#1 Resource for Ford Explorers and Rangers for 20 years 1996 - 2016
2016 Explorer Forums Elite Membership Chat Elite Rides Reviews Gallery
Go Back   Ford Explorer and Ranger Forums "Serious Explorations" > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
New Navajo Truggy build
Reply
Thread Tools
Old 03-23-2011, 05:32 PM   #21
Elgatoprerunner
La Habra, CA
1992 Mazda Navajo Truggy
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Removed the bed and skinned the rear bed sides
Cut the bed off, or what was left of it. I wanted to make room for all of the upcoming cage and suspension work.
Not sure if I like the "bobbed" look. I might install the sides un-bobbed using Dzus fasteners. Any help with the design of the rear would be very helpful. I have searched all over this forum and Google for ideas.
This is off subject but I thought I might get some advise.
These are the rockers off a good used 4.0L motor i bought from a junk yard. The engine does come with a 3 month warranty. Any way, I noticed a rattle coming from the engine when warm and in neutral. This rattle happens around 2500 rpm. I had some good used rockers off the previous engine that I installed. I have not fired it up yet. Does anyone think this excessive wear could cause the rattle?
Elgatoprerunner is offline   Reply With Quote
Old 03-24-2011, 04:08 PM   #22
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Oops
Sorry for the multiple posts of the same topic. There was a 3-4 day delay from when I posted till it showed up. Does anyone know why?
Last edited by Elgatoprerunner; 03-25-2011 at 12:35 PM. Reason: Multiple Posts of same topic. 3 day delay. contacted Rick Horwitz about it.
Old 03-25-2011, 09:05 AM   #23
bftank
rifle, COLORADO
1994 explorer xlt
Vehicle Specs
Quoted: 2 Post(s)
i vote tubestyle bed with removable skins. no bed does look weird.
bftank is offline   Reply With Quote
Old 03-25-2011, 11:03 PM   #24
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Bed sides
There will be some sort of bed sides when I'm done.
The problem I'm having is with the rear window opening.
The bed area is so short that making a cage that allows
window to function is a challenge. I've seen a few truggys
with a high caged rear that looked good. Looking around the
forums for ideas.
Old 03-26-2011, 01:20 AM   #25
FROADER
Moderator
Huntington Beach, CA
FROADER's Avatar
2010
Vehicle Specs
Quoted: 61 Post(s)
You probably don't need the rear glass to go all the way up. If you go that way, you could put some rubber (soft material) pads on a bar that it goes up to. Just an idea if that made sense.
FROADER is offline   Reply With Quote
( Join the Elite Explorers )
Old 03-28-2011, 09:51 AM   #26
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Beadlocks are here. This is how a pipe fitter does it.
I finally received my 16.5x8" steel wheels from 4 wheel parts. I installed the wheel on my pipe positioner (it turns with a foot peddle), broke out the Miller Passport and started welding. Here are some picks of the progress.
Old 03-28-2011, 09:21 PM   #27
Slowlyvverot
Greensboro, NC
93 ExElTee
Vehicle Specs
Quoted: 0 Post(s)
sweet.
__________________
'93 XLT: 2" lift on 33s, 4.88s
DubDub
Quote:
Originally Posted by Stic-o View Post
Sway bars! You don't need no stinking sway bars!
Slowlyvverot is offline   Reply With Quote
Old 03-29-2011, 02:14 PM   #28
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Bed cage ideas
I came across this picture. I like the way the tire is tucked out of the way.
Might look ok with a tiny bed area like mine.
The license plate does hinge out of the way to remove the tire.
Old 03-29-2011, 09:36 PM   #29
Keeper0311
Riverside, CA
2000 XLT 4x4
Vehicle Specs
Quoted: 13 Post(s)
Looks like one sweet build! Hope to see you out at Truckhaven.
Keeper0311 is offline   Reply With Quote
Old 03-29-2011, 10:12 PM   #30
GRNMACHINE
IL
GRNMACHINE's Avatar
95 Sport 4x4
Vehicle Specs
Quoted: 35 Post(s)
Subscribing, very different-I like it and want to see the progress.
__________________
95 Sport 4x4, 3.73, tt/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15x10 DC-1's, Pro Comp ES9000 shocks, Flowmaster Catback, ARB OME Leaf Springs, 2" BODYLIFT
GRNMACHINE
GRNMACHINE is offline   Reply With Quote
Old 04-01-2011, 10:14 PM   #31
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Gonna rip into her tomorrow.
