Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
big block 93 explorer
Reply
Thread Tools
Old 06-22-2012, 11:58 AM   #81
pat3
vancouver washington now i reside in hawaii
91 xlt 4 door 13inch lift
Vehicle Specs
(Original Poster)
Well shit now I have to go look and see if I've got 60 s or 80 s I'll let you know
pat3 is offline   Reply With Quote
Old 06-22-2012, 12:04 PM   #82
pat3
Vehicle Specs
(Original Poster)
They are 60s
Old 06-22-2012, 12:09 PM   #83
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
Quote:
60 sounds more realistic and even at that they are to big.you wouldnt even get above like 40% on those.60 are good for 700-800hp on the 4.0 specs even with lots of boost.the 4.0 block cant handle but 15-20lbs of boost so there is NOOOO WAY you will make over 400hp and pretty sure they say the block is only good to 350hp. Im making about 330ish at the crank and i have 36lbs injectors running 9.9lbs of boost and they are no where near 85%.but thats what your using so good luck,sure they will work but are over kill
__________________
92 xl 5.5"duff arms,3"BL,PJ 36x14.50,wrapped headers,side dump exhaust,.20 over,HF oil pump,422cam,45cc 95tm p+p 10.67:1 heads,p+p lower manifold,75mm TB,90mm maf,36lbs injectors,P+P GM M90 Supercharged & intercooled!!SCT tuned!!electric fan,4.88s aussie locked front & back!!next NOS&W/M
http://www.explorerforum.com/forums/...=double+vision
jd4242 is offline   Reply With Quote
Old 06-22-2012, 02:53 PM   #84
pat3
Vehicle Specs
(Original Poster)
Well guys if trick flow put out a set of heads would y'all buy them
Old 06-22-2012, 02:58 PM   #85
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
If they was aluminum and had much LARGER valves,i would consider.
__________________
Old 06-22-2012, 03:27 PM   #86
dking
Winterville,NC
dking's Avatar
1992/2000 Explorer XLT
Vehicle Specs
subscribing
dking is offline   Reply With Quote
Old 06-22-2012, 03:27 PM   #87
pat3
Vehicle Specs
(Original Poster)
Well they are concitering making a set for me but if their is demand it will help more. Can we start a poll of some kind
Old 06-22-2012, 07:41 PM   #88
mr cribb
Eufaula, OK
mr cribb's Avatar
92 4dr 5spd 2WD
Vehicle Specs
Depends on the price.
__________________
Jeremy Cribb, SGT, U.S. Army Retired 2002-2013. Iraq Veteran 2005-2006
Engine down for a while.... awaiting money for bottom end rebuild
I collect license plates.... PM me if you have some up for grabs....
mr cribb is offline   Reply With Quote
Old 06-23-2012, 10:09 PM   #89
arco777
Anchorage, AK / Little Rock AFB, Arkansas
arco777's Avatar
2x 1994 4x4
Vehicle Specs
Quote:
Originally Posted by jd4242 View Post
You better check your math!!your way off!! There is NO WAY you would even get close to 85% with 40lbs!!its just not possible to make that much power or need that much fuel with a v6 block!!
I thought he was running a 460? I can't find the post where he said he was building a 4.0... now I'm confused.
Sweet Explorer project though!!
__________________
-1994 Explorer 2DR 4x4 - EE swaybars/shocks, Optima Yellow Top, modified throttle body, exhaust, intake. Paxton supercharger on the workbench...
-1994 Explorer 4DR 4x4 - exhaust, brush guard, modified throttle body, intake, 2" lift, 31.5" tires on 16" Sport Trac wheels.
-1989 Taurus SHO
-2008 Mustang GT Bullitt #5560 - Tuned
arco777 is offline   Reply With Quote
Old 06-23-2012, 10:10 PM   #90
arco777
arco777's Avatar
2x 1994 4x4
Vehicle Specs
If Trick Flow made a set of heads for the 4.0 that would improve power even with a mostly stock motor, then yes, I'd be interested in buying.
Old 06-23-2012, 10:15 PM   #91
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
He's talking about his next build.
__________________
Old 06-23-2012, 10:17 PM   #92
jd4242
va beach
jd4242's Avatar
92 SC
Vehicle Specs
Well the gold one is comming soon finally got the heads back and the machine shop called yesterday the block is done.
The list on it right now is
Si stainless valves
Comp duel springs
Comp ls retainers
Arp rod bolts
Arp head studs
Sbc pistons
Comp cam
90 mm maf
80 pound injectors
And so on I'll get deep in it latter wait till you see the home made aluminum tunnel ram
80lbs INJECTORS!!!!WTF thats not going in the v6 is it??
Yep Shure is along with the t56
__________________
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
