Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
New Navajo Truggy build
Reply
Thread Tools
Old 11-27-2011, 12:33 PM   #181
baphomet666
Bordeaux,FRANCE
baphomet666's Avatar
Explorer.1994. 4WD
Vehicle Specs
it must be very pleasant driving a truck that goes everywhere.
the child can be proud of you
__________________
X 1994 4.0, Intake System Air Filter KKM,Flowmaster Exhaust System - Force II, BBK Performance 1580 66mm,
I'm French my name is Dominik
You want something of FRANCE ask me by PM
baphomet666 is offline   Reply With Quote
Old 11-27-2011, 01:17 PM   #182
4wheeltom
Filer, ID
4wheeltom's Avatar
91 XLT
Vehicle Specs
I've been watching this build for awhile, good to see that you got it in the dirt. Congrats on an awsome build.
4wheeltom is offline   Reply With Quote
Old 11-27-2011, 11:40 PM   #183
Elgatoprerunner
La Habra, CA
1992 Mazda Navajo Truggy
Vehicle Specs
(Original Poster)
Youtube video
Hope this works. This is the link for the Navajo shake down run.
http://youtu.be/i1MHgSUukuY
Elgatoprerunner is online now   Reply With Quote
Old 11-28-2011, 12:31 AM   #184
Brandon96
Central Virginia
'96 XLT 4.0 OHV
Vehicle Specs
If I could shake your hand right now I would.
AWESOME build sir, awesome.
__________________
1996 XLT 4x4 - TruckTruck
BUILT 4.0L OHV/SOHC Hybrid - Done.
Before - After
Brandon96 is offline   Reply With Quote
Old 11-28-2011, 07:28 AM   #185
baphomet666
Bordeaux,FRANCE
Explorer.1994. 4WD
Vehicle Specs
Very impressive work of the front axle and suspension, WHAou I made the travel FRANCE for a ride with you immédiatly if you invite me
__________________
Old 11-28-2011, 11:36 PM   #186
mounty71
It's green, not gray.
San Francisco, CA
mounty71's Avatar
'00 Mountaineer
Vehicle Specs
Why is the exo shaking so much?!
__________________
MATT SCHWARTZ
2000 MOUNTAINEERINATOR REGISTRY
1991 FORD EXPLORER (IN EXPLORER HEAVEN) REGISTRY
mounty71 is offline   Reply With Quote
Old 11-29-2011, 07:59 AM   #187
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Quote:
Good question Matt.
I was wondering the same thing. This is what I think was causing that.
1. The rock sliders still need some triangulation. The cage ties into them in front of the door and behind the door. At this point the rock sliders are welded to the frame at a right angle. I need some gussets there.
2. The body is still on stock rubber bushings. If the problem persists I may swap those out for some aluminum pucks. Boxing in the frame will also help.
3. The front of the cage is not finished yet, I still have to run some tubing over the fenders and connect to the bumper that isn't there yet.
4. I also plan on welding the rock sliders directly to the body to help tie everything together.
Planning a New Years trip to Truck Haven. Anyone else planning on a trip there?
Old 11-29-2011, 08:16 AM   #188
mounty71
San Francisco, CA
mounty71's Avatar
'00 Mountaineer
Vehicle Specs
Have you considered adding some triangulation to the cage from side to side? You'd have to go through the cab but the strength gain would be worth it. And you probably already know, but only weld the sliders to the cab if you solid mount the cab, otherwise the body will just tear away from the sliders.
__________________
MATT SCHWARTZ
Old 12-15-2011, 10:56 PM   #189
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Fox 4" air bumps and Deaver springs
Here are my new (to me) Fox 4" 2.0 air bumps. They arent fully extended because I let all the Nitrogen out. If 4" is too much I can adjust their travel by inserting a spacer inside them.
I got to say that Deaver spring co is a top notch class act company. These guys will work with you to suit your needs. These springs new are $650. They sit a little higher than I had hoped. With a full tank of gas, tools, cooler full of beverages and 4 people I think it will sit pretty level.
