Go Back   Ford Explorer Ranger Enthusiasts "Serious Explorations"® > Ford Explorer Ranger Repair - Troubleshooting - Modifications & Detailing Forums > 1991 - 1994 Explorer Ranger Navajo 1st Generation > Modified 1991-1994 Explorers
Notices
Modified 1991-1994 Explorers Questions concerning modifications to the 1991-1994 Explorer, Mountaineer, Ranger and Navajo. Aftermarket accessories and modifications. Bullbar, running boards, floor mats, cargo mat, DVD headrest, wheels, tires, stereo upgrade, headlights, mud flaps, lift kits, engine swap, transmission swap.
New Navajo Truggy build
Reply
Thread Tools
Old 07-10-2011, 10:42 PM   #101
FROADER
Moderator
Huntington Beach, CA
FROADER's Avatar
Vehicle Specs
Nice work!
I say at least one tub in the middle with plate and dimple dies on either side.
FROADER is offline   Reply With Quote
Old 07-11-2011, 05:23 AM   #102
86 slo-vo
owensboro, KY
92
Vehicle Specs
Quote:
Originally Posted by Elgatoprerunner View Post
Started by cutting just under the lip of the door
What a pain in the ass this was. There is about 3 or 4 different layers of sheet metal through our this area.
not what i was hoping to hear. ill be cutting mine soon. our sliders will be alot alike, you read me mind on what i wanted to do with mine lol
86 slo-vo is offline   Reply With Quote
Old 07-11-2011, 09:44 AM   #103
Elgatoprerunner
La Habra, CA
1992 Mazda Navajo Truggy
Vehicle Specs
(Original Poster)
Quote:
The initial cut was done with a die grinder and cutting disc. I peeled back the sheet metal then cut the next with a plasma, peeled that back then cut the rest with a combination of plasma and sawsall. If that helps.
Elgatoprerunner is offline   Reply With Quote
Old 07-11-2011, 02:05 PM   #104
shawn.m
placerville, ca
shawn.m's Avatar
1989 Bronco 2 with 92 4.0
Vehicle Specs
vote for one of the greatest fab threads on this site! SICK welding skills!
subscribed
__________________
sold but not forgotten 1989 B2 - 1993 4.0 D35 4.10 LS, 8.8 4.10 SOA LS and disc brakes, 6" superlift, SS brake lines front, hatch cut off, 75mm AeroStar MAF Sensor, 2.5 Magnaflow Cat into 2.5 Flowmaster
shawn.m is offline   Reply With Quote
Old 07-11-2011, 07:28 PM   #105
zensius
Pleasant Hill, CA
zensius's Avatar
'92 4 dr. EB
Vehicle Specs
I'm not sure how well this would work for your rig. But there was a mod people were doing some years ago. On top of the stock leaf stack you would add the top leaf from a Ranger leaf set. Then cut the eyes off the original top leaf. It was supposed to allow for a softer ride, to a point. Never did it so I can't vouch for it. I think it was called The Zimmerman mod. Look it up.
__________________
92 4wd 4dr EB, Superlift 5.5, lock right front,No Slip rear, Rs 9000's, 31's/33's,Warn hubs, giant carton of milk, enormous bowl of cereal, over 75 cereal pillows.
zensius is offline   Reply With Quote
Old 07-12-2011, 07:22 PM   #106
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Air Shocks
Has anyone used air shocks on their SAS'd explorer? I'm not really happy with the front coils on the navajo. Way too soft. Scary soft. I've been looking at Sway A Way 2.5 air shocks. Anyone have any advice on these? Only thing I've heard is that they are used best on lighter crawlers. The Navajo is pretty light now. And I plan on going fiberglass front end so it will be even lighter.
Its either air shocks or coil overs, they are just so dammed expensive.
I'm probably going to move the front coils to the rear and run a similar radius arm set up.
Old 07-12-2011, 09:08 PM   #107
86 slo-vo
owensboro, KY
92
Vehicle Specs
if your worried about being soft you should stay away from the air shocks. they can be extremely soft. which is the reason why most of the guys that run on the street go to coilovers.
your weight range is fine for airshocks but you would probably need some kind of sway bar for the street if the leafs feel soft.
Old 07-12-2011, 11:42 PM   #108
FROADER
Moderator
FROADER's Avatar
Vehicle Specs
IZwack used airshocks on his initial build. I don't remember if he's using them on the rebuild.
http://www.explorerforum.com/forums/...+obama&page=17
Old 07-12-2011, 11:58 PM   #109
mounty71
It's green, not gray.
