| EF Swag Store | 2013 Ford Explorer | Forums | Elite Membership | Chat Room | My Posts | Reviews | Explorer Photo Gallery |
| Stock 2011 - 2014 Ford Explorer Discussion 2011 - 2014 Ford Explorer reviews, problem solving, maintenance, TSB, service bulletins, owner reviews, specifications, Ecoboost. |
Thread Tools |
#1 |
Wannabe Elite Explorer
Troy, NY
'11 XLT
Aluminum Canoe on the stock bars?
Hey everyone. I just installed my stock crossbars and I own a rather heavy 9 foot aluminum canoe. Whats the best way for me to transport it? Right on the bars and tied off to the front & rear or do I need some kind of canoe carrier?
#2 |
Holland Patent, NY
2011
Don't have my X yet, but the manual says Max recommended weight is 100 lbs. Is it more than that?
Maybe others can chime in on how important adhering to that Max Load is. Assuming no load issues, my guess is it would always be better to use a carrier specific to what you're carrying (i.e. spread the load, secure tie down, etc.). |
#3 | |
NJ
'97 XLT
Quote:
#4 |
I don't think it should max out the weight. I would put some rubber strips or similar on the cross bars to keep them from getting scratched and to provide a material that can compress when you lock down the canoe. As mentioned, I would also put some neoprene strips or rubber strips under the tie downs.
Not sure what you use to tie, but ratcheting straps are the only way to go...I hardly use rope or bungies anymore. If you go to Home Depot in the Hardware aisle they will have them. There are single packs of straps for like $20, but they are rated for like 10000lbs. What you want are the 4 pack of straps (they come in a plastic case) that are like $10-$15. They should be rated for about 1000lbs each. They also have rubber on the handles so they won't stratch anything the ratchet is up against. I can't recommend them enough. Here is a picture for you, this is back on my 2003 explorer, but I have done it on my 07 and plan to on my 11. Notice the strap on the hood? In the photo it is released, but I usually put one strap on each cross bar and then one from the back end to the receiver hitch (put a hitch in with a clevis or just tie around) and then I put one on the front over the front of the hood to the tow hook or something sturdy in front. These aren't necessary, just extra, make sure you pad it all well or you will scratch the paint when the wind makes the strap vibrate.
#5 | |
NJ
'97 XLT
Quote:
#6 |
Troy, NY
'11 XLT
Hey everyone,
Thanks for the great notes. I got a Yakima canoe kit that has these foam blocks that fit PERFECTLY around the stock crossbars. Now my last issue before I take it out this weekend, the only tow hitch up front is off center and where is the screw-in dealy? Do I have to worry about it being off center? |
| Tags |
| canoe, crossbars |
| Thread Tools | |
