Old 02-06-2011, 04:27 PM   #17
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
I'm going down now to tackle it. Any last minute tips or warnings.
The rear bearings are self lubricating right ?
__________________
'00 Sport 2DR
Old 02-06-2011, 04:56 PM   #18
waskly
Crooklyn NY!
Vehicle Specs
yes they are, dont hurt though to put light gear oil on them.
Old 02-07-2011, 04:58 AM   #19
G-96XLT
Toronto, ONT
'96 XLT , '00 Sport
Vehicle Specs
(Original Poster)
I got it all done except for the drain plug. The thing looks really bad and I can't fit the ratchet extension in. I'll try again tomorrow.
The tool was great, it only takes a couple of smacks. The bearings were ok but fluid was dirty.
__________________
'00 Sport 2DR
Old 02-07-2011, 07:57 AM   #20
96eb96
Albany, NY
96 EB V6 OHV 4WD
Vehicle Specs
Put some penetrating oil on it overnight.
Did your pinon holding bolt in the axle come out in one piece? In most cases they break.
96eb96 is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
