Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
Help me please.
Reply
Thread Tools
Old 02-08-2011, 04:07 AM   #1
89 ranger
Seattle
1995 xlt
Vehicle Specs
(Original Poster)
Help me please.
I just acquired a 1996 explorer xlt 4x4 for free from a coworker. The tranny went out and she bout a new car. This thing is nice and i thought id put a tranny in it and sell it. Well i bout a new 4r55e for it and and new torque converter. And proceeded to put them in. Old tranny had these symptoms:
Would not shift into gear until higher rpms
It would randomly diengage and free spin.
Used parking pin to slow it down so i could put it in drive and drive it home.
(not good but eh it was shot)
Clunked into gear
New transmission:
Shifts into gear nicely
Powers off the line without slippin
Can power brake no slippin
But... It has the same exact problems between gears. Wont shift till higher rpms
Cant find overdrive
I had the line pressures checked and the diagnoses was low line pressure.
The guy told me this tranny was bad too and that it was the clutches or the valve body. But with the same problems i dont believe it. I cycled key and tried to relearn comp but no luck. I talked to a friend who was a ford tech for 14 years and in the 300+ explores he has worked on it had very seldome been a bad valve body. He told me that if the kick down isnt set right or somethign somewhere (was a little over myhead) it could be diverting pressure in the wrong places and causin these problems. Please give me some insight on how to check or other diagnosis. Im frustrated and i want it fixed.
89 ranger is offline   Reply With Quote
Old 02-09-2011, 11:10 AM   #2
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quote:
Originally Posted by 89 ranger View Post
...... Well i bout a new 4r55e for it and and new torque converter. And proceeded to put them in.. Im frustrated and i want it fixed.
"NEW" 4R55E? One can buy a used or rebuilt, but not new. So, what did you buy?
Problem looks like, you want more diagnosis of present transmission troubles, but did not diagnose those of the original one, which might have been in better condition than the "new" one.......imp
imp is offline   Reply With Quote
Old 02-09-2011, 11:14 AM   #3
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
First suggestion. Check the Throttle position sensor.
<1v at idle position, steadily rising to 4.5v as you slowly open the throttle.
High TPS voltage will hold the lower"passing"gear, as the PCM "thinks" the throttle is floored.
Just throwing it in there.
__________________
Jon
2000 Mountaineer
Turdle-gone
Vitamin D Wagon Sold also
Turdle is online now   Reply With Quote
Old 02-12-2011, 03:36 PM   #4
89 ranger
Seattle
1995 xlt
Vehicle Specs
(Original Poster)
Well its not new but it is newer. And the old tranny was completely destroyed. Metal in the pan. Okay well my diagnosis of old tranny was that it needed to be replaced. The lady i got it from left it at the shop where they said tranny was bad and thats where i picked it up. Never had any suspiscion that something else would be causing these problems.
Old 02-16-2011, 05:22 PM   #5
89 ranger
Seattle
1995 xlt
Vehicle Specs
(Original Poster)
useless forum thanks guys
Old 02-16-2011, 06:00 PM   #6
ncranchero
Sport Trac Moderator
Denver,NC
ncranchero's Avatar
Truckin' on Pat & Charlie
Vehicle Specs
You catch more flies with sugar than sh*t !
__________________
Steve,
2010 Transit CONNECT 145K miles, 2002 Sport Trac 4x4 SOLD
2000 Taurus SES 3.0L 24 Valve DOHC Duratec 87K miles
1994 F150 4x4 4.9L/5-speed 160K miles,
1995 Ranger 2.3L/5-sp/3.73 75K miles "Plain Jane"
How to post photos
ncranchero is offline   Reply With Quote
Old 02-16-2011, 06:15 PM   #7
Turdle
Old and in the way
Humboldt, Kansas
Turdle's Avatar
2000 Mounty
Vehicle Specs
Results from post 3 please.
As far as useless you sound like my ex wife. ol whats her name
__________________
Jon
2000 Mountaineer
Turdle-gone
Old 02-16-2011, 06:25 PM   #8
ncranchero
Denver,NC
ncranchero's Avatar
Vehicle Specs
You're a good man Jon!
