#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger - Computers, Chips, Tuning > EEC V
Notices
P0301, P0302, P0303, P0172 and P0174 codes.
Reply
Thread Tools
Old 03-02-2011, 10:25 PM   #1
David704
stewd100@aol.com
stewd100@aol.com
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hey Folks
I need some help. 2000 Explorer 4.0 s.o.h.c. I have codes 300 multi cylinder. 301,302,303 p0172 and p0174. I have changed the upper and lower intake gaskets. I have replaced the all 4 O2 sensors and fuel filter and checked pressure while driving stays around 65. Engine runs rough and check engine light flashes. If someone could offer any information I would be forever grateful.
Thanks
Dave
David704 is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-02-2011, 10:40 PM   #2
boominXplorer
Elite Ranger
Virginia Beach, Va
boominXplorer's Avatar
00 4x4 Mounty
Vehicle Specs
Quoted: 176 Post(s)
Timing chain guides are gone and letting the chain slack causing missfires. You also can only get to the front one with the engine in the truck. To replace the rear chain guides you must pull the engine .
__________________
2002 F250 Crew Cab SB 7.3 Diesel 4x4 - 4" MBRP exhaust, AIH delete, SCT Livewire
2001 Ranger ext cab 4x4 - 5.0 swap, 4406, 35s, 4.88s and 9" lift
2007 Ford Focus ST Black - Stock DD
2002 Explorer 4dr for Parts
My eBay auctions
boominXplorer is online now   Reply With Quote
Old 03-02-2011, 10:41 PM   #3
lynchy wa
Down Under Beer Explorer
Albany, Western Australia
lynchy wa's Avatar
2008 ford falcon XR8 ute
Vehicle Specs
Quoted: 11 Post(s)
G'day Dave, the only thing I can think of, (which isn't saying much) is cleaning the MAF sensor and throttle body (use the dedicated cleaner for each if you try this). You could also try searching for the problem's you're having in the search bar at the top of the page. Hope this help's.
Well Boomin know's, so disregard my bull s*** but welcome
__________________
Me-Greg Lynch, She UmaII 2008 XR8 ute, red heeler alarm of course! 360 rwhp 5.4 litre, staggered 20" 275 & 245 tires, custom twin 2.5" exhaust, hooker mufflers an ol'skool H pipe, K&N filter, slammed. Last of the Aussie hand built V8's.
My wagon Uma SOLD
lynchy wa is offline   Reply With Quote
Old 03-03-2011, 12:05 AM   #4
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 380 Post(s)
Welcome to this forum! I've renamed your thread, and moved it into the EEC-V section.
BrooklynBay is offline   Reply With Quote
Old 03-03-2011, 06:38 AM   #5
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
Sounds like it jumped time
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 03-03-2011, 07:04 AM   #6
2000StreetRod
Greenville, SC
2000StreetRod's Avatar
00 Sport FI,03 Limited V8
Vehicle Specs
Quoted: 45 Post(s)
compression check
Misfire sources are: ignition, air/fuel ratio, compression. Your misfire codes are just for the cylinders in bank 1 (passenger side).
P0172 indicates bank 1 is too rich while P0174 indicates bank 2 is too lean. Make sure that your pre-cat O2 sensors for bank 1 and 2 are not cross connected (left sensor going to right PCM input, right sensor going to left PCM input).
I suggest that you perform a compression check to eliminate the right timing chain as a possible source of the misfires.
2000StreetRod is online now   Reply With Quote
Old 01-10-2012, 10:35 AM   #7
NJFord
NJ
2003 Sport Trac
Vehicle Specs
Quoted: 0 Post(s)
Ever resolve this? Having the same exact issue.... Cleared the 0171 and 0174 with a new PCV line but still getting the 030x's and a nice tapping
UPDATE: Pulled timing cover and passanger side tensioner/guide on my Crank to Jackshaft chain was wasted. Ordered a new one at dealer and hoping to put in tmrw. It appears from reading ALL OVER this site that P0300,1,2,3s are a result of timing chain issues be it a bad cassett, guide or tensioner. Look around if your having this issue. There are some awesome guides with pics to walk you through the job.
NJFord is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