I came across some used 14" travel Bilsteins for the rear. The Pro Comp shocks I was using were a piece of shit. Yes that is still a stock shackle. I don't want any more lift and this thing pulls a true 14" of rear travel, maybe more because my shock is on a slight angle. I don't think fabricating shackles will do me any good.
I bought some bump stop cans for the rear. Some day I will try to get air bumps for them also. I'll be checking Craigslist frequently
Old 12-16-2011, 03:14 AM   #190
baphomet666
Bordeaux,FRANCE
Explorer.1994. 4WD
Vehicle Specs
Great look.......
~ Dominik
__________________
Old 12-16-2011, 10:07 AM   #191
GRNMACHINE
IL
95 Sport 4x4
Vehicle Specs
Incredible!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
__________________
95 Sport 4x4, 3.73, tt/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15x10 DC-1's, Pro Comp ES9000 shocks, Flowmaster Catback, ARB OME Leaf Springs, 2" BODYLIFT
"Thy shall Not Leaveth Thou Chariot Stocketh" Explorer 2nd Genesis
GRNMACHINE
GRNMACHINE is offline   Reply With Quote
Old 12-16-2011, 11:29 AM   #192
Foxracin
Mount Holly, NC
1991
Vehicle Specs
You still have the old superlift springs you took off? If so I really need them.
Foxracin is offline   Reply With Quote
Old 12-16-2011, 11:54 AM   #193
baphomet666
Bordeaux,FRANCE
Explorer.1994. 4WD
Vehicle Specs
with gold hands and a head that thinks well, it's amazing what can be done ......... certainly the time and patience more and some
~ Dominik
__________________
Old 12-16-2011, 11:55 AM   #194
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Quote:
Unfortunately the reason I had to buy new springs is I messed up the Superlift springs.
I was attempting to make my own leaf pack and accidentally cut the wrong leaf there for ruining the Superlift springs.
They were pretty clapped out and bent any ways.
Sorry
Old 12-16-2011, 02:45 PM   #195
Xeek
Virginia Beach, VA
1991 xlt
Vehicle Specs
http://www.nc4x4.com/forums/showthread.php?t=125323
Xeek is online now   Reply With Quote
Old 12-17-2011, 11:11 AM   #196
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Cycling Deaver leaf springs
This seems to be the most popular way to cycle leaf springs.
I made spacers to accomidate for the leafs I removed and lowered the vehicle with the forklift. Took some measurments to see how long the bump stops should be.
Full bump
It pulls a true 14 1/2" of rear wheel travel. I guess I could get more if I wanted to modify the shock mounts and get longer shocks.
As it is now the springs have a drastic negative arc at full bump. Not sure how good this is for the springs.
Old 12-17-2011, 01:39 PM   #197
mounty71
San Francisco, CA
mounty71's Avatar
'00 Mountaineer
Vehicle Specs
Generally I think 1" to 2" of negative arch is acceptable, but unfortunately with the stock leaf mounts and the design of the frame of explorers, you lose a lot of bump travel if you limit it. And bump travel is your friend on a desert truck. That's why in the future I'm planning on doing custom leaf mounts.
__________________
MATT SCHWARTZ
Old 12-20-2011, 11:46 PM   #198
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Started on the front bumper.
Started on the front winch bumper today. Still have a lot of tubing still to run.
This tubing running in front of the grill is a random length just to hold everything together. It will be cut back later.
Removed the body mount. I'm going to solid mount all the body mounts
Maybe one day I'll buy a winch. Just wanted to make sure the bumper could handle one.
Old 12-21-2011, 04:24 AM   #199
baphomet666
Bordeaux,FRANCE
Explorer.1994. 4WD
Vehicle Specs
Shit, or you take all your ideas
~ Dominik
__________________
Old 12-21-2011, 11:05 PM   #200
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Bumper progress
Got a few more pieces tacked up. I only have about 1 1/2 hours on work nights to work on it.
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