__________________
Steve,
How to post photos
Old 02-16-2011, 09:43 PM   #9
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
And I thought I was hard on 'im in post #2................imp
Old 02-26-2011, 03:41 AM   #10
89 ranger
Seattle
1995 xlt
Vehicle Specs
(Original Poster)
Ah cool. Well if ud spend as much time trying to help as u do making jokes u might be able to help me
Old 02-26-2011, 07:22 AM   #11
lounge lizard
Eastern PA
1997 xlt awd
Vehicle Specs
man! talk about a stick up the..............
anyways do you know if it has had the cruise control recall modification done to it yet?
some of the modifications done to fix the cruise control causes the motor to rev up and shift hard/lagging between gears. not knowing this and staying on the throttle would cause problems in the transmission department.
just throwing it out there mine did this till it learned the new fix
__________________
lifting the world one truck at a time!
lounge lizard is offline   Reply With Quote
Old 02-26-2011, 08:07 AM   #12
ncranchero
Denver,NC
ncranchero's Avatar
Vehicle Specs
Actually there was no joke to it and I have helped out a time or two but thanks for the advice. You come here nice and fresh with a transmission problem and expect an immediate solution to a problem your 14 year Ford tech friend can't/hasn't helped you with. You had two constructive posts, neither of which did you answer with facts. Your diagnosis of the original transmission was, in your words "The lady i got it from left it at the shop where they said tranny was bad" which is meaningless. You swapped in a used transmission which is okay, but based on a transmission shops determination that the original one was bad.This is not going well for you and I understand your frustration but calling a forum you expect help from USELESS is just plain asinine. People here are quite willing to help where they can, including me believe it or not, but insulting them is not the way to get that help!
Can you explain what you are talking about here? Is there a cruise recall that does something other than add a fused harness/replace the deactivation switch/inspect the connectors to prevent a short leading to a fire? What does the cruise recall have to do with this. This is new info to me but hey, I'm willing to learn.
__________________
Steve,
How to post photos
Old 02-26-2011, 08:13 AM   #13
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
You are obviously a Retard sir. To call out a community of over 150,000 members world wide with over 2 million posts, backed by car manufactures, engineers, certified mechanics, doctors, lawyers, police officers, rescue workers, Military personnel, white & blue collar hard working men & women, USELESS is about the dumbest thing I have seen a person do in a long long time.
Go to the dealership, and try to get your FREE answers. I bet when you pull up to the garage door, a red carpet will be unrolled for you, 25 knowledgeable mechanics will be greeting you, the owner will make everybody stop what they are doing, to make sure your high & mighty self absorbed pompous ass gets pampered and see to your every whim.
If you just want to take, take, take, and have nothing to give, GTFO!
__________________
The Black Hole
Pugly
gmanpaint is offline   Reply With Quote
Old 02-26-2011, 11:48 AM   #14
lounge lizard
Eastern PA
1997 xlt awd
Vehicle Specs
Ahmen!
Gmanpaint!
and I'm just a newbie here too!
__________________
Old 02-26-2011, 11:54 AM   #15
lounge lizard
Eastern PA
1997 xlt awd
Vehicle Specs
Can you explain what you are talking about here? Is there a cruise recall that does something other than add a fused harness/replace the deactivation switch/inspect the connectors to prevent a short leading to a fire? What does the cruise recall have to do with this. This is new info to me but hey, I'm willing to learn.[/QUOTE]
sorry! missed this post!
but!
when I had mine done in the explorer, it start to rev to 3K in first gear and then shift hard. wasn't every time from a standing start but it was always when you least expect it.
when I took it back to the dealer who did the recall the guy said the truck had to learn the shift commands over with the modification. and after about a month all is well again.
haven't had an issue with high revving shift pattern since the recall and that was in the fall.
talked to a few others who have had the same thing happen and they said it cleared up with in a few weeks like mine did.
I have no way of knowing if this is true, but hey! ya never know!
__________________
Old 02-26-2011, 04:50 PM   #16
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
When It Becomes Wasteful:
IMO, only, it is a waste of valuable forum space and computer memory to "resolve" issues by "ganging-up" on one-another.
Perhaps my own "quip" was out of place. Others must answer on that one.
At any rate, it sounds as though some good came out of the thread after all, regarding engine speed and cruise-control inputs to it.
Pray, let's get on with business! imp
Edit: Added thought-- I am impressed by correct useage of "asinine", as most people think it refers to "anality".
Old 03-01-2011, 07:38 PM   #17
89 ranger
Seattle
1995 xlt
Vehicle Specs
(Original Poster)
Okay well im in a pickle to get this thing out and excuse me for posting that but i wasnt getting any constructive answers. But all in all after you called me retarded and what not, which there was no reason to be a douche over a forum site, but im clearly not
Retarded i have a driver's and i am able to use a computer. Now with the exceptions of idiot savants i dont think many mentally handicapped people are very good at using computers. Now this cruise cpntrol
Thing is new to me and i do not know if it has been done but u think it will help
If it hasnt. I dont know how long the computer will take to relearn its shifts but it hasnt been driven a whole lot because of the problems ive had. Im a little scared. Could a bad cpmputer cause this? And if so where woulf i find said computer. Thanks now im sorry i called ur forum out for being useless but it did grab a lot of attention and some good starts to an answer. So that comment about catching mores flirles with sugar than shit
Should be rethought. Lol. Thanks and sorry guys.
