| 2007 - 2010 Explorer Sport Trac All questions about the stock 2006- 2010 Ford Explorer Sport Trac. |
Thread Tools |
#1 |
Wannabe Elite Explorer
New Jersey
2007 Sport Trac Limited
3000lb+ boat tow with v6?
Hey guys..have an 07 with the 4.0 that i'm going to be using to tow my 2400lb 21' Chris Craft .with the trailer and fuel and gear that total weight could be 3500lbs give or take. i'll prob be towing it under a dozen times this summer about 30min to an hour each way. Should i make any mods to my truck before doing so..such as tranny cooler etc? There are some wicked hills around the lake and i'm going to wish i had a v8 but it is what it is..even though ford limits the truck at 5500lbs,i want to avoid burning up my trans. what do you think?
#2 |
Sparta,Ga
08 Sport Trac Adrenalin
I would recommend a trans cooler when towing anything that heavy. Me personnally, if my vehicle did not have anything other than the cooler in the lower portion of the radiator, I installed an auxillary cooler. Towing generates a lot of heat.
#3 |
Sport Trac Moderator
Pittsburgh, PA
'08 Sport Trac
Look at what hitch you have too. A Class II is standard and good for 3500 lb. so you'd be pushing the limit of the hitch but not the truck. If you have the factory Class III then it will be fine.
__________________ '08 Sport Trac, Gibson exhaust, K&N, Firestone Destination A/T's, Steelers regalia. "It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776 |
#4 |
E TN
2007 ST XLT 2WD
check your brakes on a regular basis as well with that much weight and the mountains.
#5 |
New Jersey
ok thanks guys.. i'm starting to think my v6 is going to be too weak to tow the boat, ecspecially going up hill off a stop. it seems like it would take forever to get up to speed..guess i wont know til i try
#6 |
Pittsburgh, PA
'08 Sport Trac
This was around 3000 lb., I didn't have any trouble with it on a 400+ mile tow. Moved my kids to my house from their mother's three years ago, it was packed inside. Only got about 12 mpg though.
#7 |
sw fla
2007 xlt
FWIW: I tow a 21' Seacraft in the same weight range, and I have no problems. It's not the towing...it's the stopping. Be sure and allow for plenty of space if the trailer does not have brakes.
#8 |
Pittsburgh, PA
'08 Sport Trac
Very true. Normally I just tow my jetski, with the trailer it's about 1000 lb with a full tank of gas and I will say that the Sport Trac stops with it WAYYY better than the Ranger I had before. Gotta love 4 wheel discs.
#9 |
New Jersey
thanks for the replies and pic. did you guys have a trans cooler installed first? do you have v6's or 8's? that can be night and day
#10 |
sw fla
2007 xlt
I am towing with a V-6 no cooler.
#11 |
Pittsburgh, PA
'08 Sport Trac
They already have a tranny cooler. If you are going to regularly tow long distances you should probably get a bigger one though. Mine is a V6.
Generally you want to switch the Overdrive off when you are towing. Otherwise it will shift back and forth a lot which builds up heat in the tranny. __________________ '08 Sport Trac, Gibson exhaust, K&N, Firestone Destination A/T's, Steelers regalia. "It is not the multitude of ale-houses that occasions a general disposition to drunkenness among the common people; but that disposition arising from other causes necessarily gives employment to a multitude of ale-houses." -- Adam Smith, 1776 |
#12 |
B
AZ
2008 Sport Trac XLT
JohnnyO - you got a V6 with no cooler, but what hitch were you using to move your kids back home? Class 2 or 3?
The only towing I've done with my V6 - no cooler (Class2), was pulling a Honda Civic to a body shop on a tow dolly. |
#13 |
Pittsburgh, PA
'08 Sport Trac
I used the factory Class 2. It is good for 3500 lb.
#14 |
B
AZ
2008 Sport Trac XLT
Thanks for the info. I think my biggest concerns always have to do with exceeding the tongue weight.
#15 |
Cleveland, OH
'07 Sporttrac
Welded on Class II
Hey folks, need some help. Bought a 23' dual axle travel trailer (3300 lbs) to replace a pop-up camper. Current class II hitch is welded to the rear of the frame rails. New trailer has larger hitch ball. Dealer was going to install Class III hitch but since the old one is welded on how do I proceed? V6 Auto engine/tranny.
#16 | |
Pittsburgh, PA
'08 Sport Trac
#17 |
Cleveland, OH
'07 Sporttrac
Thanks Johnny. I'm taking it to a custom truck place this week.
#18 |
Pittsburgh, PA
'08 Sport Trac
No prob. A 23' dual axle should really have a weight equalizing hitch, which means a Class III or IV hitch with a 2" receiver. IF you can find a shop that will do it, you can cut the Class II off the crossmember and weld on a Class III receiver in its place without replacing the whole crossmember. The crossmembers are no different between the factory Class II and Class III hitches.
| Thread Tools | |
