#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 2006 - 2010 Explorer Mountaineer 4th Generation > Stock 2006 -2010 Explorers
Notices
Stock 2006 -2010 Explorers Stock 2006 -2010 Ford Explorer Forum. Problem solving, maintenance, TSB, service bulletins, owner reviews, specifications.
"Powertrain malfunction indicator" (wrench light)
Reply
Thread Tools
Old 03-07-2011, 09:59 PM   #1
Worktofish
Eastern Washington
2006 XLT
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
I have a 2006 4.0L 4x4 Explorer that just lit up the "powertrain malfunction indicator" (wrench light) on the dash.
I bought this vehicle over 4 years ago, and it has always hesitated when cold, (similar to a cold, carbureted engine for those of you who remember those...). It runs fine after.
However, today after starting it cold, it hesitated, then shimmied, and then the powertrain malfunction indicator came on. I drove it 4 miles home, but it had shifting issues.
I was planning on having it towed to the dealer, however, after reading another post, I see that it can be intermittent. Sure enough, I just went back out and started the vehicle - no light!
Any ideas what this means???
Worktofish is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-08-2011, 06:41 AM   #2
swetrid
Reading Pa
1999 Eddie Bauer
Vehicle Specs
Quoted: 4 Post(s)
You need the trouble codes from pcm to help diagnose.
__________________
Resident Ford Tech for the last 17 years, 1999 Eddie Bauer Explorer, 1987 Mustang GT, 2013 Focus ST
swetrid is offline   Reply With Quote
Old 03-08-2011, 07:11 AM   #3
PEAR0119
Ottawa, Ontario
2006 Explorer XLT 4.0 4x4
Vehicle Specs
Quoted: 2 Post(s)
I had the same sorta issue with my 06. I was driving down the highway and all of a sudden it hesitated and shimmied then the wrench light came on. I pulled over, turned the car off then back on and everything was OK until the next day. It eventually got so bad that I couldn't even drive the car and it finally threw a MIL light that stayed on.
When I read the codes it threw a "Throttle stuck open" and "Forced idle" codes. I can't remember the exact code number. So, I brought it to Ford and they replaced the TPS sensor on the throttle body as it was throwing "erratic voltage" codes when they read them. Been driving daily for 5 months since and have had no issues.
My issue was intermittent but since the wrench light turned off every time the car was turned off, I would of gotten the runaround from Ford. Once the MIL light stayed on I then brought it to Ford and they replaced the TPS sensor under warranty.
__________________
2006 Explorer XLT V6 4x4 --> mine
2005 Mustang GT --> mine
2003 Explorer limited 100th anniversary 4.6L 4x4 --> Dads
2009 Expedition Limited 5.4L 3V 4x4 --> Dads
PEAR0119 is offline   Reply With Quote
Old 03-08-2011, 07:16 AM   #4
PEAR0119
Ottawa, Ontario
Vehicle Specs
Quoted: 2 Post(s)
I found them. I was getting:
P2104 Throttle Actuator Control System - Forced Idle
P2111 Throttle Actuator Control System - Stuck Open
My best guess would be the TPS as your symptoms sound very similar to mine.
__________________
Old 03-08-2011, 09:19 AM   #5
Worktofish
Eastern Washington
2006 XLT
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Yes, that sounds very similar. I'll pull the codes and see what I get.
It ran fine this morning on my short drive to the gym and back. I'll pull the codes tonight.
Thanks for the information, I was having fears that the transmission was toast.
Old 03-08-2011, 02:19 PM   #6
PEAR0119
Ottawa, Ontario
Vehicle Specs
Quoted: 2 Post(s)
Mine ran fine somedays and others was a complete nightmare. My first reaction was that the trans was toast too. Once I read the codes I knew it was the TPS and Ford confirmed it for me. I was relieved to say the least.
__________________
Old 03-11-2011, 11:45 PM   #7
Worktofish
Eastern Washington
2006 XLT
Vehicle Specs
Quoted: 2 Post(s)
(Original Poster)
Any recommendations for a code reader? I was shocked to see the cheapest one for $60, and up to $250. I'm old school. The only way I ever read codes was to count the sweeps on a voltmeter. Can that still be done?
Also, I haven't had any problems since the original, but I'll see if I can get the codes off this weekend.