[/QUOTE]
Old 03-01-2011, 08:10 PM   #18
ncranchero
Denver,NC
ncranchero's Avatar
Vehicle Specs
Well there are thit flies too you know.
I know of absolutely NO WAY the cruise control recall can affect the transmission shifting. You can read the complete, including dealer info, HERE
Research TSBTSB 97-22-4
Your 96 TSB's, several which pertain to transmission issues.
Technical Service Bulletins
1996 Explorer - US (English)
The Technical Service Bulletins (TSB's) listed here may NOT apply to the vehicle you are working on. You MUST run OASIS with a specific VIN and Symptom Code to determine if it applies. If OASIS does not return the TSB, then it does NOT apply.
06-26-1
MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-14-4
MERCON ATF IS BEING REPLACED BY MERCON V ATF AS A SERVICE FLUID.
05-6-20
FRONT AXLE LEAKS FLUID FROM VENT TUBE - VEHICLES EQUIPPED WITH 4X4 OR AWD
03-22-10
TRANSMISSION - 4R44E - 4R55E - 5R44E - 5R55E - LOW LINE PRESSURE READING AT WIDE OPEN THROTTLE (WOT) - POSSIBLE DIAGNOSTIC TROUBLE CODES P0732, P0733, P1762 - VEHICLES BUILT BEFORE 12/1/2001
03-18-1
ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS
03-14-8
TRANSMISSION - NEW TRANSMISSION COOLER FLUSHER - SERVICE TIPS
02-25-8
ELECTRICAL - NEUTRAL TOW AVAILABILITY
TRANSMISSION - NEUTRAL TOW AVAILABILITY
02-22-1
DRIVEABILITY - SURGE/ROLLING IDLE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
ENGINE - GEAR DRIVEN SYNCHRONIZERS - INCORRECT INSTALLATION - CAMSHAFT POSITION SYNCHRONIZER (CMP) INSTALLATION TOOL CORRECT APPLICATION
02-17-6
LAMP - BRAKE - INADVERTENT DISABLING OF BRAKE SHIFT INTERLOCK
02-16-4
FUEL SYSTEM - FUEL PUMP "WHINING"/"BUZZING" NOISE COMES THROUGH ENTERTAINMENT OR TWO-WAY RADIO SPEAKER
RADIO - ENTERTAINMENT OR TWO-WAY COMMUNICATION - "WHINING"/"BUZZING" NOISE IN SPEAKERS CAUSED BY FUEL PUMP
NOISE - "WHINING"/"BUZZING" - COMES THROUGH SPEAKERS OF ENTERTAINMENT OR TWO-WAY RADIO
02-14-2
ENGINE - 4.0L OHV - POSSIBLE CRACKED FLEXPLATE - NOISE OR VIBRATION - VEHICLES EQUIPPED WITH AUTOMATIC TRANSMISSION ONLY
ENGINE - NO CRANK - POSSIBLE CRACKED FLEXPLATE - NOISE OR VIBRATION - VEHICLES EQUIPPED WITH 4.0L ENGINE AND AUTOMATIC TRANSMISSION ONLY
NOISE - NOISE DURING CRANKING - POSSIBLE CRACKED FLEXPLATE - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE AND AUTOMATIC TRANSMISSION ONLY
TRANSMISSION - A4LD - 4R55E - NO FORWARD OF REVERSE ENGAGEMENT - POSSIBLE CRACKED FLEXPLATE - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
01-23-6
ENGINE COOLANT - PROPYLENE GLYCOL - FORD MOTOR COMPANY POSITION ON ENGINE COOLANTS MADE FROM PROPYLENE GLYCOL
ENGINE COOLANT - PROPYLENE GLYCOL-BASED - FORD MOTOR COMPANY POSITION ON PROPYLENE GLYCOL-BASED ENGINE COOLANTS
01-21-6
ELECTRICAL - REVISED MECHANICAL HOOD LAMP SWITCH TO REPLACE OLD STYLE MERCURY HOOD LAMP SWITCH
01-19-7
ENGINE - 4.0L OHV - CARBON KNOCK ON ACCELERATION
NOISE - CARBON KNOCK ON ACCELERATION - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
01-10-12
WIRING - WIRE HARNESS TERMINAL REPAIR KIT AND WIRE SPLICE PROCEDURE
