Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
Just replaced Tranny modulator, now i got shifting problems - HELP!
Reply
Thread Tools
Old 02-15-2011, 05:07 PM   #1
T3hN1cksta
Las Vegas, Nevada
1994 Explorer Xlt 4x4
Vehicle Specs
(Original Poster)
Dk Exp Just replaced Tranny modulator, now i got shifting problems - HELP!
Today i replaced my Vacuum modulator on my transmission and before i replaced it the car shifted flawlessly, the old modulator was leaking so i was losing fluid, and today i installed the new modulator and now it shifts really wierd. Heres what happens : it'll shift from 1st to 2nd, and then at around 15mph while accelerating it'll downshift and then it'll shift into 2nd again. I topped off my tranny fluid level after installing the new modulator (yes i put the original pin into the new modulator) and ive checked the vacuum line and its connected on both ends. Anybody know what could be causing this? I really dont want to end up burning my tranny out
T3hN1cksta is offline   Reply With Quote
Old 02-15-2011, 06:57 PM   #2
mrjoe16
Mojave, ca.
1994 XLT
Vehicle Specs
Im still new to the transmission thing but as I have red in this forum you have to readjust the bands. Im not sure what the torque spec is and how much you need to back them off and lock down the lock nut. If you do a search on band adjustments youll get it shifting smooth.
mrjoe16 is offline   Reply With Quote
Old 02-15-2011, 07:05 PM   #3
bcbid
U.S. Marine
,MI
bcbid's Avatar
1993 Eddie Bauer (4X4)
Vehicle Specs
I posted this in the other thread. Have you checked your engine oil? when my modulator went bad . That is where the tranny fluid went. Mine worked fine after I changed it.
__________________
PAIN IS WEAKNESS LEAVING THE BODY,U.S.M.C., SEMPER FI...Brian
This is "Bouncing Betty", my 1993 Explorer.....
http://www.explorerforum.com/photopo...1721&protype=1
1993 Eddie Bauer (4.0 stock)
bcbid is offline   Reply With Quote
Old 02-15-2011, 09:33 PM   #4
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Did you clean the bore with a wire brush, and WD-40 prior to installing the new modulator? Is the new modulator adjustable or non adjustable? Did you clean the vacuum line with Seafoam?
BrooklynBay is online now   Reply With Quote
Old 02-15-2011, 09:41 PM   #5
T3hN1cksta
Las Vegas, Nevada
Vehicle Specs
(Original Poster)
Its not leaking into my engine oil, it was leaking into the vac hose and going to my intake
I didnt clean the bore or vac hose before installing the new modulator. and Im pretty sure that my modulators non-adjustable. Would cleaning out the bore/ vac hose effect how the tranny shifts?
Old 02-15-2011, 09:51 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Everything has to be free of old fluid since old fluid is sticky, and attracts dirt. The pin & spool might bind if it's contaminated. Transmission fluid was drawn into the engine through the vacuum hose.
The adjustable modulator has a thumb wheel adjustment. Does the new modulator have a very small opening where the vacuum line goes? If not, then it's a C3 modulator which is the wrong part.
Old 02-16-2011, 09:08 AM   #7
DV8
Cedar Grove, WV
94 XLT
Vehicle Specs
also, did you replace your mod valve with an adjustable aftermarket one? if it is, it will have a screw in the end near the vacuum connection. try adjusting the little screw, which is a real pain to get to with the valve on the trans. i had the same problem, and that is what i did to fix the problem.
__________________
94 XLT 260,000 4.0L auto, with original engine and trans. MODS: Mile Marker manual hubs. ACCESSORIES: custom interior green dome lights, air freshener, two car seats.
95 Nissan Altima GXE 250,000 2.4L 5spd with original engine and 2nd trans. All stock, runs with a 2003 rustang gt
a big enough hammer fixes anything
DV8 is offline   Reply With Quote
Old 03-14-2011, 06:29 PM   #8
T3hN1cksta
Las Vegas, Nevada
Vehicle Specs
(Original Poster)
DV8, which way did you turn yours? We adjusted mine clockwise and its doing the same thing still, should i try adjusting it the other way? Counter clockwise was for rough shifting, and clockwise was for soft shifting/slipping (which is what we adjusted mine to, its adjusted to the max 4 turns, we did it in intervals, 2 turns then tested, 3 turns then tested, and 4, and its still doing the same thing)
Old 03-14-2011, 08:40 PM   #9
DV8
Cedar Grove, WV
94 XLT
Vehicle Specs
i dont remember which way i had to turn it, but if it really made no difference, you may have a faulty valve. it does happen. i can personally attest to that, as i sell parts for a living.
__________________
Old 03-14-2011, 11:20 PM   #10
T3hN1cksta
Las Vegas, Nevada
Vehicle Specs
(Original Poster)
It did effect how its shifting, but it didnt fix the problem with my tranny shifting back into 1st gear halfway thru 2nd gear
Old 03-17-2011, 10:44 PM   #11
T3hN1cksta
Las Vegas, Nevada
Vehicle Specs
(Original Poster)
Update: yesterday i came outside to get in my car and i noticed a large puddle of fluid underneith my car, upon further inspection its leaking large amounts of transmission fluid from somewhere around the modulator, and now every time i turn the car off within 15-20 minutes a large puddle (about as big as a sheet of printer paper) will appear underneith my car,could this have been caused by us adjusting the modulator??
__________________
1994 Xlt 4x4 Stock 4.0l w/ a4ld tranny
Old 03-18-2011, 12:45 AM   #12
BrooklynBay
Brooklyn, NY
Vehicle Specs
Check underneath to see where it's leaking from.
Old 03-19-2011, 12:41 AM   #13
T3hN1cksta
Las Vegas, Nevada
Vehicle Specs
(Original Poster)
I found where it was leaking, one of the pan bolts became really loose, tightened it up (and made sure the rest were tight) and it fixed the leak.
__________________
Old 03-19-2011, 12:57 AM   #14
T3hN1cksta
Las Vegas, Nevada
Vehicle Specs
(Original Poster)
Does the pin in the modulator have to go set in a specific spot inside the bore of the transmission? because everywhere ive taken it everyones said check to makesure i re-installed the pin, and i did. When i re-installed the modulator i placed the pin in the modulator and installed it that way, does the pin have to seat in a certain spot/position in the bore?
__________________
Old 03-20-2011, 01:37 AM   #15
BrooklynBay
Brooklyn, NY
Vehicle Specs
The pin has to go into the modulator first.
Reply
Tags
1994, 4x4, explorer, modulator, xlt
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