San Francisco, CA
mounty71's Avatar
'00 Mountaineer
Vehicle Specs
Have you thought about just getting some good quality rebuildable/valvable shocks under the front? You want soft springs for crawling so it can flex easily, but a well-valved shock will do wonders in controlling how quickly the suspension will compress and rebound. You can find some good deals on used King/Fox/Swayaway/Bilstein/Radflo/etc. shocks and they are easy to rebuild and valve to exactly what you want. That's the route I would go if it were my truck.
__________________
MATT SCHWARTZ
2000 MOUNTAINEERINATOR REGISTRY
1991 FORD EXPLORER (IN EXPLORER HEAVEN) REGISTRY
mounty71 is offline   Reply With Quote
Old 07-13-2011, 12:09 AM   #110
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Thanks for the great info guys. Wasn't aware that air shocks are also soft. I think if I get a sway bar it will help a lot.
Something I just thought of. Does it matter which end is up on a typical shock? I'm running nitrogen procomp shocks with the body up. Could that cause the softness? It almost feels like the shocks aren't doing anything.
Old 08-07-2011, 10:29 PM   #111
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Cage, 1st try
Started on the cage.
Tacked the fenders in place for inspiration
After all this work I ended up scrapping the rear section. Good thing it was only tacked.
Old 08-07-2011, 10:50 PM   #112
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Cage 2nd attempt.
I'm ditching the Navajo fenders and going to make my own. Will run LED's for brake lights.
I want to make the rear pure buggy.
The rear will be able to carry a 38" tire vertically right behind the gas tank.
I will probably make a tool box in between the tire and cab.
Still have a lot of tubing still to fab for the rear.
Old 08-07-2011, 10:54 PM   #113
GRNMACHINE
IL
95 Sport 4x4
Vehicle Specs
Really Crazy Cool!!!!!
__________________
95 Sport 4x4, 3.73, tt/shackles, K&N FIPK, 33X12.50X15 BFG T/A, 15x10 DC-1's, Pro Comp ES9000 shocks, Flowmaster Catback, ARB OME Leaf Springs, 2" BODYLIFT
"Thy shall Not Leaveth Thou Chariot Stocketh" Explorer 2nd Genesis
GRNMACHINE
GRNMACHINE is offline   Reply With Quote
Old 08-08-2011, 12:26 AM   #114
shawn.m
placerville, ca
shawn.m's Avatar
Vehicle Specs
coolstuff!
__________________
Old 08-08-2011, 09:10 AM   #115
Dannyboy
Other Make & Models Mod
43°48′48″N 91°13′59″W
Dannyboy's Avatar
91 4 do'
Vehicle Specs
Yes, it does matter if they are upside down
Dannyboy is online now   Reply With Quote
Old 08-10-2011, 12:16 AM   #116
mini
Crazy Canuck
1993 expo
Vehicle Specs
looks like a killer job so far the only prob i see with your plan is how do you plan to remove a 38" tirer plus rim vertically ?
would it not be easier if the back bars were hinged at one end to make life a little easier for spare removal
just my .02
mini is offline   Reply With Quote
Old 08-10-2011, 10:30 AM   #117
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
just my .02
Good point. These bead Locked swampers are not light. I'm still deciding on spare mount location. I made a mock up spare last night out of ply wood. I'll do some trial fitment and see where the best location is. Remember there still needs to be room for my ice chest and tool box.
If I need to get to the spare I hope I have some buddies with me.
Old 08-10-2011, 09:04 PM   #118
GRNMACHINE
IL
95 Sport 4x4
Vehicle Specs
Yeah ice chest, gotta stay hydrated!!
__________________
GRNMACHINE
Old 08-11-2011, 08:10 PM   #119
tylersloan
Central Illinois
92 explorer 4 door
Vehicle Specs
Wow just wow this is some of the best fab work I've seen in a long time keep it up and post more pictures lol.
__________________
92 explorer 2wd fixing to be a 4wd with a SAS and a divorced 205 with 78 to 79 bronco or f 100 axles
All post sent from my iPhone 3GS
tylersloan is offline   Reply With Quote
Old 08-28-2011, 10:56 PM   #120
Elgatoprerunner
La Habra, CA
Vehicle Specs
(Original Poster)
Cage design. 3rd attempt
I wasn't happy with the way the last cage was going so I scrapped it.
I ended up removing the rear shock hoop, moving the gas tank forward 5 inches and cutting the rear of the frame and 3" pipe cross member.
If you remember originally I bobbed the frame and wrapped it around some sch 40 3" pipe.
Once I moved the gas tank forward I cut the rear of the frame as close to the shackle as possible. I then wrapped it in plate steel
Reply
Search Explorer Forum
Top of Page
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
US Flag
We Support Our Troops!
Explore the site!