01-9-7
DRIVEABILITY - HO2S (HEATED OXYGEN SENSOR), CATALYST, AND FUEL SYSTEM MONITORS - SERVICE TIPS - OBD II VEHICLES ONLY
00-26-4
MALFUNCTION INDICATOR LAMP (MIL) - MIL ILLUMINATED - DIAGNOSTIC TROUBLE CODE (DTC) P0420 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODE (DTC) P0420 STORED IN MEMORY - VEHICLES EQUIPPED WITH 4.0L OHV ENGINE ONLY
00-24-3
ACCELERATOR PEDAL BRACKET - SHEET METAL CRACKS OR FATIGUES AT DASH PANEL AREA - ALL MODELS - VEHICLES BUILT 9/1/1990 THROUGH 7/1/1999
00-23-10
TRANSMISSION - FLUID IN-LINE FILTER KIT - REPEAT REPAIRS OF TRANSMISSION - SERVICE TIPS
00-21-3
CLIMATE CONTROL - EATC - BLOWER MOTOR CONTROL SERVICE TIPS
00-8-3
NOISE - "RUBBING" FROM REAR OF VEHICLE DURING RIGHT HAND TURNS - VEHICLES EQUIPPED WITH 5.0L ENGINE BUILT THROUGH 1/5/2000
99-24-2
LOCKS - REPLACE AND/OR REPAIR ANY LOCK COMPONENT - AVAILABILITY OF INDIVIDUAL LOCKS
99-23-4
MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0442 AND P0455 - NO DRIVEABILITY CONCERNS
99-20-6
AIR CONDITIONING - BURNING ODOR OR SMOKE WHILE BLOWER MOTOR IS ON
NOISE - "RUSTLING" HEARD ALONG WITH AN ODOR WHILE BLOWER MOTOR IS ON
99-20-3
BUMPER - FRONT BRACKET REPLACEMENT - SERVICE TIP
99-15-2
TRANSMISSION - NEW TRANSMISSION FLUSH AND FILL TOOL AVAILABLE THROUGH ROTUNDA
99-11-1
NOISE - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
VIBRATION - TSB SPECIAL FOR NOISE/VIBRATION/HARSHNESS
99-10-4
MALFUNCTION INDICATOR LAMP (MIL) - MIL ILLUMINATED WITH DIAGNOSTIC TROUBLE CODES (DTCS) P0171, P0174, P1131 AND/OR P1151 STORED IN MEMORY - 4.0L SOHC VEHICLES BUILT THROUGH 1/12/1998
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH DIAGNOSTIC TROUBLE CODES (DTCS) P0171, P0174, P1131 AND/OR P1151 STORED IN MEMORY - 4.0L SOHC VEHICLES BUILT THROUGH 1/12/1998
99-8-15
INTERIOR TRIM - DOOR TRIM PANEL REPLACEMENT - SERVICE TIP
99-8-8
CLIMATE CONTROL - ERRATIC OR INSUFFICIENT TEMPERATURE CONTROL - EATC EQUIPPED VEHICLES - SERVICE TIP
99-6-5
WINDNOISE - AROUND SIDE DOOR(S) - SERVICE TIPS
99-4-3
REPROGRAMMING POWERTRAIN CONTROL MODULES (PCMS) - OUT-OF-VEHICLE - EEC V VEHICLES ONLY
99-2-3
WATER LEAKS - WINDSHIELD SEALING - SERVICE TIP
WINDSHIELD - SEALING - SERVICE TIP
98-5A-13
BRAKES - DISC BRAKE CALIPER SLIDE GREASE - NEW SPECIFICATION - SILICONE BRAKE CALIPER GREASE AND DIELECTRIC COMPOUND ONLY TO BE USED
BRAKES - DRUM - SHOE-TO-BACKING PLATE LUBRICATION - NEW LUBRICANT MATERIAL
BRAKES - PETROLEUM-BASED LUBRICANT MAY CAUSE SWELLING OF RUBBER PARTS - SERVICE TIP
LUBRICANT - SILICONE DIELECTRIC COMPOUND - NEW APPLICATION - SILICONE BRAKE CALIPER GREASE AND DIELECTRIC COMPOUND
98-5A-11
BRAKES - ELIMINATION OF SANDING ROTORS AND DRUMS - SERVICE TIP
98-5A-5
BRAKES - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT
BRAKE ROTOR MACHINING - AVAILABILITY OF HUB-MOUNT BRAKE ROTOR MACHINING EQUIPMENT
98-5A-4
BRAKES - PREVENTING BRAKE VIBRATION - SERVICE TIP
WHEELS - PROPER LUG TORQUE PROCEDURES - SERVICE TIP
98-26-2
FUEL - INFORMATION ON GASOLINE - TIPS TO RESOLVE VOLATILITY RELATED DRIVEABILITY CONCERNS
