Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Ford Explorer Sport Trac Forums > 2001-2005 Explorer Sport Trac
Notices
2001-2005 Explorer Sport Trac All questions related to the 2001-2005 Explorer Sport Trac model.
05 Sport Trac brake problem
Reply
Thread Tools
Old 02-22-2011, 08:20 AM   #1
myata92
Fargo, ND
1998 Mercury Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hello, I have an 05 Sport Trac with a serious brake problem. My front passanger side caliper is locked up onto the rotor and won't release. The real problem is it just did that and I bought and replaced the caliper with a new one two weeks ago. When I changed it out last time I also replaced the brake pads and rotors on both sides on the front and just the new caliper on the passanger front side, which is where the problem is again. I also flushed and rebled the whole brake system with fresh brake fluid. During those two weeks it worked fine with no signs of problems but all the sudden it locked up again. The way it feels is if I had engaged the emergency brake on that wheel. Could I have just gotten a bad caliper or is there any other problem I should be looking at?
myata92 is offline   Reply With Quote
( Join the Elite Explorers )
Old 02-22-2011, 01:54 PM   #2
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
'94 F150 4x4 SWB 4.9L
Vehicle Specs
Quoted: 28 Post(s)
Unscrew the hose from the caliper and see if it releases. Sounds like the inside of the hose has come apart and blocking the return of the fluid. Not uncommon problem but it is for an '05. If that doesn't release the piston pressure it's a bad caliper, binding internally.
__________________
'14 Transit Connect 2.5L 16 Valve DOHC Duratec
'02 Escape XLT 3.0L 24 Valve DOHC Duratec 160k
'94 F150 4x4 4.9L/5-speed 160K miles,
How to post photos
ncranchero is offline   Reply With Quote
Old 02-22-2011, 04:14 PM   #3
myata92
Fargo, ND
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Well now I went out and messed with it some more. It unlocks when I go in reverse and stays that way until I put it in drive and as I am moving forward I hit the brakes and than it locks up again and won't release until I put it in reverse and drive backward again. I will check the brake line like you mentioned tonight as well.
Old 02-22-2011, 07:04 PM   #4
ncranchero
Co-moderator
Denver,NC
ncranchero's Avatar
Vehicle Specs
Quoted: 28 Post(s)
That's crazy........ If it was drum brakes I could understand that. Are you SURE you seated the caliper back into the mount correctly, and it's not loose on one end and binding?
__________________
How to post photos
Old 02-22-2011, 08:01 PM   #5
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
I would ck over wheel bearings, caliper brackets etc.
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Reply
Tags
brake, caliper, front, locked up, passanger
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
