EF Swag Store 2013 Ford Explorer Forums Elite Membership Chat Room My Posts Reviews Explorer Photo Gallery
Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Under the Hood > Explorer, Ranger - Computers, Chips, Tuning > EEC V
Notices
No power at the OBD II receptacle.
Reply
Thread Tools
Old 03-09-2011, 08:25 PM   #1
usnwalt
Oklahoma City
2004 Sport Trac XLT
Vehicle Specs
(Original Poster)
My 2004 Sport Trac is having its fair share of issues, so I purchased a code scanner to help me out. When I plugged it into the OBD II receptacle, the scanner did not illuminate. I then plugged the same scanner into the OBD-II port in my 2004 F-150, and the scanner does function properly in the F-150. I checked all the fuses that are labeled PCM and they all check good. Is that were the voltage for that receptacle comes from?
Currently, the truck will not start, however, removing the negative battery terminal and letting it sit for about 5 minutes, then reconnecting the neg., the chances of the truck starting increases. It has started and ran for several minutes until I turned it off and unsuccessfuly attempted to start it immediately afterwards. When it does run, it does not idle smoothly above 3000 RPMs.
The truck has 73K and was in good running condition until recently.
Thank you for any input or information you can give me.
usnwalt
usnwalt is offline   Reply With Quote
Old 03-11-2011, 09:03 AM   #2
BrooklynBay
Aerostar Forum Moderator
Brooklyn, NY
BrooklynBay's Avatar
88 89 93 95 96 Aerostars
Vehicle Specs
Welcome to this forum! I've moved your thread into the EEC-V section. Check the PCM relay.
BrooklynBay is offline   Reply With Quote
Old 03-11-2011, 05:47 PM   #3
swetrid
Reading Pa
2001 Eddie Bauer
Vehicle Specs
There is a fuse for the dlc which is also the cigar lighter fuse.
__________________
Resident Ford Tech for the last 17 years, 2001 Eddie Bauer 5.0L, Cherry Bomb Cat back, 2010 Ecoboost Flex
swetrid is offline   Reply With Quote
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