98-24-6
ELECTRICAL - NEW TERMINAL GREASE RELEASED FOR SERVICE
98-23-10
MASS AIR FLOW (MAF) - SENSOR CONTAMINATION - SERVICE TIP
98-20-19
POWER SEAT SWITCH - BUTTON COMES OFF
98-20-10
EXHAUST SYSTEM - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
NOISE - "BUZZING" OR "RATTLING" - LOOSE CATALYST OR MUFFLER HEAT SHIELDS
98-18-14
AIR CONDITIONING - WATER DRIPS ON FLOOR FROM EVAPORATOR WHEN BLOWER IS ON HIGH IN MAX A/C OR NORMAL A/C MODE
98-17-15
STEERING - DRIFT/PULL, TIRE WEAR, RIDE QUALITY - RIDE HEIGHT SETTING PROCEDURE
SUSPENSION - RIDE HEIGHT - SETTING PROCEDURE - SERVICE TIP
98-15-12
EMISSIONS - AVAILABILITY OF EVAPORATIVE EMISSION CANISTER COMPONENTS
98-14-8
BRAKES - ANTI-LOCK - ABS FALSE ACTIVATION AND/OR INTERMITTENT ABS LAMP ON WITH DIAGNOSTIC TROUBLE CODES (DTCS) 1145, 1155, 1230, 1233, 1234, AND/OR 1237 STORED IN MEMORY
BRAKES - PULLS WHEN ABS PUMP RUNS
NOISE - "GRINDING" AND/OR "WHINING" - ANTI-LOCK BRAKES - ABS FALSE ACTIVATION AND/OR INTERMITTENT ABS LAMP ON WITH DIAGNOSTIC TROUBLE CODES (DTCS) 1145, 1155, 1230, 1233, 1234, AND/OR 1237 STORED IN MEMORY
98-14-5
STEERING - "CLUNKING" FELT WHILE ROCKING STEERING WHEEL SIDE-TO-SIDE
98-12-5
AIR CONDITIONING - FILTERING REFRIGERANT AFTER A/C COMPRESSOR REPLACEMENT - SERVICE TIPS
98-11-11
TRANSFER CASE - WATER INGESTION THROUGH VENT TUBE WHILE DRIVING THROUGH HIGH WATER
98-6-10
STALL - STALLS ON DECEL WHILE ENGINE IS COLD - VEHICLES EQUIPPED WITH 4.0L ENGINE AND MANUAL TRANSMISSION
98-5-2
TIRE - TIRE COMPANY TELEPHONE NUMBERS FOR CUSTOMER ASSISTANCE
98-1-26
WIRING - LAMP OUTAGE MODULE HOUSING AND SURROUNDING PLASTIC COMPONENTS MELTED - EDDIE BAUER AND LIMITED EDITION MODELS EQUIPPED WITH MESSAGE CENTERS AND IMPROPERLY CONNECTED TOW WIRING KITS (VEHICLES BEING TOWED)
98-1-24
TRAILER WIRING - PROCEDURE FOR INSTALLING TRAILER WIRING HARNESSES - EDDIE BAUER LIMITED MODELS
WIRING - LAMP OUTAGE MODULE HOUSING AND SURROUNDING PLASTIC COMPONENTS MELTED - VEHICLES WITH MESSAGE CENTERS AND IMPROPERLY CONNECTED AFTERMARKET TRAILER WIRING - EDDIE BAUER AND LIMITED EDITION MODELS
98-1-12
TRANSMISSION - 4R44E/5R55E - NEW SERVICE PART - CENTER SUPPORT - SERVICE TIP
TRANSMISSION - A4LD - NEW SERVICE PART - CENTER SUPPORT - SERVICE TIP
97-26-21
CD PLAYER - "SKIPS" - HIGH SERIES CONSOLE - NORMAL DRIVING CONDITIONS
NOISE - "SQUEAKING" FROM HIGH SERIES CONSOLE - NORMAL DRIVING CONDITIONS
VIBRATION - HIGH SERIES CONSOLE - NORMAL DRIVING CONDITIONS
97-24-25
AIR CONDITIONING - DISCHARGE AIR TEMPERATURE DOES NOT CHANGE WHEN MOVING TEMPERATURE LEVER
97-24-13
REMOTE KEYLESS ENTRY (RKE) - DIAGNOSTIC SERVICE TIPS
97-22-17
CLUTCH - HARD TO DISENGAGE OR FREQUENT REPLACEMENT OF CLUTCH SLAVE CYLINDER - EARLY WEAR-OUT OF SLAVE CYLINDER
97-22-4
TRANSMISSION - A4LD, 4R44E/4R55E, 5R55E - TORQUE CONVERTER SLIP - DIAGNOSTIC TROUBLE CODE (DTC) 628 OR P0741 STORED IN MEMORY
97-22-1
DELTA PRESSURE FEEDBACK EGR (DPFE) - DIAGNOSTIC TIPS
97-21-15
SHUDDER OR BINDING SENSATION - IN TIGHT TURNS WHILE VEHICLE IS IN 4X4 AUTO MODE - VEHICLES BUILT THROUGH APRIL 1997