Thanks for all the Kudos on the build. Still a long way to go. The next issue I see is adapting the VSS or vehicle speed scensor to the 9" or relocate it to the transfercase output. What is the cheapest way to do this? The Navajo does have a Auto. I did think about converting to manual shift auto. A ratcheting shifter where the console is now. Anyone doing this?
Did a quick rattle can paint job.
Rear end is coming out tomorrow. Hopefully I can get the 9" under it and siting on the swampers. I'm doing a spring over axle.
Bead lock have held air for the past 3 days.
A little primer and gloss black and you would never know its 32 years old
Old 04-02-2011, 12:13 AM   #32
RangerX
Moderator
Elite Ranger
Omao, Kauai
RangerX's Avatar
'93 Ranger XLT 4X4
Vehicle Specs
Quoted: 184 Post(s)
Quote:
Originally Posted by Elgatoprerunner View Post
You should find a bed from a 92 Ranger, cut it in half at the center of the wheelwells, and graft it on.
__________________
Bill Collins
93 Ranger XLT 4X4
"Beauty is only sheet metal deep."
RangerX is online now   Reply With Quote
Old 04-02-2011, 11:27 AM   #33
GRNMACHINE
IL
GRNMACHINE's Avatar
95 Sport 4x4
Vehicle Specs
Quoted: 35 Post(s)
Dig the "cage bed" pic. Nice weld work on the wheels too!
__________________
GRNMACHINE
Old 04-02-2011, 12:58 PM   #34
Dannyboy
Other Make & Models Mod
4348′48″N 9113′59″W
Dannyboy's Avatar
91 4 do'
Vehicle Specs
Quoted: 6 Post(s)
Not sure if that is an issue, I have a 9" on my 91 as well as a C5 transmission, VSS is in the transfer case.
Dannyboy is offline   Reply With Quote
Old 04-02-2011, 02:28 PM   #35
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
VSS. And Ford 9"
I think you solved your own problem. I heard that the A4LD needs the vss in orders to shift. That is why I was considering a manual ratchet type auto. Smell what I'm thinking?
Old 04-02-2011, 06:57 PM   #36
iheartbeams
laguna niguel
1993 xlt
Vehicle Specs
Quoted: 0 Post(s)
your old rims 15 by 8? any chance you wanna get rid of them?
iheartbeams is offline   Reply With Quote
Old 04-02-2011, 09:50 PM   #37
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
All the old axles, wheels, and stuff like that was heading for Craigslist.
I have 5 of those wheels. None are in great condition. Not sure the width.
Old 04-02-2011, 10:04 PM   #38
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Wow, Its So BIG.
Got the 9" installed today. Like a dumb ass I cut the old u bolts with my plasma to save time. It turns out I could have used them. Oh well.
The S.O.A gained me about 6"
Forklift made quick work of the swap
My son Nate. He's spent countless hours with me at my shop, he never complains.
I used some pipe jack stands under the front frame. Removed puney tires and mocked up the front.
Tomorrow I should finish the rear and hopefully get the TTB removed from the front.
Old 04-03-2011, 07:57 PM   #39
Elgatoprerunner
La Habra, CA
Vehicle Specs
Quoted: 7 Post(s)
(Original Poster)
Sunday progress
I thought of a good way to set pinion angle without having to worry about if the axle moved side to side. I found and marked the axle where the perches needed to go. I then tack welded some angle clips next to the perch to act as a guide.
I installed the u-bolts loosley so I could jack up the pinion. It worked really good.
Welded them on both sides
Of course I took a picture of the best weld. Local 250 Pipe fitter baby.
Old 04-04-2011, 10:16 AM   #40
n.gardner
Bel Air, MD
'02 XLS
Vehicle Specs
Quoted: 0 Post(s)
Dude this looks so badass. Cant wait to see it done.
__________________
Nick 02 XLS
2.25/1.75 BTF, 285's, procomp 52 wheels, ECOH bumper, Smittybilt XRC8, Light Bar, Air Box Mod, flowmaster 40, CB
MORE TO COME.....
n.gardner is offline   Reply With Quote
Reply
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
