| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2014 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Milwaukee, WI
Bulb size
What is the bulb size of headlights and foglights? I get my Explorer on Tuesday so can't check manual.
#2 |
2011
HD-13/9008 I think???
#3 | |
Merced, CA
2011 XLT
Quote:
Fogs: H11 __________________ 2011 XLT - White Suede with Tan interior, Rapid Spec 202A |
#4 |
Milwaukee, WI
are the 9005 a hi/low beam bulb or is the 9005 just for low beam. If so, what is the high beam bulb?
#5 |
Augusta, GA
2011 Explorer Base
#6 |
Merced, CA
2011 XLT
Yeah, it's a projector headlight, so there's a metal piece that comes down & blocks part of the light for the low beam. When you hit the high beams, it moves out of the way, allowing all the light to shine through.
#7 |
Toyota Highlander Convert
Ottawa, Ontario area
2011 Limited AWD
You did not mention which model you have. The Limited comes with HID bulbs which I assume have different part numbers than the regular bulbs.
__________________ Peter 2011 Explorer Limited White Platinum Tri-Coat,340A (Rapid Spec 302A).Previous rides;'99 Windstar; '02,'06 & 09 4WD Toyota Highlander Limiteds |
#8 |
waukesha
93xlt
I have a limited and I did not get the HID lights. But I can say this, the lights are ok at nite, but not great. I would like it if they where about 25% brighter. I also know there are a number of bulbs to replace them, but I am not willing to damage the housing because of high heat or burned out bulbs every year or so. If anyone has an answer to this it would help.
#9 |
Milwaukee, WI
I am ordering new PIAA bulbs to replace stocks as I hate the dull yellow stock bulbs. I always buy wiring harnesses for aftermarket bulbs to help with your concern of aftermarket bulbs producing more heat. These harnesses can withstand much higher temps. Harnesses cost about 12 bucks for a pair on ebay.
As for the HID's. Those are not standard on Limited. Quite a hefty upgrade. Wish I had the money for those but you can get them from Ford later on so perhaps I will save up. |
#10 | |
2011 Limited AWD
#11 |
New Jersey
2011 XLT / 11 Edge Sport
So is it 9005 or HD13 or 9008?
#12 |
Milwaukee, WI
Headlights: 9005(HB3)
Fogs: H11 Just installed new bulbs for both headlights and fogs tonight. I hate stock dingy yellow bulbs. I put in 8000K for headlights and 2500K yellow bulbs for fogs. I know the pics suck. Doesn't do justice. So much whiter and brighter than OEM. As far as installation. Was tricky. The headlights are really akward and luckily I have little hands. Fogs same. I barely fit under the car and had to go under from the front and center cause of the low hanging plastic. Had to unscrew 1 screw on each side to move plastic covering area where fog is. Once the screw is out, the fogs install is easier than headlamps. I could change all 4 bulbs in my Dodge Nitro in like 10 min. This took me over an hour. Bulbs better last. http://i4.photobucket.com/albums/y14...e/DSC_0118.jpg http://i4.photobucket.com/albums/y14...e/DSC_0119.jpg http://i4.photobucket.com/albums/y14...e/DSC_0120.jpg http://i4.photobucket.com/albums/y14...e/DSC_0121.jpg |
#13 | |
Victoria, BC
2011
Quote:
#14 |
Santo Domingo
2011 XLT
I got aftermarket HID for both Headlights and Fogs. Good HID wont damage the housing and improves the visibility a lot! I got it really cheap, like about 140 bucks and looks really nice.
** Watch out for HID fog lights. They can be annoying for oncoming traffic. I did it cuz they are not regulated in my country. |
#15 |
Victoria, BC
2011
Did you have to use a different wiring for the hids? I read due to heat you may need a diff wiring harness.
#16 | |
Oklahoma City
2011 LIMITED 4WD
Quote:
__________________ 2011 Limited 4WD, 301a, tow, BLIS, sterling grey/stone; ordered 12-30-10, Built 3-17-11, Delivered 4-13-11. |
#17 |
Santo Domingo
2011 XLT
#18 |
B
pittsburgh
2011 Limited 4wd
Most Hids are are 35w as opposed to the 9005 i believe being 65w. Initial firing of the Hid's go up a little I dont remember the spec off hand. But the hids will draw less current...
The 9005 bulb is actually used as the high beam in most 4 bulb systems. |
| Thread Tools | |