TRANSFER CASE - SHUDDER/BINDING SENSATION IN TIGHT TURNS WHILE VEHICLE IS IN 4X4 AUTO MODE - VEHICLES BUILT THROUGH APRIL 1997
97-20-15
DRIVESHAFT - U-JOINT - AVAILABILITY OF GREASEABLE SERVICE PARTS
DRIVESHAFT - U-JOINT - IDENTIFICATION OF SERVICE PARTS BY MEASUREMENT
DRIVESHAFT - U-JOINTS - IDENTIFICATION OF SERVICE PARTS BY MEASUREMENT
97-19A-1
EVAPORATIVE EMISSIONS
97-19-11
COOLING SYSTEM - "ON-VEHICLE" HEATER CORE PRESSURE TEST REQUIRED FOR WARRANTY CLAIM
97-18-9
COOLING SYSTEM - TEMPERATURE GAUGE FLUCTUATION - VEHICLES WITH 4.0L ENGINE
NOISE - "THUMPING" HEARD FROM WATER PUMP AREA - VEHICLES WITH 4.0L ENGINE
97-17-24
TRANSMISSION - 4R44E/4R55E - EXTENDED SHIFT AND ENGINE RPM ABOVE EXPECTED LEVELS OR "NO UPSHIFT" - TRANSMISSIONS BUILT BEFORE 6/20/95
TRANSMISSION - 4R44E/4R55E - O/D OFF LAMP FLASHING AND/OR DIAGNOSTIC TROUBLE CODES (DTCS) 645, 646, 647, 648, P0731, P0732, P0733, P0734
97-17-22
COOLING SYSTEM - COOLANT LEAKING FROM ENGINE BLOCK HEATER - VEHICLES WITH 4.0L ENGINE
97-17-2
REAR VIEW MIRROR - NEW PROCEDURE FOR PREFERRED REATTACHMENT METHOD
97-15-22
MALFUNCTION INDICATOR LAMP (MIL) - MIL LAMP ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTCS) P0133 AND P0153 STORED IN MEMORY - EXPLORER WITH 4.0L OR 5.0L ENGINE, AND MOUNTAINEER WITH 5.0L ENGINE
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED - DIAGNOSTIC TROUBLE CODES (DTCS) P0133 AND P0153 STORED IN MEMORY - EXPLORER WITH 4.0L OR 5.0L ENGINE, AND MOUNTAINEER WITH 5.0L ENGINE
97-15-5
AIR CONDITIONING - OIL REFILL CAPACITY CHART - SERVICE TIP
97-12-13
TRANSMISSION - C6, E4OD, AOD, 4R70W - LOW TRANSMISSION FLUID LEVEL AND/OR SHIFT AND/OR ENGAGEMENT CONCERNS - 4X4 AND AWD VEHICLES ONLY
97-11-11
TRANSMISSION - 4R70W - ERRATIC OR PROLONGED 1-2 SHIFT
TRANSMISSION - AODE - ERRATIC OR PROLONGED 1-2 SHIFT
97-11-5
REMOTE ANTI-THEFT PERSONALITY (RAP) TRANSMITTERS - REPROGRAMMING INFORMATION
97-10-5
AIR CONDITIONING - COMPRESSOR FAILURE - INSUFFICIENT AMOUNT OF REFRIGERANT OIL
AIR CONDITIONING - LACK OF COOLING - INSUFFICIENT AMOUNT OF REFRIGERANT OIL MAY CAUSE COMPRESSOR FAILURE
97-9-8
POWERTRAIN CONTROL MODULE - REPROGRAM POWERTRAIN CONTROL MODULE (PCM) - SERVICE PROCEDURES - SERVICE TIP
97-9-5
LONG CRANK - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 11/1/94 THROUGH 3/30/96
STALL - AFTER STARTING WHEN ENGINE ALLOWED TO SOAK FROM 1-4 HOURS - STICKING IDLE AIR CONTROL (IAC) VALVE - VEHICLES BUILT FROM 11/1/94 THROUGH 3/30/96
97-8-8
AIR CONDITIONING - EATC SERVICE TIPS
97-8-6
MALFUNCTION INDICATOR LAMP (MIL) - DIAGNOSTIC TROUBLE CODES (DTCS) P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, AND/OR P0308 STORED IN MEMORY
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATES - DIAGNOSTIC TROUBLE CODES (DTCS) P0300, P0301, P0302, P0303, P0304, P0305, P0306, P0307, AND/OR P0308 STORED IN MEMORY
97-4-7
FRAME - RIVET REPLACEMENT WITH BOLTS - SERVICE TIPS
97-3-14
TRANSFER CASE - BINDING OR SHUDDER - DIAGNOSTICS - VEHICLES WITH 4.0L ENGINE - SERVICE TIP
97-3-8
