Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Stock 1991 - 1994 Explorers
Notices
Stock 1991 - 1994 Explorers For questions related to the base Ford Explorer. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications. No modification questions.
No Resonator on Exhaust
Reply
Thread Tools
Old 03-07-2011, 05:41 PM   #1
beauboy
Jacksonville, FL
1991 Ford Explorer XL
Vehicle Specs
(Original Poster)
Here's one for you exhaust experts -
I recently had my muffler and exhaust replaced on my '91 Ex. Each time previously that I had to replace it, the exhaust pipe rusted away from the resonator (juice can-looking thingy). Well, this time, the shop decided to install an exhaust pipe without a resonator, explaining that mufflers are much better than they were 20 years ago, so I shouldn't need a resonator. Made sense to me.
But in driving for the past week, I noticed that I'm going through gasoline a lot faster than before. My mpg looks like it's dropped off a few.
Question - does the presence of a resonator, or the absence of one, effect my gas mileage? Is there a deal here having to do with more or less backpressure?
I just don't know, so I'm looking for input.
Thanks in advance.
beauboy is offline   Reply With Quote
Old 03-07-2011, 06:07 PM   #2
Jason94sport
South FL
93 Sport 2WD 5 speed
Vehicle Specs
With it off it makes the exhaust free flowing. More air out of your engine. It could decrease gas mileage a little. You may be just on the gas more & don't realize it as well.
Jason94sport is online now   Reply With Quote
Old 03-07-2011, 06:15 PM   #3
beauboy
Jacksonville, FL
Vehicle Specs
(Original Poster)
Not on the gas more. I'm not a teenager, nor a new explorer owner. This one I bought brand new back in '91 and haven't been in a hurry for more than 10 years.
Could I attach a resonator to the end of the tailpipe to restore mpg?
Old 03-07-2011, 06:35 PM   #4
johnvosh
Stony Plain, Alberta
'93 Sport
Vehicle Specs
Just out of curiosity, when did you last replace your o2 sensors? From reading on this site it almost sounds like your o2 sensors may be going out and it just happened to coincide with your exhaust replacement.
__________________
Johnny V
2010 Chevrolet Cobalt LT, 2 door, 5spd, silver, loaded
2013 Ford Mustang GT| 5.0L| 6-spd| Magnaflow cat-back exhaust| NAV, backup camera| GT Performance brake pkg|Recaro's| Sterling Grey
johnvosh is offline   Reply With Quote
Old 03-07-2011, 07:06 PM   #5
beauboy
Jacksonville, FL
Vehicle Specs
(Original Poster)
That's a bit of a stretch, john. I haven't changed my O2 sensors for quite a while - because I haven't needed to. An engine analysis (which I do at regular intervals) would've showed a faulty sensor. Coincidences don't happen as often as people might think.
Old 03-07-2011, 07:48 PM   #6
Jason94sport
South FL
Vehicle Specs
Hell no need to be so arrogant. Damn dude we are suggesting things.....
Old 03-08-2011, 12:21 AM   #7
Anime
GREEN SCREAM!!
Hattiesburg, MS
Anime's Avatar
'93 Sport 4x4
Vehicle Specs
The presence or absence of a resonator shouldn't affect mileage in the slightest, at least usually. Resonators are usually straight-through mini mufflers (like glasspacks or race bullets), though some with internal louvres (instead of holes) do restrict exhaust flow. In this case, going from a restrictive resonator to a good flowing pipe might improve mileage by reducing backpressure.
Indirectly, the lack of a resonator usually allows a bit more of a performance tone, so sometimes it might be the staying on the gas to generate that exhaust note that uses more fuel. If you've been driving the same and haven't noticed any difference other than the mileage drop, something else might be to blame.
Most mufflers and pipes for the '91-92 are pretty decent (usually 2.25" all around) and flow what the 4.0 needs, so MPG shouldn't be affected unless something was changed. The factory systems just used a resonator (and some shop-installed systems add one on) since there is a bit of drone in free-er flowing systems on these. I have a '91-92 Dynomax catback with a Super Turbo and the 2.25" pipe on there and it does drone a good bit at 1700-1900 RPM. A resonator would likely mellow that out.
What sort of exhaust system is on there? If the new pipe is smaller (say 2 inches instead of 2.25"), or has crush-type bends, it might be more restrictive than the previous one. If a new muffler was used, it might flow worse than the old one. I have seen some pretty crazy muffler designs that choke the 4.0 with trying to stick the flow through a 1/2" hole. They are quiet, but torque, power, and mileage all suffer for it. You may want to measure/eyeball the pipe and be sure it's the correct size (2.25") and isn't cheap crushed stuff at the bends, or inquire with your exhaust shop as to what they used previously and what they use now to try and account for the difference.
My suggestion for the pipe for the '91-92 would be the Dynomax one. It's 2.25" with mandrel bends, costs about $40, and has the hangers on it like the OE type pipes. It even works along with Walker's non-Dynomax Quietflow3 muffler instead of the Super Turbo.
__________________
"I think man has always gone where he has been able to go, and I think that when man stops going where he can go, he will have lost a lot. Man has always been an explorer. To me, there's a fascination in thrusting out and going to new places. It's like going through a door because you find the door in front of you." - Michael Collins
Anime is online now   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
