Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > Explorer & Ranger Transmissions, Transfer Cases, & Differentials
Notices
Explorer & Ranger Transmissions, Transfer Cases, & Differentials Transmissions, Transfer Cases. A4LD, 4R70W, 4R44E, 4R55E, 5R44E, 5R55E, M5OD, BW 1354, Control Trac, GEM, AWD. Ford 8.8", Dana 35
speed sensors and 4wd flashing lights for 96 EB
Reply
Thread Tools
Old 03-12-2011, 05:15 PM   #1
raulrdz3
Menlo Park, CA
1996 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
Hi everyone!
My 4wd does not work when the car is moving, and only snow chains made it not do the 6 flashes. When I have the car parked or very slow speeds, I have no problems. After days of reading in the forums, I'm pretty sure that my problem are the HALL speed sensors. The only thing is that with my 96 Eddie Bauer, there's 3 types of speed sensors: 1) a regular speed sensor (autozone part SU1019), 2) an abs sensor which I think is in the rear axle (Autozone SU2175), and 3) a transmission speed sensor (autozone part SU2320).
which of those 3 are the HALL sensors in this model? I think it's 1 and 2 but if someone can confirm that would be great
raulrdz3 is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-12-2011, 08:46 PM   #2
albi1cnobi1
Elite Mountaineer
South Jersey
albi1cnobi1's Avatar
99 Mountaineer V6 4x4
Vehicle Specs
Quoted: 115 Post(s)
Hey raulrdz3,
Your 96 doesn't have a speed sensor in the rear axle. Ford didn't move it from the output of the transfer case until 99. What type of t-case do you have? If it is the control trac 4405 the 4wd selector switch will say " 4wd auto-4wd hi-4wd lo". If that is the case there are 2 hall effect sensors , 1 in the front output and 1 in the rear output of the t-case. Unfortunately if these are bad the t-case is coming out and getting opened up. They are internally located in the t-case. The other sensor is mounted on the output of the t-case and is for the speedo.
__________________
Al
99 Mountaineer 4.0 SOHC. 2013 F150 SuperCrew 4x4
TT/F-150 Leaf Spring Mod, 2" BL, 32x11.5/15 BFG A/T's, Rancho 5000's, Gibson Catback, Coilover conversion(in process), Electric Fan Conversion, AVM Manual Lockout Hubs, Dual Battery System. EATC Mod. BW1354 swap. My 4405 To 1354 Swap Thread Support your own economy, Buy American, all of our jobs depend on it.
albi1cnobi1 is online now   Reply With Quote
Old 03-12-2011, 10:49 PM   #3
raulrdz3
Menlo Park, CA
1996 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
the switch just says 2wd-4wd auto-4wd high
i do see a speed sensor right next to the shift motor, but i now understand that is different than the hall effect sensors. then there's 2 hall effect sensors i should be focusing on fixing?
Old 03-12-2011, 10:51 PM   #4
raulrdz3
Menlo Park, CA
1996 Eddie Bauer
Vehicle Specs
Quoted: 0 Post(s)
(Original Poster)
and thanks for your help!
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