LOCKS - REMOTE KEYLESS ENTRY (RKE) - RKE INOPERATIVE - VEHICLES BUILT THROUGH 10/30/96
96-26-19
ENGINE - 4.0L - TORQUE-TO-YIELD (TTY) CRANKSHAFT DAMPER BOLT - SERVICE TIP
96-26-12
TRANSAXLE - TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSAXLE COOLING SYSTEM CLEANING PROCEDURES - SERVICE TIP
TRANSMISSION - TORQUE CONVERTER REPLACEMENT GUIDELINES AND TORQUE CONVERTER/TRANSMISSION COOLING SYSTEM CLEANING PROCEDURES - SERVICE TIP
96-25-24
ENGINE - 4.0L - NEW TORQUE-TO-YIELD CONNECTING ROD FASTENERS
96-24-16
VIBRATION - IN FLOOR PAN - AT WIDE OPEN THROTTLE (WOT) AND/OR STEADY HIGHWAY SPEEDS (70+ MPH) - 5.0L VEHICLES WITH ALL-WHEEL-DRIVE (AWD) - EXPLORERS AND MOUNTAINEERS BUILT IN LOUISVILLE THROUGH 7/29/96 AND/OR ST. LOUIS THROUGH 8/12/96
96-24-9
TORQUE CONVERTER - LEAK TEST PROCEDURE - SERVICE TIP
96-24-6
WIRING - ELECTRICAL DIODE IDENTIFICATION AND SERVICE REPLACEMENTS
96-23-1
STEERING - "CLICKING" NOISE HEARD WHEN TURNING STEERING WHEEL
NOISE - "CLICKING" SOUND HEARD WHEN TURNING STEERING WHEEL
96-22-5
MASS AIR FLOW SENSOR - REPLACEMENT AS AN ASSEMBLY - SERVICE TIP
96-22-1
WINDSHIELD AND INTERIOR GLASS - FOG/FILM
96-21-9
STALL - STALL ON DECEL WHEN CLUTCH IS DISENGAGED AFTER CLOSED THROTTLE ENGINE ON DOWNHILL GRADE - MAY HAVE MIL CODE P1506 STORED IN MEMORY - 4.0L MANUAL TRANSMISSION VEHICLES ONLY
ENGINE - 4.0L - STALL ON DECEL WHEN CLUTCH IS DISENGAGED AFTER CLOSED THROTTLE ENGINE ON DOWNHILL GRADE - MAY HAVE MIL CODE P1506 STORED IN MEMORY - 4.0L MANUAL TRANSMISSION VEHICLES ONLY
96-20-8
AIR CONDITIONING - NEW O-RING APPLICATIONS - THICKER O-RINGS FOR SPRING LOCK FITTINGS - SERVICE TIP
AIR CONDITIONING - SPRING LOCK COUPLING CLEANING PROCEDURE - SERVICE TIP
96-20-7
AIR CONDITIONING - NEW O-RING AVAILABILITY AND APPLICATIONS - SERVICE TIP
96-17-16
BUMPER - FRONT - PREMATURE SIGNS OF WEAR AND/OR CHROME CRACKING - VEHICLES BUILT THROUGH 2/11/96
96-15-6
AIR CONDITIONING - FILTERING REFRIGERANT - SYSTEM FLUSHING - TRACER DYE - LEAK TESTING - O-RING TOOL - TSB REPUBLICATION TO INCLUDE LATEST MODEL YEAR
96-14-13
STEERING - NOISE HEARD THROUGH STEERING COLUMN DURING PARKING LOT MANEUVERS AND/OR STOP-AND-GO OVER BUMPS - VEHICLES BUILT THROUGH 3/25/96
NOISE HEARD THROUGH STEERING COLUMN DURING PARKING LOT MANEUVERS AND/OR STOP AND GO OVER BUMPS - VEHICLES BUILT THROUGH 3/25/96
96-12-17
COOLING SYSTEM - COOLANT LEAK FROM RADIATOR IN COLD AMBIENT TEMPERATURES - VEHICLES WITH 3.0L OR 4.0L ENGINE
LEAKS - COOLANT - COOLANT LEAK FROM RADIATOR IN COLD AMBIENT TEMPERATURES - VEHICLES WITH 3.0L OR 4.0L ENGINE
96-12-9
NOISE - "CHATTER" DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING - TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR REAR AXLES
AXLE - NEW SERVICE KIT AVAILABLE FOR TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR
AXLE - TRACTION-LOK DIFFERENTIAL - 7.5 AND 8.8 INCH RING GEAR - "CHATTER" NOISE DURING TIGHT TURNS OR TURNS AFTER AN EXTENDED PERIOD OF HIGHWAY DRIVING
96-11-1
LOCKS - INTRODUCTION OF NEW LOCK DESIGN - SERVICE TIP
96-10-7