Old 03-12-2011, 01:16 AM   #8
BigRondo
USMC 1371
Worcester, MA
BigRondo's Avatar
2002 XLT V6 4x4
Vehicle Specs
Quoted: 94 Post(s)
You should be able to get the codes read at your local auto parts store for free. Around here AutoZone and Advance Auto Parts do it for free and give you a print out of the results.
__________________
Rondo - USMC, Combat Engineer, 1983-1996
Click here for a list of my write-ups!
Quote:
Originally Posted by FIND on 4-22-13
Don't mess with Boston. They will drop everything, hunt you down, and then go on like you never existed once they are done cleaning up the mess.
BigRondo is offline   Reply With Quote
Old 03-16-2011, 02:50 PM   #9
FordService
Official Ford Rep
Dearborn, MI
FordService's Avatar
2014
Vehicle Specs
Quoted: 301 Post(s)
Worktofish,
This is Seni with Ford Customer Service. I am sorry your Explorer is not performing to your expectation. We recommend that your vehicle be inspected by a Ford dealership to determine the cause of any symptoms your vehicle may be experiencing. If there is no coverage under applicable warranties, recalls, or ESPs, repairs and services would be your responsibility. As you mentioned, the problem may be intermittent, but that doesn’t mean it’s not a problem. Your next step is to make an appointment with your servicing dealership to have your vehicle diagnosed. Please PM me if further assistance is needed. Thank you.
Seni
__________________
FORD SERVICE
p: 800.392.FORD
t: @FordService @Ford
f: facebook.com/FordExplorer facebook.com/Ford
FordService is offline   Reply With Quote
Old 03-18-2011, 02:15 AM   #10
DavidEBSmith
Chicago, IL
'07 Mountaineer
Vehicle Specs
Quoted: 2 Post(s)
Like the next poster said, you can get it done for free at many auto parts stores; I have a basic Actron code reader like this one that's $50 and it works fine.
http://shop.advanceautoparts.com/web...T|GRP2018_____
DavidEBSmith is offline   Reply With Quote
Old 03-29-2011, 04:05 PM   #11
mcucciare
Vehicle Specs
Quoted: 0 Post(s)
I had the same problem with my 06 4.0L. It started off very intermittently, but over a year or so it got worse and worse. Pulled codes and there were 3. They were related to the TPS. There is an updated throttle body assembly that comes with the TPS. Replaced that and all has been good for about a year now. Seems to be a pretty common problem on these. I've heard of people going through 2 or 3 before they get a good one. Good Luck!
Mike
mcucciare is offline   Reply With Quote
Old 05-12-2015, 11:24 PM   #12
Phildad
2004 Mountaineer
Vehicle Specs
Quoted: 0 Post(s)
Backyard Mechanic
I also had Limp Mode problems that got worse over a period of a week or two. P2104, P2111, & P2112. After reading quite a bit, I replaced the TPS but no better at all. Finally got so bad that as soon as I touched the throttle it would show the wrench and limp mode.
Had already cleaned the MFS and the ETB and they were very clean. Checked the connectors and wiring and everything seemed fine.
Frustrating.
So read a bunch more and decided I was going to have to spend the money and get a new ETB next... But didn't want to spend that much money.
As a final option, I took the ETB drive apart and found the DC motor had very dirty armatures. It was tricky, but gently pulled the brushes back and put 600 grit sandpaper in front of them in a very tiny piece. Using the brushes, I pressed the sandpaper against the Armature gently and twisted and twisted the DC motor spindle. Took three pieces of sandpaper to get most of the black off the Armature. This was rather tedious and you have to be gentle. Also tricky to get it all back together, but after PCM reset, reassembly and starting the truck, and going through learning procedure, it ran perfect. Yay!
Just wanted to pass this on to those of you that know much more than I do. Hope it may help you understand why the error codes trip and the engine becomes useless.
Phildad is offline   Reply With Quote
Old 07-27-2015, 07:43 PM   #13
cadguy49
West Virginia
2007 Ford Explorer XLT
Vehicle Specs
Quoted: 0 Post(s)
2007 explorer Powertrain malfunction indicator
Powertrain malfunction indicator wrench comes on when I start the vehicle, then goes off in a matter of a minute. I don't notice any power or shifting issues. Any thoughts?
cadguy49 is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
