Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2002 - 2005 Explorer Mountaineer 3rd Generation > Stock 2002 - 2005 Explorers
Notices
Stock 2002 - 2005 Explorers Questions related to non-modified 2002 - 2005 Explorers and Mountaineers. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. Sport Trac and Sport use the 1995-2001 forum.
Seat belt buckle wire disconnect and 51 air bag code
Reply
Thread Tools
Old 02-27-2011, 11:44 AM   #1
soccerman600
KC, KS
2004 Explorer XLT
Vehicle Specs
(Original Poster)
I have a 2004 Ford Explorer XLT. My seat belt buckle monitor would not turn off. I read the forums on how to shut it off, but the sensor inside the buckle would not register the buckle and unbuckles. So....I also read that you could disconnect the wire leading out of the belt under the seat. I did this and the monitor finally stopped beeping. But....now the air bag light is on and giving a 51 code. How can I fix this new problem? Is this wire being disconnected a real problem or can I have the light turned off and still drive with confidence that the air bag will work properly? Thanks for helping.
soccerman600 is offline   Reply With Quote
Old 02-27-2011, 03:46 PM   #2
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Welcome to the forum!!
I'm not sure, but I believe that if the airbag light is on then the system will not operate as expected in the event of a crash. Hopefully someone with more knowledge will chime in. Sorry I couldn't be more help.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is online now   Reply With Quote
Old 10-05-2011, 11:37 AM   #3
favila
Los Angeles
2003 Explorer Sport
Vehicle Specs
Quote:
Did you ever find a solution to this problem? I'm having the same problem right now and can't seem to find a fix.
favila is offline   Reply With Quote
Old 02-27-2013, 03:36 PM   #4
ke5efr
Myrtle Beach, SC
2003 Ford Explorer XLT
Vehicle Specs
Red Exp problems?
i have an 03 explorer and I was having the same code, but it was because of the buckle sensor being unplugged. the only way to make that go away is to replace the buckle, or plug it back in and find a way to deactivate the monitor.
if you have an elmscan 327 (i think) then download FORscan software to scan all the sensors in the car.
ke5efr is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