FUEL - CALIFORNIA REFORMULATED GASOLINE (CARFG) - SERVICE TIP
96-10-6
NEW GENERATION STAR (NGS) TESTER - INCORRECT INFORMATION DISPLAYED DURING DIAGNOSTIC MONITORING TEST RESULTS - VEHICLES WITH ON-BOARD DIAGNOSTICS (OBD) II
96-8-15
COMPASS - ERRATIC - VEHICLES BUILT THROUGH 2/1/96
LAMP - MAP LAMP BULB BURN OUT - VEHICLES BUILT THROUGH 2/1/96
SWITCH - MAP LAMP OPERATION ERRATIC - VEHICLES BUILT THROUGH 2/1/96
96-7-26
WIRING - TRANSMISSION INTERNAL WIRING HARNESS SERVICE - FLUID PAN CHANGE REQUIRED FOR TRANSMISSIONS BUILT BEFORE 11/30/95 - SERVICE TIP
TRANSMISSION - 4R44E/4R55E - TRANSMISSION INTERNAL WIRING HARNESS AND FLUID PAN REVISION - TRANSMISSIONS BUILT AFTER 11/30/95 - SERVICE TIP
96-7-15
LOCKS - NEW DESIGN LOCKSETS HAVE BEEN INSTALLED ON CERTAIN TRIAL VEHICLES - LIGHT AND HEAVY TRUCK VEHICLES REFERENCED - SERVICE TIP
96-7-11
TRANSMISSION - 4R70W - SPECIAL SELECTION PROCEDURE FOR LOW SERVO PISTON - SERVICE TIP
TRANSMISSION - 4R70W - UNIQUE CASE WITH LOW/REVERSE SPACER - SERVICE TIP
96-7-6
MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - CODE 0446 STORED IN MEMORY - VEHICLES BUILT FROM 12/21/95 THROUGH 2/8/96
LAMP - MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATION - CODE 0446 STORED IN MEMORY - TAURUS/SABLE VEHICLES BUILT FROM 12/21/95 THROUGH 2/8/96 AND EXPLORER 5.0L BUILT FROM 2/5/96 THROUGH 3/14/96
96-4-19
TRANSMISSION - 4R44E/4R55E - TRANSMISSION OVERHAUL AND SEAL KIT - SERVICE TIP
96-3-20
TRANSMISSION - 4R44E/4R55E - SCREEN AND GASKET SERVICE KIT - INCORRECT PARTS - SERVICE TIP
95-23-1
PAINT - 1996 COLOR CHART - AFTERMARKET SUPPLIER CROSS-REFERENCE LIST
95-21-1
SUPPLEMENTAL RESTRAINT SYSTEM - AIR BAG MODULES - DISCOLORED OR MARRED COVERS - PAINTING RESTRICTIONS
95-19-13
TRANSMISSION - 4R44E/4R55E - DIAGNOSTIC SERVICE TIP
95-18-4
AIR CONDITIONING - FORD APPROVED FLUSHING PROCEDURES - SERVICE TIP
95-16-1
SHEET METAL - ROOF PANEL AND DRIP RAIL REPLACEMENT - SEAM SEALER APPLICATION PROCEDURE
________________
TSBs found:113
__________________
Steve,
How to post photos
Old 03-01-2011, 09:57 PM   #19
gmanpaint
Torsion Bar Free
since 2010
gmanpaint's Avatar
94 XLT-95 FX4
Vehicle Specs
This is a tight nit community with nothing but helpful people on it. Your new and you get a pass from me for apologizing. Takes a decent person to admit they were wrong as you have done. I will also retract my out lash comment towards you, and apologize myself for my rude comment.
You will be amazed at how well this place really does work, just hang around for a bit, and you will see for yourself. Some thread questions are answered in seconds, some take weeks, but most get some form of help.
Give a little, take a little, that is what makes this place priceless.
__________________
The Black Hole
Pugly
Old 03-01-2011, 10:01 PM   #20
imp
Missouri Ozarks
2004 XLT
Vehicle Specs
Quote:
A gentleman, Sir, you are, and a scholar! Where T.H. is SW MO in relation to Rolla, and are sick signatures here to be tolerated by you? imp
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
