Go Back   Ford Explorer and Ranger Forums "Serious Explorations"ģ > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1995 - 2001 Explorer Ranger Mountaineer - Sport thru '03 - 2nd Generation > Stock 1995 - 2001 Explorers
Notices
Stock 1995 - 2001 Explorers Questions related to non-modified 1995-2001 Explorer, Mountaineer, Ranger and '02+ Sports and Sport Trac. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
Automatic transmission oil pan with a drain plug.
Reply
Thread Tools
Old 03-07-2011, 08:37 AM   #1
2000co
Denver, CO
'05 Mountaineer V6 AWD
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
Anyone know where i can buy automatic trany oil pan with drain plug? Itís for 2000 XLT 4x4 V6 OHC.
Iím going to change fluid and filter and decided to add drain plug to make life easier.
2000co is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-07-2011, 09:16 AM   #2
BrooklynBay
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Quoted: 427 Post(s)
http://www.yourcovers.com/transpan_9614-2.php
BrooklynBay is online now   Reply With Quote
Old 03-07-2011, 09:26 AM   #3
2000co
Denver, CO
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
Pricey, anyone sell cheaper?
Old 03-07-2011, 11:18 AM   #4
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
Install a drain plug in your current pan. It will be much cheaper.
Old 03-07-2011, 11:35 AM   #5
2000co
Denver, CO
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
I like the drain plug idea but im worried it will leak.
Anyone try the oil pan you suggested on 2000 explorer sojc 4x4? I called the company and they were not sure if i have the clearance for it
Old 03-07-2011, 09:14 PM   #6
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
They mentioned that there is a clearance issue on some vehicles since their pan is so deep. You could solder a 1/2 X 20 nut inside of the pan, and use a magnetic drain plug with a gasket. I've done this before, and I know that it doesn't leak like the drain plug kits. Check # 75 in my list of useful threads.
Old 03-08-2011, 09:36 AM   #7
2000co
Denver, CO
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
Thanks for the write up!
Can you direct me to how to write up for transmission oil and filter change for my truck? Also, what trany oil you recommend to use?
Old 03-08-2011, 10:36 AM   #8
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
You have to remove the pan bolts, then drop the pan, and remove the gasket & filter. Be careful not to strip the aluminum case when you replace the pan bolts. A torque wrench is recommended, but an ordinary wrench could be used it you're careful. Don't use silicone on rubber gaskets. Mercon V ATF is the proper fluid to use.
Old 03-08-2011, 01:12 PM   #9
2000co
Denver, CO
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
Where did you bought the drain plug? Autozone selling one but im not sure if it's good
Old 03-08-2011, 09:55 PM   #10
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
A drain plug is a drain plug (unless it's the over sized type). The drain plugs in Autozone should be fine. I still have a bunch of them sitting around that I bought a while ago.
Old 03-08-2011, 10:07 PM   #11
2000co
Denver, CO
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
Sounds good, thanks
What filter and gasket you recomend? i call the dealer and they want 4 time more then Autozone. Is it ok to buy these parts at Autozone?
Old 03-08-2011, 10:12 PM   #12
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
Don't get any cork gaskets. A rubber gasket is reusable, and doesn't need any silicone. The neoprene gaskets are good too, but you will need to apply a sealant such as Indian Head sealer or silicone. You could make your own gasket out of high temperature rubber gasket material from a plumbing supply. Check # 91 in my list of useful threads: http://www.explorerforum.com/forums/...d.php?t=240437
Old 03-11-2011, 06:29 PM   #13
2000co
Denver, CO
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
I decided to go to drain plug and take it to a friend to weld it. Do you think I need to prime and paint the welding against rusting?
Old 03-12-2011, 10:53 PM   #14
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
Not necessarily. Solder works fine if you want to do it yourself instead of welding it.
Old 03-13-2011, 12:16 AM   #15
2000co
Denver, CO
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
Thank you very much for all your help!!
I drop the pan and created a huge mess on the floor but i added the drain plug so next time it will be cleaner. Per the book i added 4 quart of new oil and Iím planning on draining it every time i do and oil change. I know itís over kill but for $20 I donít mind.
Old 03-13-2011, 12:33 AM   #16
BrooklynBay
Brooklyn, NY
Vehicle Specs
Quoted: 427 Post(s)
Thanks for the update! Did you use a magnetic or non magnetic drain plug?
Old 03-13-2011, 10:21 AM   #17
2000co
Denver, CO
Vehicle Specs
Quoted: 15 Post(s)
(Original Poster)
I use the magnetic plug
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
